Closed Thread
Old 05-10-2013, 04:31 AM   #1
westbrookw
LET'S GO...MOUNTAINEERS
westbrookw's Avatar
Re: What did you do to your truck today!
Powder coated some drums yesterday.
72 SWB/Step
westbrookw is offline
Old 05-10-2013, 10:58 AM   #2
VWNate1
VWNate1's Avatar
Post Re : Paint
Originally Posted by SCHRUMGMC View Post
Like the orange paint
I do have one question about paint
I need Ocean Green and Havana Beige Paints ...can a Lowes do it or what ?
There are OnLine Paint sources that $ave $erious $ .
First you have to figure out what kind of paint you want , single or multiple stage and so on .
Du-Pont has a very good Vintage Color Paints Program indeed , it goes by the original color code , NOT CHEAP .
I too like that Orange , looks very sweet .
Last night I drove my truck to a Car Nut gathering at a shop that apparently does rust repairs and custom body works ~ I talked to the owner and will take my truck there during business hours to let him look at my rusty cab & see what he thinks , co$t$ involved and so on .
To - day (Friday) is another work day for the rig , I have some rusty unobtanium gas tanks I have to take to Gas Tank RENU U.S.A. and another shop in Wilmington , see who does the best job on them .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 05-10-2013, 01:10 PM   #3
jabborabbo
jabborabbo's Avatar
So far I've spent about 3 hours trying to get the #@!*&%#@#@ left brake drum off my 67 GMC....
jabborabbo is offline
Old 05-10-2013, 01:16 PM   #4
Tshort1
Tshort1's Avatar
PB Blaster, Remove the parking brake, find deep well socket to fit over studs, slide socket over studs and beat socket Hard with hammer. Then beat around edge of drum untill it losens up. repeate steps above with mover force untill it breaks free. if that dosent work some have threaded holes 2 of them, find bolts that fit and tighten them in, they act as a press to press of the drum. Hope that helps a little. Dont be scared to hit the crap out of it.
Tshort1 is offline
Old 05-10-2013, 01:44 PM   #5
jabborabbo
jabborabbo's Avatar
I can see very very very slight movement around all the studs and the hub/axle when I use a screwdriver to pry between the drum and the backing plate - there's one spot on the hub/axle where I don't see much movement at all, though. I've backed the brake star adjuster thingy all the way out - if the drum was worn on the inside such that the brakes were keeping it from coming off I would get some kinda loose wobble in the drum when I pried on it from opposite sides, right? If it is the brake shoes holding it on, how do I deal with that?
Old 05-10-2013, 01:16 PM   #6
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Back the brake shoes off alot....otherwise a small piece of C4 will remove it
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Ol Blue K20 is offline
Old 05-10-2013, 06:57 AM   #7
Square_78
Square_78's Avatar
Installed my slam ss7 bags in front today. Much better than the ss6
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline
Old 05-10-2013, 09:06 AM   #8
jkeating1
jkeating1's Avatar
So the problem of having to put in super high pressure went away with the Ss7's? Are the specs on the 2700's comparable to SS7's, as far as pressure-to-lift?
JK
jkeating1 is offline
Old 05-10-2013, 05:41 PM   #9
Expat_dude
Expat_dude's Avatar
Yeah baby!!
1970 Chevy swb, project UGHH!
1987 Grand National
http://s168.photobucket.com/albums/u.../1970%20Chevy/
Expat_dude is offline
Old 05-10-2013, 08:28 PM   #10
glider_6969
My new clutch finally came him in, hope to do my new motor install this weekend, I waited over a week from on parts place later to find out it was on back order, I got fed up with them when to another parts place got it the next day, I should have known better
68 Long stepper
My other ride ,,, 07 Streetglide..
glider_6969 is offline
Old 05-10-2013, 09:45 PM   #11
longbed67
longbed67's Avatar
Fired up my turbocharged Inline for the first drive!
http://www.youtube.com/watch?v=z3MvI...ature=youtu.be
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline
Old 05-11-2013, 12:59 AM   #12
hart11b
hart11b's Avatar
Changed the tranny fluid/filter (didn't even make a big mess).
Changed the engine oil/filter.
Got the windshield wipers working and installed some new back-up light gaskets on my non-functioning back-up lights.
hart11b is offline
Old 05-11-2013, 01:16 AM   #13
profe56
Took away the manual transmission crossmember, now that the engine is not installed and I had a lot of free space to work.
profe56 is offline
Old 05-11-2013, 06:34 PM   #14
TexasK5
TexasK5's Avatar
Started the changeover from the Stewart Warner gauges I installed 18 years ago to some sweet new AutoMeter gauges.
TexasK5 is offline
Old 05-11-2013, 07:13 PM   #15
dishow
dishow's Avatar
Shop logo'd the 67.
90 Chevy 454 ss
dishow is offline
Old 05-11-2013, 08:18 PM   #16
vidman
vidman's Avatar
All Sheetmetal went to the cleaners..
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline
Old 05-11-2013, 08:22 PM   #17
glider_6969
Put the new clutch on and got the motor ready on the lift, dropping it in tomorrow,
68 Long stepper
Old 05-11-2013, 11:18 PM   #18
AustinScott
AustinScott's Avatar
Wow what a long day...
Did the final work on the transmission, installed a new trans cross-member, and reinstalled the transmission & exhaust...
I had to drill new holes for the cross-member.... not to bad, just something I didn't expect I would have to do.
I got the lower holes drilled for now, need a longer drill bit to do the uppers.
One thing I can say after the test drive.... WOW what a night and day difference the new valve-body & torque Converter made...
During the short test drive I fell in love with this truck all over again.
Here are a few pics...
Ill post more details about the cross-member and the hole offset in a different thread.
Scott
68-SWB, 327, hooker headers, spintec mufflers, disk brake 3.5/5 drop, buddy buckets, 200-4R, 2200 stall, 3.73 12bolt Eaton Posi,
My 68-SWB Photo Build Thread
All my Google Albums
AustinScott is offline
Old 05-11-2013, 11:46 PM   #19
VWNate1
VWNate1's Avatar
Thumbs up Re: What did you do to your truck today!
Scott ;
Is that tranny cross member better than the original ? if so why ? .
My '69 C/10's tranny cross member is beat up so I dunno if I should just go buy a cheap if perfect used one or what .
I drove my truck to the local Pick-A-Part where I spent the whole day stripping a '59 Metropolitan Nash FHC , it was 20' from a cherry '71 (?) long bed C/10 Custom Camper that was obviously some old Man's baby before getting abandoned in the carport and scrapped after he died . another RUST FREE CAB .
A few of the good guys from right here stopped by as I was working to say 'Hello ' ~ I was really busy and so didn't chat much but I always enjoy seeing you fine , hard working guys out and about .
Right next to me was a 1950 Chevy 3100 , another Old Man's rig that SHOULD NOT have been junked , it was a Low Rider and even had front disc brakes on the (rebuilt) original axle , boy howdy was there ever a crowd around it , all new chrome and window lifts , door latches , on and on....
A nice rust free cab too , I was there when the yard opened until about 3:00 PM and there's not much left apart from the bare cab , Muncie SM420 tranny , an open drive shaft rear end (hard to find and good to have) , bottom end of a later 235 C.I.D. engine and the rebuilt front axle ~ the two guys who got the disc brakes worked diligently for hours to get them off .
Another fine old rig that should have been put back on the road but many (like 50 +) guys were oh so happy indeed to get parts off it .
I need to check my spark plugs as it began to miss on the road home , it's been a while since I swapped them 'round and it still burns 1 quart every fillup
-Nate
Geezer
VWNate1 is offline
Old 05-12-2013, 12:31 AM   #20
AustinScott
Originally Posted by VWNate1 View Post
Scott ;
I decided to go with a different Cross-member for two reason, more exhaust clearance & more pan bolt access.
The stock cross member and a 2004r transmission do not play well together.
The rear pan bold is almost impossible to get off & harder to get back on and tight.
This cross-member was cheap, well build & has all the clearance in the world for pan bolt access.
One slight dislike i have found is the E-brake cable, it rubs slightly on the cross-member, due to the cross-member being a bit further back than the stock.
Let me find a few pictures to show you what I mean.....
TH2004r and stock member
Not that great of an angle, but you can see the rear bolt has only a fingers thickness between the cross-member & the bolt head.
This is with the larger mount as well
This is the E-brake cable on the stock member.
TH2004r and POL's Cross-member $65.99 LINK
This is the E-brake cable on the POL Cross-member. Slightly touching in the "off" position
Hope that helps.
Scott
Old 05-11-2013, 11:46 PM   #21
nlped
nlped's Avatar
^^^ that's one beefy trans crossmember! I'd flip those lower bolts though. They'll get scuffed on something and those threads will be ruined.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline
Old 05-12-2013, 12:06 AM   #22
AustinScott
Thanks for the input... But what you don't see in that picture is the exhaust.
It hangs below the frame rail. So the bolts are not in danger...
But the true reason I put them in this way is just in case they come loose and the nut falls off... the bolt will have a better chance at staying in place.
But good eye tho
Cheers!
Scott
Old 05-12-2013, 12:32 AM   #23
Shyguy
Junior Member
Shyguy's Avatar
But good eye tho
Cheers!
Scott
I always put bolts in the same way for the same reason. It works.
I bought a '75 C-30 and when crawling underneath to check things out I notice the rear transmission cross-member was bolted in and that a couple of nuts had fallen off, but the bolts were still in place from the top.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline
Old 05-12-2013, 12:41 AM   #24
AustinScott
Yeah I had something similar, check out this photo of when I had the exhaust redone. This was still the TH400 at the time.
Notice any bolts on the passenger side of the cross-member... OK it had one.. on the top rail... But all the others had fallen out.
Scott.
Old 05-12-2013, 01:31 AM   #25
Mr.Hyde
Applied undercoating to the inside of my bed panels. Can't say it's the most fun part of the build. Note to self wear sleeves and rubber gloves next time.
1968 Chevy C10 build - http://67-72chevytrucks.com/vboard/s...d.php?t=546713
Member of tailgate association of manitoba
Mr.Hyde is offline
Closed Thread
