#6126 |
Re: What did you do to your truck today?
Today I replaced my heater fan. I'm going to be needing that soon! Also
figured out my door locks. Narrowed it down to one key that fits the ignition and both doors even though one of the handles isn't the original! |
#6127 |
Senior Enthusiast
Slid under the back of the truck and cleaned/polished the chrome rear end cover and the brake lines on the axle housing.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#6128 |
Dropped off the rear end to get rebuilt and another load of parts for the powder coaters.
#6129 |
thats badass ![]() ![]()
![]() bagged 66 longbed build http://67-72chevytrucks.com/vboard/s...d.php?t=449548 my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918 |
#6130 |
Coil spring clamp kit came in from Eckler's today. Only thing left to get for the rear suspension is shocks and bolts and stainless button heads for the diff cover.
Gettin' excited now! Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla Matt. 6:27 "Who of you by worrying can add a single hour to his life?” http://www.67-72chevytrucks.com/vboa...=507266&page=2 |
#6131 |
Went to DMV, got the title started and got temporary registration! Hah, I'm finally on the road!
I see I am not the only one that pretend drives. If you look at my blog on my other project you should get a good laugh out it. My wife did. http://47ihc.blogspot.com |
#6132 |
Today I tackled the tank job I have been waiting to do; with some help from this forum I found out that my filler hose was cracked, I could feel it with my fingers. So, took out the tank and started the work (thanks to markeb01 for the trouble shooting suggestions).
Russell 1966 GMC Truck Project http://67-72chevytrucks.com/vboard/s...26#post5602826 |
#6133 |
I see a small light at the end of this tunnel..... Sanding party this weekend on the bed sides..... Hope to have a driver end of Oct.?????
#6134 |
![]() Join Date: Nov 2010
Sweet!!! Your truck is coming along great!!!!!
LIFE IS SHORT HAVE FUN |
#6135 |
Had new exhaust installed
#6136 |
Mounted my final 2 Titan 18" sPares, pix soon.
Posted via Mobile Device |
#6137 |
I adjuste the emergencybrake cable and take a ride to wisit a friend
#6138 |
Yesterday actually, drove my truck to work. I am in sales, so kinda drove it here and there all day, love the oohs and aahs from my clients!
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
#6139 |
Just received my 21 Circuit Rebel Wire kit, so im going to be having fun tearing into the wiring from now until I go back to work MON.
#6140 |
Compiled and cleaned a bunch of engine parts after a 3 year haitus things were scattered here and there. Short block's been together for about a year and now I'm just a timing chain and oil pump shaft away from having it ready to finish re-assembling. I hope to have engine finished and transmission ready to go on my off days next week...
#6141 |
Drove 'ol blue to church in the evening and as I got home I pulled up to the garage door and thought I would see if I had high beams,I knew I had low beams ... Turned out I had NO beams .. so I started checking it out, had power out of the dimmer on both sides when tested high and low .. so checked at the 2 wire bulkhead by the horn and had nothing .. got out my small sandblaster with the spot nozzle on it and blasted the corrosion off the terminals at the firewall and dimmer .. finally got them working and noticed the wire was hot to the dimmer switch ... Checked the bulbs and sure enough they were halogen ...lucky when I installed the relay for the radiator fan I installed a row of 3 from an 88 sierra .. So I had 2 spares .. so I figured it was time to do some wiring since I had already run the grounds and power for the relays it was a 10 minute job ...........
#6142 |
Changed the oil and cruised around. Also made me some iPhone wallpaper using a little app called Colorsplash.
#6143 |
#6144 |
#6145 |
Finished buffing my fenders today.
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=346597 https://www.facebook.com/pages/198-C...1434001?ref=hl |
#6146 |
![]() Join Date: Dec 2010
#6147 |
Dropped my seat, door panels and visors off to get stitched up yesterday, its a glide engineering seat with the foam, mounts fit great, not gonna make the Goodguys show in October, but fer sure in March
#6148 |
Wow! Looking very nice! What instrument panel is that? I like!
#6149 |
Dakota Digital, its tip top, the panel itself is less than an inch thick runs off a cat 5 cable, no speedo cable has a sensor with a wire and it programs itself, mark off a mile and push the button, gives % to empty etc, Thanks for the input
#6150 |
I gotta get me one of those! Very nice!
