03-14-2013, 07:51 PM | #601 | |
Re: 1972 Chevy p/u NewType Build
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
03-14-2013, 08:38 PM | #602 |
I got a bunch from work to start with and I'm about to go in the garage and start making a mess. The gunk is a little tacky so well see how it rough if not ill lay more and hold for another day.
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903 Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
03-14-2013, 08:55 PM | #603 | |
03-15-2013, 02:04 AM | #604 |
Well got down to sanding tonight so here's the progress and product I'm using
I started by using my triangular file's pointed end to dig out the designed grooves for the grip itself and was quite impressed how easily this task was as you can see most of the original look is back already with just one round of that. then I moved onto sanding the next 2 1/2 hours ( Note to self spread epoxy thinly next time ). Used 80 grit to knock down just about everything I'll soften the grit as I go through my phases. I felt pretty at home doing all of this I've watched my dad so long when he's done projects that I guess I got some of his talent finally . Finally I layed down some more epoxy to fill in the cracks on the backside of the grip and pretty much did every valley but they should turn out well. So far I'm very happy with the results of the filler and it's got me looking forward to finishing the sanding quickly so I can lay some paint down more tomorrow Also does anybody know what this little symbol is on the backside? is it just a part of the wheel maker's mark or is it special? I havent covered it yet I probably wont
03-15-2013, 02:12 AM | #605 |
Proprietor of Dale's Corner
hey bud, if you get discouraged let me know. I will help, I know I am a ways away but on weekend I dont mind helping
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
03-15-2013, 02:40 AM | #606 |
Oh no discouragement here my friend I'm enjoying this project here I figured out when I restored my fathers Tonka truck that I get engrossed in the fun of a small restoration like this Steering wheel. But hey you need that truck on the road man lt me know I may be driving around alot farther when I get the new Mo-mo in my truck
03-15-2013, 07:21 AM | #607 |
C/10 junkie
Looking good Dylan. Just in time for next weekend
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
03-15-2013, 10:20 AM | #608 | |
03-19-2013, 02:15 AM | #609 |
uh-oh first coat of primer lets see how this goes
03-19-2013, 02:31 AM | #610 |
The Steering wheel looks excellent man wonderful job on it
1971 GMC Sierra 1959 GMC 100 |
03-19-2013, 10:03 AM | #611 |
C/10 junkie
Looks good Dylan. Hey what's with the tires on the fridge?
03-19-2013, 10:15 AM | #612 |
It's full of light beer and those keep it from floating away
03-19-2013, 10:16 AM | #613 |
Thank you I'm ready to see how it turns out tonight after I let it sit and dry up
And Shawn that my only good spare tire no wheel from the p.o. A custom spoke wheel/tire for my softtail and some dirtbike paddle tires Posted via Mobile Device
03-19-2013, 10:19 AM | #614 |
Dylan, I think you should paint it blue again and that way it will look good in Blue
03-19-2013, 10:30 AM | #615 | |
03-19-2013, 10:50 AM | #616 |
No problem, I will have to lower it though. The first low rider 4x4
03-19-2013, 05:39 PM | #617 |
I'm down for that build
03-19-2013, 05:57 PM | #618 |
Whole new meaning to rock climbing
03-19-2013, 10:06 PM | #619 |
C/10 junkie
More like rock scrape'n
03-19-2013, 11:07 PM | #620 |
yeah, and I thought the light pole made it ugly
03-19-2013, 11:44 PM | #621 |
How do you feel in the holes around the Wheel ?
03-20-2013, 08:36 AM | #622 |
What kind of primer are you using on that wheel?
1968 LWB C20 / AC / Wood Bed |
03-20-2013, 10:14 AM | #623 |
The product is above its called Pc-7 two step process once mixed together like bondo it binds together and can be used to fill a lot of different products apparently. Ill et you guys all know how well it worked once this wheel is in use. Can't really get a good gauge on it right yet
crakarjax What kind of primer are you using on that wheel? Currently just rustoleum which I'm kinda curious if its the paint that semi cracks, if its just the cracks in the wheel trying to be filled, or the weather messing it up. Posted via Mobile Device
03-20-2013, 10:58 AM | #624 |
Thanks man, I'll use that on my 59's Steering Wheel
03-20-2013, 11:01 AM | #625 |
Be sure to light coat through out the week when you do rustoleum has a tendency to crack if the coat is too wet. Which I believe is the issue I'm having. But I'm being rushed for this so that's why. Thanks for checking the progress out.
Tags |
1972 chevy c10, cheyenne super, rebuild, restoration, showtruck |
