Old 09-17-2015, 07:45 PM   #601
blue57
blue57's Avatar
Re: My Blue 1957 build
Originally Posted by Dan in Pasadena View Post
Whew, spent the evening re-reading the entire thread again. I'm truly impressed, truly inspired, thanks.
Can you give us a few references? Contact info for the electrician that wired it up?
When you posted the photos of the AC lines inside the fender I kinda thought you were planning to do that. I've been planning to run mine in there since I saw a guy do it years ago but now I'm wondering if there's a reason I shouldn't? I planned on welding elevator bolts onto the inner fender, then I realized I can just use longer stainless button head bolts where the inner & outer fender join along the top so I can use some kind of strap/loop. I DO get that road debris could damage the lines so that's a consideration. Anything other reason I've not considered?
Any chance you used Elegance Auto Interiors in Ontario? The work looks like some of theirs I've seen and everything of theirs is beootiful! Congrats on a GREAT truck. Can't wait to watch your Dad's come together.
PS: I forgot to ask about the TCI rear leaf kit. I've been planning on flipping my rearend on top of the stock leafs and C notching. But I'd truly rather NOT notch it if the TCI kit will lower it enough all by itself. I know their leaves are parabolic and supposedly smoother riding. Any more info? Mine would be with a Chevy 10 bolt.
A buddy of mine wired it up. If you want his info shoot me a PM and i can send it to you.
The picture of the lines on the inner fender were on another truck. Those have actually been completely redone in polished stainless lines. My dad has his lines run down the inside of his inner fender. Not sure if you can run a loop and have the bundle of four lines hanging there. However i did use longer bolts on the drivers side and clamped the electrical up to them so its tucked away. I would think it would be more secure being clamped to a strap or tab welded to the fender.
As far as the interior, I was referred to a guy that has worked from a couple of the big name shops and still does interior work as a fulltime job, but takes on projects on the side out of his home.
The TCI leaf kit i have isnt the same kit they sell now. There new kit is only a 2 leaf pack i believe and mine was originally there 4 leak pack so i wouldnt be able to help you out on that one.
my build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=522711
blue57 is offline   Reply With Quote
Old 09-17-2015, 09:00 PM   #602
Dan in Pasadena
Dan in Pasadena's Avatar
Thank so much for the response. I will drop you a PM and my rewire is probably a year off as I don't expect my truck out of body & paint til near December.
I'll call TCI and see what they quote about the amount of drop from their old kit versus their new kit, but thanks for making that clear.
If you think the interior guy is available I'll ask you for his info in the PM too.
Good call on the AC lines. I'll go back to my elevator bolts welded to the inner fender about every 12-18".
I forgot to ask you: do you recall how much you modified your wheel base when you installed your IFS? I keep reading anywhere between 3/4" to almost 2". Right now I'm thinking about 1" or maybe 1-1/4"
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 09-17-2015, 09:13 PM   #603
blue57
blue57's Avatar
i didnt alter from the instructions. i placed it where the instructions said to
my build thread:
Old 09-17-2015, 09:43 PM   #604
dsraven
on the rear leaf kit, the springs only position the axle, the amount of drop before a notch is determined by how much space you have between the axle tubes and the frame when it is at the ride height you want. you must leave some room for when you hit a bump or the axle will hit the frame. then it depends on what you have for spring rates or if you have air bags etc. not good for your teeth/spine/truck if you bottom out. look around and see if there is a "look" you like, then contact that owner and see what the space is on his/her truck. also if it bottoms out on the frame if they have no c notch. you could always fab up some heavy duty rubber suspension snubbers from a later model vehicle so they help out with the bottoming factor but in the end, if it is low and no c notch you may bottom out anyway.
Old 09-17-2015, 11:40 PM   #605
Dan in Pasadena
Originally Posted by dsraven View Post
...contact that owner...
I did. It's "blue57".
That's why I'm asking him about his TCI kit and he has no frame notch on his truck - which I'd prefer if I can do it and get his stance.
I also like Ogre's stance and his setup is very nearly like mine, a Fatman IFS kit but he flipped his rear axle on top of his leafs and had to notch. I'm setup to do that but when I noticed blue57 HADNT notched and I wanted to ask him about it. Since TCI's kit has changed I'll have to get a read from them on the lowering effect their new kit provides and if they recommend the installation without a frame notch still.
Old 09-18-2015, 02:07 AM   #606
dsraven
I think if you read through ogre's stuff he says he does bottom at times. or contact him.
Old 09-18-2015, 09:20 AM   #607
Hblee
Hblee's Avatar
I just bought a Heidt's crossmember and their instructions don't mention moving it forward either. The instructions also don't mention the need to have 1.5 degrees of tilt to help with anti-dive but the videos I've watched of the MII installs always mentions the 1.5 degree angle.
Don't pay no mind to that whirrin' sound, she uses a little oil but outsida that she's cherry.
Hblee is offline   Reply With Quote
Old 09-18-2015, 01:27 PM   #608
blue57
blue57's Avatar
I didnt notch mine, but i dont plan on hauling stuff in the bed and i try to avoid crappy roads. I have hit a few bumps in the road and it has hit the bump stops a couple times.
my build thread:
Old 09-18-2015, 09:09 PM   #609
Dan in Pasadena
Ok, so you're saying it MIGHT bottom out on rougher roads. I don't have any intention of carrying loads either. The most would be a couple folding chairs and an ice cooler for a show. I'll see what TCI says but sounds like a mild notch is likely necessary. Thanks guys.
Old 09-19-2015, 01:16 AM   #610
dsraven
Hey, after all that work, what is a little notch.
Old 09-20-2015, 03:18 PM   #611
blue57
blue57's Avatar
dont feel like cutting through fresh powder coating and moving fuel lines just yet. Thats why.......
my build thread:
Old 09-21-2015, 01:04 PM   #612
ptc
ptc's Avatar
Sometimes its like ... STOP THE INSANITY OF BUILDING PROCESS!!!!
and enjoy .....
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 02-18-2016, 11:51 PM   #613
blue57
blue57's Avatar
Man, its been awhile since i have been on here. Working out a few bugs before hitting the shows and cruising again. Just about have dads 58 done. His should be going to interior shop here soon, then its just a few little things. Should have it 100% by fathers day weekend for the Pismo show. Then in July we will both be at the brothers truck show.
my build thread:
Old 06-05-2016, 08:40 PM   #614
blue57
blue57's Avatar
Went to a show yesterday. First show out with both trucks. Just finished up dads 58 last week.
my build thread:
Old 06-05-2016, 11:15 PM   #615
oldman3
oldman3's Avatar
Very nice...Jim
oldman3 is offline   Reply With Quote
Old 06-06-2016, 08:15 AM   #616
Kim57
Kim57's Avatar
They look great.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 06-06-2016, 10:06 PM   #617
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
A great pair!
ChuckDriver is offline   Reply With Quote
Old 06-07-2016, 04:50 PM   #618
RockinKees
RockinKees's Avatar
Yes, those are beautiful!!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 06-07-2016, 05:23 PM   #619
dug224
dug224's Avatar
Wow! dug
dug224 is offline   Reply With Quote
Old 06-08-2016, 03:39 AM   #620
VDOG
Grand PooBaa Member
VDOG's Avatar
Very nice
VDOG is offline   Reply With Quote
Old 06-08-2016, 10:24 PM   #621
youngrodder
youngrodder's Avatar
They look great together...
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 07-10-2016, 09:22 PM   #622
blue57
blue57's Avatar
Great day at the brothers truck show. Dad won best paint in his 58 and i won best in class.
my build thread:
Old 07-10-2016, 09:27 PM   #623
ChuckDriver
Awesome, congrats!!
Old 07-10-2016, 11:28 PM   #624
oldman3
oldman3's Avatar
Congrats to both of you...Jim
Old 07-11-2016, 10:17 AM   #625
Kim57
Kim57's Avatar
Congrats.
Kim
My build thread
