#601 |
VA72C10
![]() Join Date: Mar 2008
Re: Rebuild on a shoestring.....continued
I'll be working with the painter. Shooting for around two weeks
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#602 |
Gotta tell you that Im really amazed at the challenges you East Coast Guys go through dealing with rust and corrosion issues. Im thinking im pretty lucky with the projects I have tackled here on the West Coast. Looks like your project is really moving along and I cant wait to see the Paint on it. Your right you cant go wrong with red... Your doing a great job and I look forward to more pics of it..
JRBECK64 |
#603 |
VA72C10
Thanks! Got a good amount done this afternoon/evening. Got the old 2 into 1 exhaust off. It was held on with wire in a few spots and used the corrugated style pipe in the rear....planning true duals on this one...
Then I cleaned up the firewall a bit by removing some extra wiring some PO had installed and started removing things to prep for paint. Then I started cleaning the engine bay and front clip. I chiseled off the dirt off the upper a-arms and scraped off years of dirt/grease. As I've found in the past all that dirt/grease is a good thing as it seems to protect the parts beneath....the rubber boots look good on the ball joints/tie rods and the brake lines look like new after power washing. The power wash was the second step. Then some more scraping and power washing. After blowing off the water then letting it dry I sprayed gunk engine cleaner and am letting that sit overnight. Will power wash one final time tomorrow morning and possibly paint in the evening if the weather holds and it dries out...
#604 |
VA72C10
Pics from today
Where I started then after chiseling. After power washing and overall just before spraying with gunk. Posted via Mobile Device
#605 |
VA72C10
One thing I did which will end up being a good solution is I unbolted the steering box without removing it entirely... I am going to convert to power steering...but at this point since it's going to paint I am going to simply spray the frame with the steering box loose...then will bolt it back up for the trip to the body shop and to make it easier to move around the body shop. Keeping the stock wheel/column in also since I don't care if that gets overspray on it. That way once the paint is finished I can install the new column and wheel and the power steering gearbox all at once...
#606 |
If you can find this stuff is a wonder cleaner it will actually melt off any rattle can paint slightly corrosive but man does it clean. It will save you a lot of time and no oils left over like Gunk. On line they say Home Depot sells it.
94 k2500 EXCab Long Bed 350ci New Toy 95 K2500 Suburban New PlowTruck 454ci Support our Troops @ http://anyairman.com http://www.woundedwarriorproject.org/ |
#607 |
GEARHEAD
Glad to see something happening with this one. Good luck.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#608 |
VA72C10
Thanks guys. The gunk worked pretty well and seems to have washed off with the pressure washer. Still had some areas I found since I did the last spraying at night. And of course the suspension is all together. If this was a show truck it would come completely apart but the steering components are good on this so it will be painted together (mostly). Busy day but did the final power wash then some more scraping, wire wheeling, and then got the great idea to remove the sway bar. Man I need a large compressor in my garage. Hand tools stink
![]() Posted via Mobile Device
#609 |
VA72C10
Picked up the intake gaskets today and have a fuel pump. Also got my pulleys and brackets (ordered a blasted and painted set from livrat and will sell my setup later. Have to save time when I can and at 100 shipped for the pulley and bracket setup complete I couldn't pass it up. Here is the only pic from the evening. Doesn't look like much but once primered and painted it will look nice!
Posted via Mobile Device Posted via Mobile Device
#610 |
VA72C10
I wish I had a closeup of the spindles and arms. It's an amazing difference. It's satisfying work but dirty
![]() ![]() Posted via Mobile Device
#611 |
can't wait to see it painted! I like to say when I'm going to do things so that I actually feel obligated to do them
#612 | |
VA72C10
![]() That's another good reason to put things on here...to have guys motivate me to get them done or give me options if something I plan doesn't make sense...
#613 | |
#614 |
GEARHEAD
I can't believe you don't have an air compressor yet. It is a must have for anyone doing this much work on trucks. A typical 60 gallon single stage 2 cylinder compressor does not cost that much and will do pretty much anything you need for a home shop. Its what I have and I can sandblast with a little patience and it will provide plenty of air for any of my tools. Fathers Day is coming up, lots of sales.
#615 |
buy the little better airtools , i skimped on mine and got thin airline to boot , the airchissel gut out totally after 30 minutes of use and the airwrench doesnt have the torq needed
i need to buy better or get one of those nifty batterypowered ones
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#616 |
67cheby
![]() Join Date: Sep 2008
frame looks CLEAN !
#617 |
![]() Join Date: Oct 2011
I'm starting to catch up on your build (too). Your frame looks great, looks like a lot of work. I still have to do mine. Keep up the good work!!
Wade ![]() , JUST WALK AWAY, AND I'LL SPARE YOUR LIVES!!! , Build thread "TANGERINE" http://67-72chevytrucks.com/vboard/s...d.php?t=498570 Board Members Met: bigblock68, ol_skool_chevy ,68TT,atvpro |
#618 | ||
VA72C10
![]() Thanks. Posted via Mobile Device
#619 | |
VA72C10
But since this truck has new drum brakes and the original suspension components are in good shape and I'm not lowering it...there is no need to tear it apart and risk tearing ball joint boots/etc. It will look nice when done and make a great driver/weekend cruiser for the next owner. Posted via Mobile Device
#620 |
VA72C10
The next truck I will build once this one is done is starting from a bare swb frame. Hoing to be able to afford to blast that frame although it is a lot cleaner than this one is already. The front suspension is all new and has been coated in por15 so a coat of paint on that and the trailing arms and I will be bolting together a clean frame. Definitely the way to go!
#621 |
Good job on the frame clean up, I will be knee deep in that goo pretty soon as well. Nice to see some progress again on this.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
#622 |
Pressure washing all that gook off is nasty, a cheep rain suit comes in real handy especially if you are going to do the under side. Here is my before and after with POR 15 & top coated with Rustolem Semi Gloss or satin don't remember which but it came out pretty good
#623 |
looks like new
#624 | |
VA72C10
#625 |
![]() Join Date: Jan 2011
Looking good buddy ! I need to clean up the GMC like that when the bed comes off.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
