Old 07-13-2010, 12:58 PM   #601
Frizzle Fry
Frizzle Fry's Avatar
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
Thanks guys Feels good to be back at it. Though I have done a little here and there over the last several weeks. Those machined parts (tapered hole for lower BJ, press-fit hole for upper, and turned down alignment pins) caused the bulk of the delay...
The upper arms are 1x.120" and the lowers are 1x.156" providing a .688" ID; perfect for tapping with 3/4-16.
Back to the shop!
Frizzle Fry is offline   Reply With Quote
Old 07-13-2010, 02:48 PM   #602
hgs_notes
GEARHEAD
hgs_notes's Avatar
The original brackets that the upper A arms mount to seem to be a weak point compared to the strength of the components you have replaced or built. Do you think they will hold up under hard cornering?
hgs_notes is offline   Reply With Quote
Old 07-13-2010, 03:45 PM   #603
Frizzle Fry
The car weighs less than the Honda, but I have seen S2000 guys do a little extra welding on them. I'll do at least that.
Old 07-13-2010, 08:23 PM   #604
sparkydog
sparkydog's Avatar
Originally Posted by ERASER5 View Post
Ahhhhh! I needed that fix. Amazing work Friz.
X2!! ......time for a smoke now.......
Balls and a Sawzall
Project Halfbreed
Porsche 944 L67V6 CARB Legal & Other Stuff
sparkydog is offline   Reply With Quote
Old 07-13-2010, 08:35 PM   #605
67ChevyRedneck
67ChevyRedneck's Avatar
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 07-14-2010, 01:02 AM   #606
Jvsapp
Jvsapp's Avatar
ff, what if you were to build a front under brace like these?
http://www.weaksauceparts.com/store/...7&cat=0&page=1
http://cgi.ebay.com/ebaymotors/ws/eB...5688&viewitem=
a couple of them. i'm sure you're plenty capable of making one
not a S2000, but gives you the idea
found a better pic
Jvsapp is offline   Reply With Quote
Old 07-14-2010, 04:29 AM   #607
Frizzle Fry
found a better pic
HG is talking about these upper arm mounts being a weak point:
As for cross bracing, I think I have plenty!
Old 07-14-2010, 04:42 AM   #608
Frizzle Fry
A little bit more, a little bit more...
Got the tires mounted on the front:
Welding/grinding:
flipped; you can see that they do have a slight asymmetry by design (one side has two bends and the other has one)
Lower still needs the shock mount added:
...and I finally tried out my powdercoat set-up. Worked out pretty well for a first try:
Old 07-14-2010, 05:55 AM   #609
Jvsapp
Jvsapp's Avatar
looks good FF. no doubt the subframe is stronger. as for your oven, i have one of those cheap liners on the bottom of mine for grease and what not. i once baked a set of wheels for my bro's welding cart and all the old grease from inside puked out onto the bottom of my oven. talk about a mess and at 400 degrees it makes alot of smoke and taints the parts. it keeps the bottom of mine clean, and i can see you have had some grease splatters.
BTW what powder you using? i pick mine up from columbiacoatings.com. though i've found a new place that might be a bit cheaper.
Old 07-14-2010, 12:27 PM   #610
Frizzle Fry
That was the first time I've personally used that oven ...was a freebe from craigslist and I didn't bother to clean it. It's smaller than I had expected so I figure it'll just get me by for now. Not a bad idea on the liner though.
My powder is from Caswell Plating. Next I might try some from eastwood since I get free shipping from them. What's your new source?
Old 07-14-2010, 03:43 PM   #611
Jvsapp
Jvsapp's Avatar
i find the powder from eastwood is picked up from columbia coatings. alot of the colors are the same, and have the same name even. just a little more expensive from eastwood.
here's the place i pick up from.
Columbia Coatings
i even bought their color books so i have an actual sample of the color before i buy it. shipping is USPS so it's not too bad even to here(hawaii). they even have a frequent buyers club so i'm hoping i will get free powder eventually. they also have monthy deals. like this month they have $2/lbs satin red. and free shipping on orders over $75.
the other place i'm looking at picking up is this one
Rosey's Powdercoating/
haven't ordered from them yet, but the color selection looks good.
i've used powder from Castwell plating, i like their metal cans.
i'm planning to build a bigger oven so i can do things like axle housings or 24" wheels. biggest thing i've done so far is 17" wheels. i'm guessing your subframe won't fit in your oven? i'm kinna like you. don't like subbing things out and would rather try to do it myself. get the pride from saying, yep i did that.
Old 07-14-2010, 04:16 PM   #612
67cheby
67cheby
67cheby's Avatar
Man you do clean work...unbelievable
67cheby is offline   Reply With Quote
Old 07-15-2010, 02:10 AM   #613
Frizzle Fry
Good info Jvsapp, and thanks 67!
Just a little teaser. Here it is with weight on the front DS tire (notice the floor jack). So this is roughly how it will sit in the front. Maybe a slightly lower with all liquids in it and after settling. Course, all that can change with adjustable coilovers
Old 07-15-2010, 04:37 AM   #614
Jvsapp
Jvsapp's Avatar
looks good FF. guess you just had to go get the tire mounted?
Old 07-15-2010, 09:39 AM   #615
Frizzle Fry
Tire was mounted in previous pics but the height was just an estimate. Now the lower shock mount is in place and holding up the car.
Old 07-15-2010, 09:49 AM   #616
67cheby
67cheby
67cheby's Avatar
man would i like to be in the passenger seat when you are setting at a stop light next to a civic with no exhaust and a four foot tall wing on the back....... and leave him setting there gawking with his mouth open !!! i didnt even mention how perfect those wheels look on your car, man your taste is dead on
Old 07-15-2010, 09:00 PM   #617
Frizzle Fry
that's the plan... Funny thing about the wheels; I hated them on the Burb/Tahoe. But I do agree that they work really well on this car. Glad I still had them ...they were nearly sold at one point
Old 07-16-2010, 03:59 AM   #618
Jvsapp
Jvsapp's Avatar
oops i was thinking of the post from 7/12. i agree the wheels are spot on. so nice..... can't wait to see some video of it
Old 07-16-2010, 06:06 AM   #619
watahyahknow
watahyahknow's Avatar
im wondering if you can just lay some aluminium foil on the bottom of that oven thats simple to put in an pull out
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 07-16-2010, 01:52 PM   #620
Jvsapp
Jvsapp's Avatar
you can but after enough cycles it becomes super brittle. the liners are cheap like $1 for a pair and are thicker than foil. they also give a nicer reflective finish. also the liners have a lip incase you get some grease spillage from inside a wheel barrow wheel say it will pool onto the liner instead of run all over the foil and onto your oven bottom.
Old 07-16-2010, 02:08 PM   #621
smbrouss70
smbrouss70's Avatar
That looks good, but do you have enough room for that tire to turn and still have some compression left for when you get into the twisties?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 07-16-2010, 03:16 PM   #622
67ChevyRedneck
I've honestly been wondering the same thing, but I can't believe that FF hasn't cycled the steering, etc before final welding, so it must not scrub?
Jesse James
Project "On a Dime"
Old 07-16-2010, 10:05 PM   #623
Frizzle Fry
Yes I've cycled it. It is tight! But it will work. We have the technology... Can't go any shorter on the upper arm and I'm at the max BS on those wheels. I will likely do a little fender rolling. Worste case scenario I'll go to smaller tires. Here's another look at the sitch at hand:
Old 07-17-2010, 05:09 AM   #624
dammitmitchell
the pollock
dammitmitchell's Avatar
anyway you can ever do a "how to" on cleaning your welds so nicely?
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 07-18-2010, 02:04 AM   #625
Frizzle Fry
You mean the ones that are ground smooth? Mostly 4.5" flap disc followed by about 100grit on a DA. Other weapons of choice are used where access is limited such as porting drums or 2" discs on a die grinder. Still need to try the 7" maroon scotchbright Nate uses for final clean.
