Old 01-10-2011, 02:32 AM   #601
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: my 80 build
A little progress video
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 01-10-2011, 11:30 PM   #602
flamingbig10
6.0 powered square
Re: my 80 build
I got the control arms and spindles cleaned up now I need to wait till it warms up so I can prime and paint them
Aaron
Old 01-12-2011, 12:29 AM   #603
flamingbig10
6.0 powered square
Re: my 80 build
Today I got the flex plate bolt and installed them
Aaron
Old 01-15-2011, 11:31 PM   #604
flamingbig10
6.0 powered square
Re: my 80 build
dad finished cutting out the floor pan today
also purchased new grade 8 hardware for the steering box, idler arm and brake valve
Aaron
Old 01-16-2011, 11:46 PM   #605
flamingbig10
6.0 powered square
Re: my 80 build
today I got the steering parts wire wheeled and prime with gloss black krylon rust tough
Aaron
Old 01-17-2011, 04:23 AM   #606
nbpro
Re: my 80 build
sweet!
nbpro is offline   Reply With Quote
Old 01-19-2011, 02:17 AM   #607
flamingbig10
6.0 powered square
Re: my 80 build
thanks, got the control arms cleaned up, also the hardware cleaned up and painted, coil springs and sway bar cleaned up
Aaron
Old 01-19-2011, 07:14 AM   #608
menace121978
menace121978's Avatar
Re: my 80 build
looking good Aaron! keep it up man!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 01-20-2011, 12:45 AM   #609
flamingbig10
6.0 powered square
Re: my 80 build
Thanks Dennis
Aaron
Old 01-20-2011, 01:54 AM   #610
Pop's C-10
Pop's C-10's Avatar
Re: my 80 build
[QUOTE=flamingbig10;3176776]
QUOTE]
Does that heater put out good heat ?
Pop's C-10 is offline   Reply With Quote
Old 01-20-2011, 09:14 PM   #611
flamingbig10
6.0 powered square
Re: my 80 build
[quote=Pop's C-10;4424920]
Originally Posted by flamingbig10 View Post
QUOTE]
It did blow ok, but I only had it ducted to blow on the window for defrost
I got the trans bolted to the motor tonight
Aaron
Old 01-20-2011, 09:17 PM   #612
mooseknuckles
mooseknuckles's Avatar
Re: my 80 build
It can't be any worse than the original heater!
mooseknuckles is offline   Reply With Quote
Old 01-20-2011, 11:28 PM   #613
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 01-21-2011, 10:02 AM   #614
JohnC
JohnC's Avatar
Re: my 80 build
Looking good man!
JohnC is offline   Reply With Quote
Old 01-22-2011, 08:14 PM   #615
flamingbig10
6.0 powered square
Re: my 80 build
thanks john
I got rear diff and flip kit swapped out but I'll need to install new leaf spring bushings, center pin, new rear shocks since my beltecs are shot I believe I use front shocks maybe some Monroe's, install new brake line and repaint every thing
Aaron
Old 01-24-2011, 10:08 AM   #616
twoodson
Re: my 80 build
Aaron - excellant job boss, keep up the good work, it is coming along that's for sure.
twoodson is offline   Reply With Quote
Old 01-24-2011, 11:30 PM   #617
flamingbig10
6.0 powered square
Re: my 80 build
thanks
Aaron
Old 01-29-2011, 01:02 AM   #618
flamingbig10
6.0 powered square
Re: my 80 build
got some work done today sandblasted the brake shields painted them and installed them, installed the brake hoses one had a split on the exterior shield they were still under warranty at Orielly's also I was able to warranty out the brake pads some time next week I will turn them at work.
pulled the c-notchs out of my old frame
there was still brake fluid in the caliper when I went to attach the hose to caliper the fluid dripped out and stripped most of the paint, they'll look ok till I get some willwood d-52s
brake line installed just need to install the brackets
starter installed and torqued down the torque converter bolts
Aaron
Old 01-30-2011, 10:57 PM   #619
flamingbig10
6.0 powered square
Re: my 80 build
I got some work done today found some more rust hopefully they reproduce patch panels for this area
Aaron
Old 01-30-2011, 11:22 PM   #620
flamingbig10
6.0 powered square
Re: my 80 build
found some more rust, so got it cut out
the rust on the braces is surface rust
Aaron
Old 01-30-2011, 11:57 PM   #621
benoit454
Chris
benoit454's Avatar
Re: my 80 build
lmc has the lower cowl piece so you're in luck.
Nice work.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 01-31-2011, 12:11 AM   #622
flamingbig10
6.0 powered square
Re: my 80 build
Thanks Chris I'll check it out, and my dads been doing cutting since he can control a grinder better then I can
Aaron
Old 01-31-2011, 12:14 AM   #623
flamingbig10
6.0 powered square
Re: my 80 build
I also ordered a valve spring tool for the 6.0
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
Aaron
Old 01-31-2011, 12:33 AM   #624
benoit454
Chris
benoit454's Avatar
Re: my 80 build
awesome, glad to help man.
Chris
GIT R DONE!!!!!!
Old 02-01-2011, 02:31 AM   #625
flamingbig10
6.0 powered square
Re: my 80 build
I ordered the patch panel I needed also ordered 81-87 inner bumper brackets
Aaron
