09-18-2014, 02:47 PM | #601 |
Re: Porterbuilt Dropmember
On the ground
Chad 1967 Chevy C10 "Project DV8ED" 1994 Nissan 300zx convertible 2004 Chevy 2500HD crew cab 4x4 |
09-18-2014, 02:51 PM | #602 |
Nate... I bought and installed the Cpp nodular 2" drop spindles but they didn't need reamed out. The DOM joint dropped right in. I'm guessing the smaller diameter of the conical hole is a little over what is required. If I tighten this up nice and tight it should be ok, right?
09-18-2014, 03:55 PM | #603 | |
Thanks! Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
09-18-2014, 05:59 PM | #604 |
Email sent.
01-03-2015, 06:03 PM | #605 |
Curious to see what the outcome of the cpp spindles was? Planning on ordering my extreme dropmember this week and will be running the modular spindles. Thanks
01-05-2015, 10:27 AM | #606 | |
Nate
01-05-2015, 10:48 AM | #607 | |
Same situation I ran into. You're going to have to bore it larger and then use a sleeve.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-05-2015, 12:34 PM | #608 |
Thanks for the reply Nate. Looking forward to running a dropmember on my truck.
01-05-2015, 08:02 PM | #609 |
A320 Pilot/USAF Retired
Just measured my CPP Nodular 63-70 spindles after reading through this. Got the coil-over Dropmember for my 57.
Mine measured at the large end at .600, the small end at .510. The bolt supplied by Nate measured .620, so the spindle will need to be very slightly enlarged and should be a nice tight fit!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
01-08-2015, 03:58 PM | #610 | |
"Also wanted to be able to go back to old posts and find your contact info easily".
"Life is too short to drive a boring vehicle". Later, Wayne |
01-21-2015, 07:46 PM | #611 |
Sofa King Crazy!!
Nate,
If you need a Southern rolling billboard, I'm your Huckleberry!!! Ordering my full PB settup tomorrow from Pro P!!! Excited!!! David
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" |
01-21-2015, 10:26 PM | #612 |
67-72 parts collector,…
For all you truck and Dropmember fans,... DelmoSpeed.com is up and running.
http://www.delmospeed.com
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-21-2015 at 10:33 PM. |
01-22-2015, 02:02 PM | #613 | |
Jake
61 Ford uni http://67-72chevytrucks.com/vboard/s...d.php?t=623422 ryans 77 c10 http://67-72chevytrucks.com/vboard/s...d.php?t=626594 |
01-22-2015, 08:39 PM | #614 |
The new website it cool. Guess I'm going to have to buy a new t-shirt.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
02-27-2015, 01:26 AM | #615 |
02-27-2015, 06:56 AM | #616 |
Very nice ^^^
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
02-28-2015, 12:26 PM | #617 |
Wow that's going to look killer.
LIFTED OR LOW THE ONLY WAY TO GO!!!! Check out my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=517346 Projects 56 Chevy pickup Porterbuilt FR/RR dropmembers |
02-28-2015, 04:46 PM | #618 |
I like that a lot!!
03-09-2015, 11:10 PM | #619 |
I am following this Thread. I am leaning towards Porterbuilt for my 72 Blazer.
JLO 1972 Blazer 2WD 1986 Chevy Silverado (Black) 1986 Chevy Silverado (Blue) |
04-16-2015, 02:00 PM | #620 |
I'm waiting on my dropmember to be delivered but was curious as to if the front DM help the turning radius. I'm putting one on my 77 C30 and need all the help I can get to get this big boy turning...
Long live SLIM ------------------ At least try to buy American |
04-16-2015, 03:47 PM | #621 |
Sofa King Crazy!!
Been waiting for awhile for my PB stuff. Got the email last night that it shipped.
vEstimated Arrival:Apr 20, 2015
04-16-2015, 03:58 PM | #622 |
My '57 front and rear version is supposed to be done today. Considering my truck is completely torn down, at least this will be progress when installed on the frame. I should be able to test it out in a year or so.
04-16-2015, 04:28 PM | #623 |
Congrats to you both!!!!
04-16-2015, 05:41 PM | #624 |
Thanks, I'm doing frame up, so it will be a while or more than a while before it will be done. Have to start somewhere, and the Porterbuilt stuff was the logical starting point. I've go things budgeted out for the next year at least. I bought the truck with no bed, and it turns out the previous owner decided to use the front clip from a '55 or'56. I thought it was just the grill and hood that was different. Turns out the only parts that compatible are the inner fenders and core support. That's going to set me back a ways. Turns out the only parts we are using will be the cab and frame.
Anyone close to Northern Arizona need a nice front clip for a '55 or '56? |
04-21-2015, 02:54 AM | #625 |
