07-21-2016, 06:29 AM | #601 |
Re: Knomadd '71 SWB C-10
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
07-21-2016, 08:13 AM | #602 | |
Still Learning
07-21-2016, 08:52 AM | #603 |
Brandon Instagram: DRVFSTR Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691 |
07-21-2016, 11:58 AM | #604 |
Daaang!
- Robbie UNITED BY TRUCKS - classic truck video content YouTube: www.youtube.com/c/unitedbytrucks Instagram: @united_by_trucks Paw Paw '68 508 Dark Blue Custom C10 Teddy '68 GMC SWB 503 Light Green LS Build Mississippi Mud '75 Skyline Blue Patina SBC Build |
07-21-2016, 02:51 PM | #605 | |
Just sayin, (read my 68 SC motor swap) The VHX gauges work great with these motors. Would recommend you get the Bim 01-2 OBDII module. I will allow you to display tranny temp, IAT, gear pattern, and a host of other things. You can have who ever builds your harness to pull the data wire so you don't have to connect it to your OBDII port. Have fun! and let me know if you have any questions.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-21-2016, 04:54 PM | #606 |
A guy with a truck
Dude. Sweet.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
07-21-2016, 09:35 PM | #607 | ||
I'll go ahead with the stock motor as-is, for now. I was on the fence, but after your statement, I'm completely on solid ground. I had no idea the trans would be so hard to tune. Glad you pointed that out though. I'll look into the BIM 01-2. I've read up on it before and liked the abilities it has, but didn't want to plug it into the port and lose the gauges when I'm plugging in a reader or something. I have a friend close by who recently did a Gen V 5.3 L83 and he did his own wiring with the help of another member. He said I could do it myself, so I think I'll try it. Any idea where I can find the wiring pinout for this setup? Maybe some pointers and an idea of what wire you're referring to for the data wire? I'm sure I'll have a lot more questions, but I'll start with your 68 thread. Followed it since late 2012, but I could definitely use a refresher.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
07-22-2016, 11:45 AM | #608 |
It's just the data line that feeds the OBDII port. Check this website out: http://lt1swap.com/geniv_harness.htm
LS1Tech.com is good also.
07-27-2016, 09:12 AM | #609 | |
I got notice this morning that the engine and transmission made it to a Houston facility. Hopefully that means it will be here today! *fingers crossed*
07-27-2016, 01:57 PM | #610 |
Rincon |
07-27-2016, 03:22 PM | #611 |
When you get it tuned they can delete afm/dod from ecm so it will stay in 8cyl mode at all times.
07-27-2016, 04:10 PM | #612 |
Still Learning
I used LT1swap.com for my wiring diagram too. He also has reflashed my PCMs. I think he charges like $80.
Brendan is very helpful when you have a question too. |
07-27-2016, 09:17 PM | #613 |
heck yeah dude! lets blow it apart!!!!!
c10clubtexas |
07-28-2016, 11:14 AM | #614 | ||
Soon.... Soon. I do have some bad news to go along with it. FedEx Freight shipped the drivetrain and wouldn't you know it... DAMAGE!!! The harness is pinched (at least one severed wire), intake is broken/cracked, 2 coils are broken, and plug wires. Several harness plugs are broken, including one for the ecm (the blue J1 plug), all 4 O2 sensors are damaged and they mangled the dipstick/fill tubes... not that I was planning on using them, but dam! Notice the two plug wires hanging in front of the manifold? Yeah, broken... This is the worst O2 sensor, but all are bent and 2 more have exposed copper wires The worst coil, but the 2nd has the harness plug broken out of it, with part still in the coil Pieces of the intake fell off... check the fins, they are all supposed to be straight and vertical. The broken J1 plug. I have contacted the seller and they are going to put in a claim and refund me the cost of the damage. Hopefully FedEx will cover legitimate costs and not just what they think it's worth. Although, I can't expect the seller to eat the cost of shipping damage, I hope they all make this good.
07-28-2016, 11:17 AM | #615 |
more pics of the damage...
The trans tail shaft seal was damaged, and there was wood particles inside... sorry for the blurry pic, didn't notice it until today.
07-29-2016, 09:19 AM | #616 |
crap that sucks. hopefully we can find the connectors without too much trouble.
c10clubtexas |
07-29-2016, 09:28 AM | #617 |
The seller is trying to find a value for the damaged parts so I can get a partial refund for the damaged cost. They are also looking for a harness to just replace the one I have. Hopefully they have better luck than I do. Called the local Chevy dealership and talked to the parts department with the VIN and was told they had two different part numbers, but couldn't get a price. Neither of those part numbers matched up with what my harness has on it.
I would just replace it, but Speartech is one of the only places I can find that does wiring for the 6L90 transmission with the engine harness. And I can't tell without calling them first if they would even do it for this new of a computer. Regardless, their harness is $950 without any add ons..... that's a bit too rich for my blood. I emailed Brendan at LT1swap.com and he replied and told me he has no info for the E78 ECM, and does not do any programming on them either. Looks like that's a dead end for me. Hopefully GM didn't do a lot of changing on their wire colors from one ECM to the other. I think I'll see if I can trace the wires and start my own pinout. We'll see if I can do it. I'm not an electrical engineer, or even a fan of wiring, so this is going to be a BIG challenge. If anyone knows another company that makes swap harnesses, let me know. I'll look them up and see if they can provide me with a new harness for this swap.
07-29-2016, 09:29 AM | #618 |
Man, I really hope they make that right for you. That'll be a sweet set-up once you get it all straightened out.
07-30-2016, 08:27 PM | #619 |
Ugh...they must have piled other packages on it.
Check BP, PSI, Howell for harness options. |
07-31-2016, 10:41 AM | #620 |
Thanks for the suggestions Doug, I've already put out requests for Speartech and Howell, but I've just added BP and PSI. Hopefully one of them is able to do this with the new ECM.
08-05-2016, 10:26 AM | #621 |
So a little update...
Speartech and PSI both told me they do not support the E78 ECM. PSI said they suggest buying their harness and an E38 ECM to work with their harness. BP never got back to me, nor did Howell. I shall be trying to practice thinning out my junk harness before I get the replacement, so I know what needs to be kept and what can to go. I did get confirmation from the seller that they have already acquired all the broken parts and will be shipping them to me, except the harness. They have put in a special order with GM to have a harness pulled from the assembly line. No idea how they have that kind of pull, but that will be awesome! Hopefully it works out. No ETA on that yet though.
08-05-2016, 10:39 AM | #622 |
Here's the engine, somewhat stripped getting ready for paint.
Check out how clean the intake runner & back of valves are!!!
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) Last edited by knomadd; 07-14-2017 at 10:03 AM. |
08-05-2016, 10:42 AM | #623 |
And here it is in all the Chevy Orange glory!
I will be painting the crank pulley and all the accessories semi-gloss black. The crank pulley has already started to rust a bit, so it needed painting anyway. Don't mind the overspray.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) Last edited by knomadd; 07-14-2017 at 10:04 AM. |
08-05-2016, 03:10 PM | #624 |
Awesome motor.
Great job on da paint
Rincon |
08-05-2016, 04:22 PM | #625 |
Still Learning
Looks great Duane! I saw a guy on Instagram that makes harnesses, I think he's @modernvintagesystems
