Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 03-09-2012, 06:21 PM   #601
kev2809
low n' slo
kev2809's Avatar
Re: Project 67 DRGNWGN - 67 Burban!!
well..actually the firewall was thinned with paint thinner...the interior was with mineral spirits. i like how the interior turned out compared to the firewall...
another member suggested mineral spirits as the thinner because the finish comes out much better, so i gave it a shot. also..i havent noticed any "craters" with using the mineral spirits. ill post some pics of my column tonight...i used the same exact process as the interior.
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 03-09-2012, 06:29 PM   #602
lyrikz
PITbut
lyrikz's Avatar
So instead of a reducer you are using mineral spirits? Does that save money cause i know reducer isnt cheap. That red looked AWESOME.
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 03-09-2012, 07:41 PM   #603
kev2809
low n' slo
kev2809's Avatar
to be honest, i dont know why i never used reducer. i just started out using regular paint thinner that i use to clean my gun...wonder how much better it would be with reducer.
on a side note..anyone want to trade gear shifter lens? i ordered one from lmc and i guess i ordered the wrong one. top is the new one, bottom one is mine..
-_--_--_ _________
Old 03-09-2012, 07:46 PM   #604
lyrikz
PITbut
lyrikz's Avatar
Im new to painting so i was just checking. Love the burb man.
and sold.
Old 03-09-2012, 09:32 PM   #605
kev2809
low n' slo
kev2809's Avatar
ya, i been following your build too hehe...ima try to paint this thing hopefully before summer, by myself....hope it goes well.
thanks for checkin out the build
-_--_--_ _________
Old 03-10-2012, 07:18 PM   #606
kev2809
low n' slo
kev2809's Avatar
got the column back in today...i was a little confused at where things went because i forgot how i took it apart lol.
for those at are following...i have question.
this bracket that goes on the column by the firewall, i noticed it has 2 holes in it, and the column itself has 2 "nipples" on it. i tried to line the bracket up with the nipples and tighten it up, but it make the column turned out of whack, like it wouldnt be straight. so i loosened it up, turned the column to be straight in the middle, and tightened up the collar. is this right? its the collar on the left, you can see the small nipple right next to the bracket support, the other nipple is under the raised portion of that bracket.
pic of the column from the inside..
-_--_--_ _________
Old 04-04-2012, 10:38 PM   #607
kev2809
low n' slo
kev2809's Avatar
actually made some progress in the last month....i got the steering wheel painted along with the glove box door, put in a new '72 booster and master cylinder...and......
finally, finally got the motor and trans dropped in tonight ! got the motor mounts tightened up fully, just need to finish tightening the trans bolts tomorrow and slip the driveshaft back in. i did manage to strip my intake bolt hole while adjusting the motor, im hoping i can just thread a grade 8 bolt in there and let it catch..the other 3 are good. will get some pics up tomorrow, snapped some tonight but they arent very good.
-_--_--_ _________
Old 04-05-2012, 01:08 PM   #608
truckzilla
truckzilla's Avatar
Subscribed! Love them ol' three door 'burbs!
truckzilla is offline   Reply With Quote
Old 04-05-2012, 09:19 PM   #609
kev2809
low n' slo
kev2809's Avatar
thanks!
heres some pics of the motor and trans dropped in, and the new booster/mc..
-_--_--_ _________
Old 04-05-2012, 09:29 PM   #610
VA72C10
VA72C10
VA72C10's Avatar
Looks really good!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 04-05-2012, 10:46 PM   #611
Southcity
Southcity's Avatar
Great burb and build thread - subscribed
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 04-17-2012, 10:14 PM   #612
kev2809
low n' slo
kev2809's Avatar
Originally Posted by VA72C10 View Post
Looks really good!
thanks fellas!
i scuffed and painted my core support and battery tray over the weekend, that way i can get it perm. bolted down and figure out my wiring (no pics) also cleaned and painted my gauge bezel, painted the needles, and hand polished the lens. not brand new, but a hell of a lot better than before. just have to repin the original plug (going from idiot guages), figure out my wiring the cluster and then put it in. also reset my odometer to 0's..
-_--_--_ _________
Old 05-11-2012, 12:39 AM   #613
Slick67
Sofa King Crazy!!
Slick67's Avatar
Makin some good progress there Kevin! Those gauges came out really clean looking. Tip: that new master cylinder and booster will look old and rusty real quick so make sure you clear coat the h3ll out of it so it stays nice and shiney for a looong time!!!
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 05-11-2012, 01:41 AM   #614
VA72C10
VA72C10
VA72C10's Avatar
Nice work on the cluster!
Old 05-11-2012, 05:58 AM   #615
kev2809
low n' slo
kev2809's Avatar
thanks!
thanks!
you think rattle can clear would work? i left it raw because i hear the brake fluid will eat the paint right off as soon as it touches
-_--_--_ _________
Old 05-11-2012, 11:30 AM   #616
Southcity
Southcity's Avatar
you think rattle can clear would work? i left it raw because i hear the brake fluid will eat the paint right off as soon as it touches[/QUOTE]
Another option is to use Duplicolor caliper paint, the kit that applies with the brush is easiest to apply with the cylinder/booster already mounted. Stands up real well to fluid, heat, etc.
Old 05-11-2012, 11:31 AM   #617
Southcity
Southcity's Avatar
oh btw - nice work and progress lately
Old 05-11-2012, 04:27 PM   #618
Slick67
Sofa King Crazy!!
Slick67's Avatar
Yeah rattle works fine, it isn't as thick as the caliper paint but holds up pretty good, and is cheap and easy to reapply when needed. Not much brake fluid is gonna get on it anyway just make sure you cover it with a plastic bag and a towel when filling! It will keep that cool raw look for a long time. My alternator still looks great!
Old 05-14-2012, 03:18 PM   #619
kev2809
low n' slo
kev2809's Avatar
good idea, i already noticed some flash rust on the mc lid...
well, im hoping i did this dash right. the only thing i didnt do was change the bulbs but i can do that with the gauge still in. got the headlight switch, wiper switch, and choke cable back in along with the dash...
i havent hooked up the trans linkage to the shifter yet, but is that the reason why the turn signal base spins some when i turn them on? like the shifter housing moves...im thinking once i get the shifter linkage connected to the rod to the trans it wont do this? or did i not tighten something up right in the steering column?
on a side note..scored a nice set of 2001 suburban front and middle row seats off craigslist...for $75!
-_--_--_ _________
Old 05-14-2012, 03:22 PM   #620
aric70chev
aric70chev's Avatar
Those seats r gonna look badass
aric70chev is offline   Reply With Quote
Old 05-14-2012, 03:23 PM   #621
Bennett68C10
Bennett68C10's Avatar
Wow nice score on the seats
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 05-14-2012, 05:48 PM   #622
Slick67
Sofa King Crazy!!
Slick67's Avatar
Hey Kev, didn't quite follow on your question about the turn signal spinning on the column. The seats are freakin awesome! Sale em for a nice profit and get some old school bus bench seats for it!!!
Old 05-14-2012, 06:04 PM   #623
kev2809
low n' slo
kev2809's Avatar
^^ lol
well i would have thrown the originals back in but my friend ran over them with his 4x4, thinking they were in the scrap pile....
about the column, the metal case that the shifter housing is bolted to, with the turn signal inside...when i put the blinker down, the case moves down a little, when i put it back up the case moves along with it. in turn, its also "moving the gear selection" on the indicator (from N to R, or from N to D1, etc..), even though its not actually shifting gears...if that makes any sense....
im not sure if there is something inside the column that keeps it stationary..or if its the part on the column under the hood that bolts to the transmission shifter linkage..that keeps it stationary
this thing...
-_--_--_ _________
Old 05-14-2012, 11:14 PM   #624
Slick67
Sofa King Crazy!!
Slick67's Avatar
That's an odd ball problem.....kinda like "my buddy ran over my seats thinking they were in the scrap heap" problem. I am not sure if the turn signal cam would have anything to do with this, but I doubt it. The shift indicator should move freely, but down at the base where the turn signal is I don't think it should. Maybe test it by taping the column so it won't move like it is hooked to linkage. Is everything tight on the column outside the firewall?
Old 05-14-2012, 11:40 PM   #625
mcbassin
Still Learning
mcbassin's Avatar
Lots of good progress here since I checked in last. Keep at it Kevin!
mcbassin is offline   Reply With Quote
