01-08-2014, 01:04 PM | #601 |
Re: Project Goldilocks, '66 C10 SWB BBW Build
Picked up a pair of CPP modular spindles from Boris (way2low) at Street Machinery. I can't find upper A-arm shafts that are dropped 1/2"; need those so I can start mocking up the A arms. Might have to have some made, or drop the mounting point itself. Gotta get ball joints too.
Also picked up a pair of NOS inside door handles. Repops won't stay on the stem.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
01-08-2014, 11:21 PM | #602 |
man this is such a cool build!
1960 short bed fleetside factory 4x4 1960 panel 454 NV4500 Daily driver 1961 Short Bed BBW Fleetside 5.3 th400 swap in process |
01-16-2014, 04:24 PM | #603 |
Artist
So where are we at with this story? Ill got get some popcorn.... ready for an update.
66 Chevy C10 283ci~cough~ SBW Fleet Buttercup '66 |
01-16-2014, 06:26 PM | #604 | |
Thanks!!
It's new in the wrapper still, never opened. Will REALLY set the truck apart once it's noticed. And it's a full set of FIVE. Not just four. ALL FIVE!!! Seriously though, I've sent an email to Hotchkis asking if they sell offset upper A-arm shafts. Haven't been able to find them anywhere else that will bolt straight to the factory crossmember. They come with their upper A-arms; hopefully they'll sell them separately. They'll help with camber gain, along with taller upper ball joints. That's about it.
01-16-2014, 06:52 PM | #605 |
Email from Hotchkis... no luck on the shafts. Looks like I'll be making my own.
01-16-2014, 07:30 PM | #606 |
have you called porterbuilt? They seem to be willing to buils specific items. Might be worth a call.
check out SANFORD build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522019 |
01-16-2014, 07:45 PM | #607 |
Haven't checked with PB. I do have a local machine/fab shop that would be up to the task, just picked up a pair of widened wheels from him yesterday.
01-16-2014, 08:47 PM | #608 |
I thought Moog offered 'offset' shafts in their 'Problem Solver' line of parts?
01-16-2014, 09:00 PM | #609 |
Yes, but offset inward/outward depending on how you install them. I'm looking for .5" dropped pivot points.
01-16-2014, 09:58 PM | #610 |
Ahh.... Gulstand mod vs for camber adjustment.
01-16-2014, 11:48 PM | #611 |
Yep! I think that those, along with taller C20 ball joints will get me in about the same range of camber gain as the available aftermarket IFS kits.
01-17-2014, 09:25 AM | #612 |
Artist
Clever thinking!
02-03-2014, 11:08 PM | #613 |
Started planning the lower A-arm's layout on the shop floor. Need to figure out my ride height and tire size next so I can figure out how deep the air bag mount needs to be for it to be in it's proper range, and then I can figure out ball joint cup angles. The bag mount will actually be about 1/2" or 3/4" below normal so I can eventually use 1/8" aluminum plate spacers under the bag to fine tune the bag height/pressure at ride height. I'm probably going to swap to smaller bags since the D2600's are pretty tall at their minimum ride height (6"). I'd like for the rockers to be about 5" off the ground at ride height, and it'll be pushing it to get the D2600's to ride that low without collapsing them too much.
Also figured out how much the upper and lower ball joint needs to be moved forward to center the wheel in the fender opening, with 4 degrees more castor than stock (ending up around 7*). I wanted to push the wheel forward an inch, so the bottom ball joint has to go forward 1 3/8 and the top ball joint only moves forward 5/8". I'm pulling the ball joints inward 1" for more fender clearance with wider wheels; planning on running 18x10" or 20x10" up front with atleast 275 tread width. Shortening the arms 1" will also help with camber gain a little. On to the CAD drawings... (Concrete And Dirt).
02-03-2014, 11:49 PM | #614 |
You'd better hope the floor doesn't move.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
02-04-2014, 12:06 AM | #615 |
I got it taped in place!
02-04-2014, 08:26 PM | #616 |
Looks like the x are wining in tic tac toe
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
02-04-2014, 11:54 PM | #617 |
Very cool!
With all of the improvements and the dimensional changes you have in mind, those are going to be a trick set of control arms. Do you plan to modify an existing lower control arm, or do you plan to build a custom one? I'm thinking that you'll build a new design, probably out of steel plate. That's what I would do. I have a buddy who builds ultra trick ($$) high end off road race vehicles, and he builds all of his own control arms and beams. Absolute works of art. I was over at his shop a while back and snapped a picture of some stuff he had just finished welding. "Just a couple of simple brackets and and some limiter strap tabs", he said. I love fab work, and I'm really excited to see what you're going to come up with.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
02-05-2014, 12:09 AM | #618 | |
02-05-2014, 10:15 AM | #619 | ||
Still Learning
02-05-2014, 12:53 PM | #620 |
Mike's a pretty young guy (27 yrs old), but he's been welding since he was a teenager. Back when the Harley chopper scene was blowing up 10 years ago, he was getting his TIG training welding frames for Daytec, who also made frames for Atlas, Big Dog, and others. He always did mini trucks on the side, but moved on to hot rods and off-road stuff because he could show off his fabrication skills. As far as his secret, it's pretty basic. Use fresh, new clean metal whenever you can. I'm not sure what rods he likes to use, but he welds with a Miller Syncrowave, using a Miller torch head (water cooled, of course). I've been around lots of guys who Tig, and I like to watch their techniques. Some guys will light the arc and maintain a consistent foot pressure. Mike is constantly on and off the pedal, hitting it on every bead, like you do when you Tig weld aluminum. He gets in a good rhythm, and it shows in his bead spacing.
He's been doing a lot of double weave Tig'ing lately, I should get some pictures. Unreal. here's his Facebook: https://www.facebook.com/pages/Exile...64332900248369
02-14-2014, 06:41 PM | #621 |
02-14-2014, 10:38 PM | #622 |
Feel some excellent fabrication in the making.
02-14-2014, 11:02 PM | #623 |
I wish, might be awhile before I get back on the A-arms.
02-16-2014, 12:15 AM | #624 |
Subscribed
64 C10 Stepside 350/4psd Driver/Project on air. Dom bags, Dual Viair and AccuAir 08 Ford F150 Limited- F-word ! Daily Driver .......................____ ..........._______l/ \____ ...........|_/(0)\_ll____/(0)_l. |
02-19-2014, 12:45 AM | #625 |
Ordered Cyro treated and slotted Stoptech's from Tire Rack but there's a 3-4 week wait before they'll be in stock. I like the look of slotted and drilled but drilled rotors will crack if they're used hard so that wouldn't work. OEM Caddy rotors were the same price but they have to be replaced every pad change, wasn't too thrilled about that. Stoptech has matching rear rotors available, and they should be more durable than oem parts. Also have to get the hubs fitted with 1/2" wheel studs and probably open up the rotors to fit the bigger studs too. Nothing on the front brakes are going to be out of the box parts at this point.
I hate that I'm not making any progress with the A-arms but I have been researching master cylinder bore sizes vs caliper piston area, pedal ratio, and pedal pressure vs pedal travel. I don't want a soft pedal; I can't stand getting in newer cars that stop with pedal travel instead of pedal pressure. Theres no pedal feel or feedback that way. I'll need to heel-toe downshift so a floppy/soft pedal won't let me keep steady pressure on the brakes while tipping the gas pedal with the same foot. Lots to consider to get it balanced front to back with a firm pedal but enough leverage with the bore size and pedal ratio to fully lock up the brakes without needing body-builder legs. I'm thinking that a good place to start is to measure how much pedal effort (in pounds) I'm comfortable with and see how much line pressure the calipers need to function properly. Been looking into Wilwood hanging pedal assemblies with triple master cylinders and an adjustable brake bias bar to tune the front/rear balance. Might be a tight fit to get it all under the dash.
