Old 10-13-2017, 08:08 PM   #601
broda1
broda1's Avatar
Re: What did you do to your Blazer/Jimmy today?
Originally Posted by SoCoC10 View Post
Thanks.
Finished the interior today. Next week I'll be focusing on the outside, installing trim and engine bay detailing.
It's beautiful! The orange plaid in the white is a perfect match.
broda1 is offline   Reply With Quote
Old 10-17-2017, 11:24 PM   #602
SoCoC10
SoCoC10's Avatar
Thanks for the feedback guys. Exterior work in high gear now. Door handles, locks, mirrors and trim going on.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 10-20-2017, 03:10 PM   #603
briank
I tackled (but not finished) patching my hardtop that the original owner decided to put a sunroof in. I could not locate a top and decided to fix the original. I have attached a before shot and then a shot of the outside top and an inside shot. The pain job is temporary as Ill probably paint the entire thing next year. This was a bear to fix as the inside has lines in it and the front header to deal with. A little more filler and sanding inside then some quick paint.
briank is offline   Reply With Quote
Old 10-21-2017, 10:27 AM   #604
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Nice work guys!
Old 10-21-2017, 01:35 PM   #605
briank
And heres an after. I got the white paint from napa....its a rocker paint and comes out textured...doesnt look too bad. It will work unitl I restore the whole top. Cannot ev3n tell there was a sunroof now.
Old 10-28-2017, 08:21 AM   #606
SoCoC10
SoCoC10's Avatar
Awesome job. Can not tell you how many tops I've seen with holes cut in them; Why?
Old 10-28-2017, 08:26 AM   #607
SoCoC10
SoCoC10's Avatar
Just a couple teaser pics. I'll post engine/engine compartment before and after in a few days.
Old 10-28-2017, 09:16 AM   #608
dirish
dirish's Avatar
That is "top" notch work, hah I said top
Anyway looks great!
dirish is offline   Reply With Quote
Old 10-28-2017, 09:22 PM   #609
A1971Blazer
A1971Blazer's Avatar
Not mine but my buddies had a leaky pinion seal and a "clunking" noise....
replaced the seal and found where some PO had once been in the carrier and hadn't shimmed the carrier bearings correctly...
it had about .020 side to side play......
fixed it all and replaced the u-joints....and since he's an electrician....we pulled some wire and put up some lights in my addition....
rained all day, but we had a successful day...!
Discovered it was a a limited slip
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 11-01-2017, 10:32 PM   #610
SoCoC10
SoCoC10's Avatar
Got it all back together today, started right up and got the engine to operating temperature. This is the last picture before the fan, radiator, core support etc. covered up the front area. I had the upper alternator bracket in the wrong place that's fixed now. Also I've got to move the water pump bolt/stud to the correct location on the waterpump(thanks Pete!). Glad I put water in it as I found a pin hole in the upper radiator hose too.
Old 11-02-2017, 09:11 PM   #611
SoCoC10
SoCoC10's Avatar
Leaking upper radiator hose fixed,freshly painted air cleaner assembly.
Old 11-06-2017, 10:33 AM   #612
SoCoC10
SoCoC10's Avatar
First drive...
Old 11-06-2017, 05:03 PM   #613
3757chevy
3757chevy's Avatar
NICE looks good.
'67 Stepside (bought 1997-sold 2021-partially bought back 2024) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 11-06-2017, 05:27 PM   #614
BLT-NT-BOT
Started to put the dash back together.
BLT-NT-BOT is offline   Reply With Quote
Old 11-07-2017, 11:48 AM   #615
1972 Jimmy
1972 Jimmy's Avatar
First drive...
Why are you selling it???
1972 Jimmy is offline   Reply With Quote
Old 11-18-2017, 11:49 PM   #616
3757chevy
3757chevy's Avatar
I can think of 44,999 reasons.
MIKE
Old 11-19-2017, 09:38 PM   #617
1972 Jimmy
1972 Jimmy's Avatar
I would have to agree!!!
Old 11-20-2017, 12:26 PM   #618
BLT-NT-BOT
Installed 4 inch lift and 33 inch tires over the weekend.
Old 11-26-2017, 11:15 PM   #619
Green Monster
Green Monster's Avatar
3rd brake light installed under the tailgate handle. Light purchased from Custom Dynamics.
Green Monster is offline   Reply With Quote
Old 11-26-2017, 11:25 PM   #620
Green Monster
Replaced the head unit today. JVC KD-AVX44 replaces Kenwood EZ500.
Old 11-26-2017, 11:27 PM   #621
3757chevy
3757chevy's Avatar
Nice looks good, I put one of those 60" strips under my tailgate with brake b/u light and turn signals.
MIKE
Old 11-27-2017, 06:06 PM   #622
Moreyel
Moreyel's Avatar
Finally got my 72 interior apart and ready to replace rusty floor boards, kick panels, rockers and most of where so many rot.
Bought a 72 P/U cab & chassis with good parts and cut the floor out.
I know many of you don't agree with ruining a good truck cab, but at 5K to fill my list of aftermarket parts, I decided to do it this way. Beside, it's fun.
Any advice from those of you that did this, is appreciated.
I'm sorry if the pics came out upside down, I'll see what I can do.
72 Blazer, 70 El Camino SS, Anniversary HD FatBoy, 2020 Ram 2500, 80 Vette, 65 Chevy 3/4 Ton 4 W/D Pickup and some more.
Wife: 06 GMC Duramax 3500 4WD Single Wheel
Next: Rust removal on my Blazer.
Thinking of putting a 50 Chevy cab on a 76 Chev 4 WD pickup.
Members Met: Aldtime, DeadheadNM
Moreyel is offline   Reply With Quote
Old 11-27-2017, 10:56 PM   #623
socalfyrengineer
Finished restoring 15x8 Steelers from M1009 and polishing and painted hubcaps on my all original numbers matching 72 k5 blazer!
socalfyrengineer is offline   Reply With Quote
Old 11-28-2017, 10:50 PM   #624
Moreyel
Moreyel's Avatar
Brian, nice job. Where'd you find the matching material?
Old 11-29-2017, 05:10 PM   #625
briank
I used a patch from a parts hardtop...smc resin and painted with a white rocker panel molding paint from Napa that sprays textured. Ill use a bedliner and paint the whole top.
