#601 |
Re: 68 K-10 SWB build thread - project Money Pit...pics galore!
I suggest tacking it in from the back and then having someone TIG the front.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#602 |
the pics of the tack welds, is that weld thru primer?
"The way it is" truck build http://67-72chevytrucks.com/vboard/s...d.php?t=359200 ![]() |
#603 |
yep...why?
#604 |
it might have pulled heat were it was a butt weld rather than a back to back plug weld, causing your blow thru. were your welds ok once you ground down the spot and removed the primer? on the connecting welds. just something i had thought of.
#605 |
I think I had some thin spots from to much grinding...
Only way to fix was to build it up on the back and fill in the front and grind it back down... Or cut out all the metal and start over.
#606 |
oh well, it happens. that though is the beauty of metal, you can always fix it! let me know if youget in a bind.
#607 |
wilco, can you weld aluminum? I want to add a 3/8" bung to my gas tank for a future vent... do you know where to get any local?
#608 | |
3/8" npt? i think i have some round stock in the garage tht would work?
#609 |
sweet and sweet... 3/8"NPT to screw a brass 90 degree nipple into for a rubber check valve....
Nope, no gas in the tank, all safe. You have taps that large?
#610 |
yes, i think i have upto 3/4 in pipe thread.
thats good! i did a mc tank once that some guy paid like $1000 for his tank and 2 fender to be painted! he was worried about his paint! i was worried about removing his tank from my head!
#611 |
hmm, maybe we should talk about your welding fee before we get rolling!
You still looking for a bench seat? I have one for trade for some welding/powdercoating work...
#612 |
how big are the powder coat parts?
#613 | |
what kind of bench is it, our style/years?
#614 |
original bench out of my 68, has been recovered and seems to have good bones. Folds forward and has a decent cover on it now. It's green so it could easily be painted with that duplicolor vinyl paint to match better...
I need to do my crank pulley, small fan, water pump pulley, alt bracket and PS bracket. Can you do PS pumps too? SOmething in a semigloss... I also am thinking about coating my window vents semi-gloss black too... I don't think your over is large enough though.
#615 | |
does your bench slide forward and back smoothly? i am definately interested. if you want to call it even, i would be good with the coating and welding for the bench, let me know.
#616 |
I think it works well.. I'll check it out when in a bit and see...
The vent window parts might come off and fit easily into you oven...I have to strip one down and see... You don't have a media blaster cabinet do you?
#617 |
yes, i do have one.
#618 |
did you get a chance to check out your bench?
#619 |
durn, i'll check it out tonight...
maybe we can link up in a few weeks at your place and get some truck work done!
#620 |
let me know when your ready!
#621 |
got something done today... not much but something...
made it to autozone and picked up a new fan clutch, and U-joints. Also continued converting the column collar for the van tilt. THis "pot metal" is weird stuff... kinda mushy when you try to grind or cut it... I'll grind the epoxy down tomorrow and see how smooth it comes out... ![]() ![]() ![]() ![]()
#622 |
well, didn't do much this weekend...
did work on the column conversion, sanded down the collar and hit it with some etching primer... can pot metal be powdercoated? or should I just paint this and the tube... off to Florida for the week... more next week..maybe ![]() ![]() ![]() ![]()
#623 |
just realized how bad those pics sucked... sorry
I think it could use a little skim coat (glaze?) and another sanding and be pretty clean...
#624 |
I'm a poor spectator
So when are you gonna be driving this sucker?
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
#625 |
![]() need wiring $500 need brakes $250 exhaust $250 paintjob $2K? weatherstrip $150 (ordered w/$200 of knick knacks) more glass $100 all that on my $100/month allowance....that's 3 more years! but seriously I plan to hang sheetmetal this summer and finish the mechanicals... and if I seel some items and paintjob has been promised with upcoming promotion (within a year?) then I could see this somewhat complete next summer...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 03-01-2009 at 12:09 AM. |
