#601 | |
Re: my '64 c-10 swb project with steel floor from a '70
yes alan, I just drilled two holes so I can mount them in the back set of holes thanks don for the comment, and thanks for email those pictures from clems get together, then one with my family with the fire pit was awesome, really captured the flames and made them stand out
my project: http://67-72chevytrucks.com/vboard/s...d.php?t=456163 |
#602 |
Chad you achieved your goal! You wanted the motor to have the "Wow factor" You got it! Every time I stop by to check up on you I always scroll back to see what I've missed and I see that motor...Dang, is that thing sweet! I always liked the look of the shotgun scoop and your mix of colors just looks killer. I too am anxiously awaiting the day she comes to life.Keep on keepin on and you'll get there!
Nice EASY project, no problem....until I get home ![]() |
#603 |
this what I did today, my hydro boost lines!
#604 |
Very Clean...
DON Proverbs 27:17 ![]() US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
#605 |
thanks don, the hoses might be clean but the frame is dirty, lol! I need to give it a bath!
#606 |
i'm debating on stripping the hood tomorrow or doing raptor liner in the bed, this next weekend will be to cold to do any painting or the raptor liner! the bed floor needs a lil work before doing the bed liner! looks like someone just throw stuff in the back and dented it up! we will see, I might just strip the hood and start fixing dents in the bed floor
#607 |
got most of the hood stripped down to bare metal then sprayed etching primer on it, I got a small section left to do! I also got the grille support panel stripped and sprayed with etching primer! lil by lil, but progress is progress!!
looks like rain here next weekend not sure what i'll get done if it rains! I wanted to spray the raptor liner in the bed, but I found a few dents in the hood that needed to be fixed! so I didn't get around to doing the bed this weekend heres some pics for ya!! everything that green has been stripped down and coated with green etching primer
#608 |
looking good man!! you are getting pretty close
![]() bagged 66 longbed build http://67-72chevytrucks.com/vboard/s...d.php?t=449548 my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918 |
#609 |
as far as the motor goes I need: spark plugs, thermostat, oil and filter, antifreeze, battery, fuel filter! just to hear it run without the wiring harness in it, yet!! i'm hoping by the end of the month I will hear it run
#610 |
Gotta agree with Coulter, Looking forward to seeing you and your truck at Clem's next go 'round!!!
#611 |
That engine looks bad a$$ !
#612 |
yep..wont be long now
my 65 fleetside build http://67-72chevytrucks.com/vboard/s...d.php?t=442370 big back glass conversion http://67-72chevytrucks.com/vboard/s...dow+conversion |
#613 |
thanks fisher, I was going for a wow factor with the motor, another wow factor when be the all steel cowl inducted hood, also hope to do a front tilt hood!!
that's jeff, we will see! I got spark plugs and wires in the truck, thermostat is in the truck, edelbrock fuel filter can in today so ill get that done this next weekend! so now its down to oil and oil filter, antifreeze and a few wires!! we will see what the weather will be like this next weekend!
#614 |
Ready to Roar!
#615 |
Sounds like your real close can't wait to hear it hope run hope it sounds as good as it looks
My frame Layin 63 short bed project ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=551353 |
#616 | |
thanks don, one step at a time!
while not much to report, I did install the edelbrock fuel filter and cut my braided hose for it! had enough fittings left over from the hydro boost kit, i'll have enough braided hose left to do my transmission hoses! since its getting cold, I'm changing my pace! I have two tailgates one will be to fix the other, since that's all its good for! really bad pitted and rust thru! but anyways I got one patch done, welded in grinded down, looks good! then I go to take pictures and the battery is died! the tailgate is like a weather project/ practice, I figure if I cant fix the tailgate then I cant fix my doors, but it looks good so we will see! i'll get some picture this thanksgiving weekend since it looks like its going to be in the 50-60 then and not 30-40 like it is now!! anyways heres the fuel filter and braided hose installed!
#617 |
just wanted to tell you all have a save happy thanksgiving!
#618 |
Post Whore
![]() Join Date: Mar 2013
Same to ya! And nice going on the truck! Looks awesome!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#619 |
well, guys haven't done much lately! been spending time with the family, cause of the holidays and such! ive been playing around with two extra tailgates I have to make one good one! but I been thinking if I can do the tailgate them I know I can to the doors, if I cant do the tailgate someone else will have to do my doors! I started one patch and have the rest marked out, the top edge has a few dents, the inside above the chevy script is bent in in a few places, few dents on the outside! so I started to cut up a extra tailgate I cut out all the good metal that I will use, I'm getting a pieces of 16gauge from my buddy to fill in where the chevy script is, mine is bowed out! so im hoping when done with this lil project my tailgate will look like a plain new tailgate, atleast that's the plan! in the forth pic is the patch I welded on from the red donor tailgate there was a BIG dent was there, looked like a 12lb. sledgehammer at full swing dent, lol!! red donor tailgate has a lot of rust through, not easy to fix like the other one is!!
It's been cold here and that's another reason I haven't done much, plus with planning to move in two months, I'm having to try to get everything lined out for that too!! anyways enough with the sidetracking, on to the pics!
#620 |
the motor is still not running yet, been sidetracked and along with this crazy weather, it got put on hold for a lil bit
#621 | |
![]() Join Date: Oct 2009
if you want help on the doors maybe i can get them done. anyway... have a great holiday and keep plugging away. |
#622 |
Wow! I thought I had too many irons in the fire...
![]() Keep rockin Chad... you are making good progress... ![]()
#623 |
Tailgate body work is a good challenge. You can do it.
So this move in two months. Garage? Shop? |
#624 |
I have a keen eye turned to this tailgate project of yours.
I have one coming up soon too.... ![]()
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
#625 | ||||
merry Christmas and happy new year to all my cyber brothers!!
