Closed Thread
Old 01-07-2010, 05:08 PM   #601
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: What did you do to your truck today?
I pulled the carb off my truck to sell. And I was going to pull the gears out of the rear end to trade.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline
Old 01-07-2010, 05:10 PM   #602
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
I shoveled out the garage door backed the truck out and then picked my way around town to avoid the wet/salty parts of the road went down picked up some flooring and took the trash out
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline
Old 01-07-2010, 08:06 PM   #603
markeb01
Senior Enthusiast
markeb01's Avatar
Received new trailing arm bushings today. Got the garage cleaned up ready for another project. Think I'll probably wait a bit before tearing it apart though, not too crazy about working on it when the ambient is 24 and the garage is 42 degrees.
markeb01 is offline
Old 01-08-2010, 10:38 PM   #604
sams60gmc
sams60gmc's Avatar
I got my bags in the mail today
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline
Old 01-08-2010, 11:56 PM   #605
ravens65
ravens65's Avatar
awesome- front and rear ? next truck I build will be bagged w/ custom frame , how much do you think a whole air system will set me back? Eric
If it has tits or wheels its gonna give you problems!!!
ravens65 is offline
Old 01-08-2010, 11:58 PM   #606
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
i changed carbs but i gotta change em back
p.o.s. holleys
back to the good old q-jets and that crappy adapter i have to use haha
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline
Old 01-09-2010, 12:26 AM   #607
198plus
198plus's Avatar
You need to learn how to tune the Holleys
p.o.s. holleys
198plus is offline
Old 01-09-2010, 12:57 AM   #608
midnite
midnite's Avatar
finished my bucket seats building my sub box and comsole and got it all installed
sorry for bad pics
the sub box goes across behind the seats
midnite is offline
Old 01-09-2010, 01:15 AM   #609
SCOTI
SCOTI's Avatar
I've been trying to get things done on my project 64 but feel as if I'm getting no where fast..... So, today I decided my task would be to make lists of items needed to be done (hey, if it helps get it done, it counts right? ).
I organized the tasks into groups & I'm going to try & use the list like 'assignments' to complete each week. I thought maybe sharing the list might help my motivation even more:
Rolling Chassis I need to....
Get the gas tank 'fill' piping determined & routed DONE
Finish my upper rear shock mounts DONE
Determine rear bumper bracket placement
Finalize bed floor mounting (switching to steel floor & raising @ the same time)DONE
Finish machining my truck-arm spacersDONE
Make rear bag hats to install the bagsDONE
Get the tranny x-member mounted
Determine exhaust routingDONE
Paint/powder-coat the frame, x-members, cab mounts, & various brackets
Route fuel lines
Route brake lines
Route air lines
Mount air tanks & compressors
Purchase rear wheels DONE
Purchase rear tires DONE
Purchase shocks DONE
Drivetrain
Repaint the motor (different 'theme' warrants a different color)
Paint the tranny
Mount the accessories (already got them powder-coated and/or detailed)
Mount radiator
Mount electric fan
Wire fans & headlight relays
Re-wire for internal alternator (hi-amp conversion)
Mount brake assembly (vac booster/master cyl, & firewall adapter bracket)
Mount trans cooler
Interior
Clean/scrub cab interior
Install high-hump trans tunnel cover
Install sound/heat insulation
Remove 'cassette' style radio for delete plate
R&R manual column for van auto tilt
Remove clutch pedal
Purchase carpet & install
Mount seat (already re-covered)
Route air-lines from controller to tanks/bags
R&R front windshield
R&R dash cluster from 'lights' to analog gauges
And finally, my list for this week....
Set the steel floor in place to finalize my fuel fill routing planned for Sunday.... DONE
Finish fitting my fabricated upper shock plates to the shock x-member DONE
Trim the PB dropped truck arm Panhard bar bracket DONE I finished this before cutting the shock x-member c-sections
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is offline
Old 01-09-2010, 01:56 AM   #610
LILRED66
LILRED66's Avatar
Nada...with the temps below zero and a foot of snow on the ground, my "get up and go has got up and went". May the sun return soon and the snow melt away.
LILRED66 is offline
Old 01-09-2010, 01:59 AM   #611
midnite
midnite's Avatar
i wish, lots of snow here, but its been -25c for the past week before the windchill....
midnite is offline
Old 01-09-2010, 02:32 AM   #612
sams60gmc
sams60gmc's Avatar
I just got the rear. I paid 100 for both. They are Air-Lift 2600's. I'm not too sure how much a whole set up will be. I have access to most of the stuff. Air tank, lines, fittings etc. plus I built everything. But I'll have to buy a compressor and some solonoids. In Street Trucks the company Airbaggit has some pretty sweet kits that seem like pretty good deals. If I was to estemate it I would guess around 1500??
Old 01-09-2010, 11:57 AM   #613
SCOTI
SCOTI's Avatar
Try AVS, SD, or Ride Tech before you use these kats. Airbagit.com is AIM/Chassis Tech which is a company known for it's issues. Buyer beware....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
SCOTI is offline
Old 01-09-2010, 03:16 PM   #614
sams60gmc
sams60gmc's Avatar
Or you could just build your own kit and pay a whole lot less and end up with something to be proud of. I've only bought the poly bushings, bags and a bag of bolts.
Old 01-09-2010, 03:46 PM   #615
SCOTI
SCOTI's Avatar
I wasn't being specific about using a 'kit'. I just know guys have had issue w/that company (AIM, aka Chassis Tech, airbagit.com, etc...).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
SCOTI is offline
Old 01-09-2010, 03:58 PM   #616
62gmc910
62gmc910's Avatar
Hey SCOTI I think we have Stella's almost identical twin
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline
Old 01-09-2010, 04:03 PM   #617
sams60gmc
sams60gmc's Avatar
I hear ya bro. I'm just kindof a tight wad when it comes to money lol. I work as a machinest so I know what it takes to build most of the stuff. altho i do love the kits offered by airride.
Old 01-09-2010, 05:19 PM   #618
Rusteeze64GB
hooked up my voltage regulator today, Also wired up a gas guage that is not work right and a voltage guage. Looks like I have some trouble shooting to do. I was going to bleed my brakes but, that is going to have to wait a week. After the brakes, the bed is going to come off and I am going to start cleaning and painting. Then I am gonna take a coil off the front and remove a few leafs in the back. I will try and get some pictures up soon.
Rusteeze64GB is offline
Old 01-09-2010, 10:06 PM   #619
zythen
Cut a quarter of my bed off with a hacksaw,sounds stupid but I rent the garage and it has no electricity. Note that my bed is 3/8 diamond plate so clean cuts really don't matter to me, I'm just scrapping the bed anyway. Pulled the wiring, cut the rusty exhaust off, moved the extra block and heads to the engine stand, drained some of the coolant, took the hood hinges off to be cleaned and painted, knocked some rust and dried mud out of the frame and off of the rear suspension and cleaned up the rest of my crap laying around.
I forgot to take pictures of it but my frame looks like it was cut off with an air chisel.
zythen is offline
Old 01-09-2010, 10:18 PM   #620
62 Bowtie
62 Bowtie's Avatar
Wired up my amp sounds great then took it for a spin. Man it felt good I havent drivin it for about a month, I was starting to get the shakes jumpped on the freeway and nailed it bookin along gettin the thumbs up I am so happy with how it runs, whew I need to calm down now .... later, Tony
62 Bowtie is offline
Old 01-09-2010, 11:03 PM   #621
monolith
Zero Albedo
monolith's Avatar
Commuted the last 2 days to work in the 64 without a hitch or a worry.
50 mi each way- this thing starts, handles, runs better than the 66 which is getting tired out.
Baz
"Deserve's got nothin' to do with it."
66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467
65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432
65 Chevy Panel (former U.S.Navy truck)
64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348
64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now)
68 Dodge Charger
monolith is offline
Old 01-09-2010, 11:25 PM   #622
DWright
Shlong Bed Club
DWright's Avatar
Finished painting my freshly built 400hp/450tq 350. Planning on towing my truck to work Monday to install the '79 crossmember and then the engine and camaro t5. busy busy busy...
DWright is offline
Old 01-09-2010, 11:37 PM   #623
198plus
198plus's Avatar
Getting tired of trying to get bed adjusted..........Cannot git rid of this problem, how much is to much for shims. To get tailgate to close on this top side I have to shim the other back side of bed up 3/8 inch and then bed doesn't set level..........Help any suggestions.......
198plus is offline
Old 01-10-2010, 12:19 AM   #624
Vernski
[quote=198plus;3721244]Getting tired of trying to get bed adjusted..........Cannot git rid of this problem, how much is to much for shims. To get tailgate to close on this top side I have to shim the other back side of bed up 3/8 inch and then bed doesn't set level..........Help any suggestions.......
It looks like the tail gate may be tweaked, I guess you could tweak it back but not sure of how to do it. Maybe someone knows the procedure out there.Body
guys?? Vernski
Vernski is offline
Old 01-10-2010, 12:40 AM   #625
198plus
198plus's Avatar
I've tried tweaking it back........I really don't think it is the tail gate ?????
[quote=Vernski;3721354]
guys?? Vernski
198plus is offline
Closed Thread
