#601 |
![]() Join Date: Jul 2012
Re: Loadmaster '47 COE
Like a Superbird wing on the back of the flatbed?
#602 |
![]() ![]() Join Date: Jul 2002
Don't know about the wing. Sounds neat. Do it. If you don't like it there is always the cutoff wheels.
#603 |
So, no love on the wing idea huh? well I guess I will just use it for a rear filler panels. I started by adding an extension to the rear lip of the fender, was able to get 2 from 1 trailer fender. The sheet steal was bent at a local shop. I will also redo the tail lights using 3 per side, 2 for tail and stop and 1 per side for reverse lights. Still a bit of test fitting and adjustments to be made. A WING....REALLY?
Rob ![]() ![]() ![]() ![]() ![]()
My '47 C.O.E build |
#604 |
what is the name for great things that get better? well this is it. hey quick question, what are these rims again? wheel vintique's or us rim? I'm brewing in my head putting my 63' on a Silverado for a daily year round truck. want to keep it looking proper with the rim and tire selection.
side note, sup with the cagarettes, natty ice, eggs and a diet coke!!!
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#605 |
Loadmaster, Those three tail lights on each side of your bed are just beggin for a sequential turn signal indicator. I wired a system on my son in laws 52 F1. Worked out great. Just thought you might like to know. Great work keep on keepin on. NC
Been there, wrecked that ![]() |
#606 |
Hey 99, they are Wheel Vintiques 8 X 16 with 4"BS. I did need to file on the front calipers just a bit for clearance and cut the taper deeper for the larger lug nuts. The late model Silverado uses 14mm studs and the wheels are drilled for 1/2 inch. Interesting idea on the tail lights Nut Case, I'll give that some thought.
Rob
#607 |
LMAO....superbird coe. Good stuff.
Man, that's lookin good Rob. Those finishing touches really make a difference. I'm gonna have to do a wheel well of some sort just to keep road grime at a minimum under there myself. Chance
SHAKE N BAKE BABY, SHAKE N BAKE.... http://67-72chevytrucks.com/vboard/s...d.php?t=686729 |
#608 |
Hey rob nice touch on the fender extensions. Too bad they were not there when mudd was flying lol
#609 |
That looks great, nice touch.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#610 |
So I'm working on the tail lights. I will be running 3 lights per side. Which way would you go, reverse light in the center or to the inside? These are standard trailer lights I picked up from a local truck stop. Simple, cheap and effective.
Rob ![]() ![]()
#611 |
Reverse light in the middle looks more balanced.
#612 |
Reverse light to the middle of truck.
#613 |
#614 |
Like your first pic. Towards center of truck.
#615 |
reverse lights in the middle
#616 |
![]() Join Date: Jan 2006
Reverse lights to the inside. Don't particularly like having the reverse lights mixed in with stop/turn lights. Just a thought! As an added note...really like what you've done with this build. I always thought the COEs were the neatest trucks. Not sure why I haven't gotten around to building one!
don "The DRBMan" 2014 Audi A4 (The Wife's Daily Driver) 2017 HD Ultra (The Cruiser) 2003 HD Fatboy (The Ride) 2001 Chevy Suburban (Another back up!!) For the first time in forever, not a single 67-72 Chevy truck, Blazer, or Suburban on the property! Basically retired and getting the new Motorhome ready for some traveling. Doing a bit of work on the house getting it ready to sell! LOL!! Last edited by dhaymaker; 02-20-2016 at 02:01 PM. Reason: More thoughts! |
#617 |
I finished the tail panels for the most part. It gives the truck a bit more of a finished look at the rear. I still need to build some filler panels for the area in front of the rear tires and I may do some type of a rear bumper below the rear panel. Strength is not the issue as there is a bit of steel behind the rear panel, if I do the bumper it will just be for looks or a step style bumper.
#618 |
I like it !!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
#619 |
That came out really nice.
#620 |
Very nice. The taper toward the rear looks good.
#621 |
![]() Join Date: Aug 2012
47-
What is that in the background of the 1st pic?!? Do you have a tree stump made up to look like a turkey or peacock? Awesome! |
#622 |
That would be a peacock made from an old propane tank for the body, a curled Toyota gas tank for a neck, hub cap face and a bunch of old golf clubs for a tail. It's mounted on an old tree stump. It was a gift for the wife when I had no COE to work on.
Rob
#623 |
Looks great Rob. I like the bed the way it is, personally think a bumper of any kind would not look as good as it does now.
#624 |
Rear turned out real nice.
#625 |
47 Fast this project has killer personality, creatively uzzing muscule, and tude. Do you have past livily stories, cause I can see some high schoolers delivery hot tubs and get in some rear trouble. Any way you are having fun and living the life, don't ever stop. Thanks Nut Case
