Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 11-07-2024, 08:47 PM   #601
HO455
Post Whore
HO455's Avatar
Re: Random pictures that you did not take.
My buddy sent me this photo he took with his new borescope. I thought it was really cool. Sort of like something you would see on the NASA web site.
RIP Bob Parks.
Old 11-07-2024, 11:03 PM   #602
Steeveedee
Who Changed This?
Steeveedee's Avatar
Ehh, what IS that?
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 11-08-2024, 09:20 AM   #603
HO455
Post Whore
HO455's Avatar
Whoops! The photo is of the inside of a catalytic convertor. The honeycomb platinum material appears to have failed and there are two balls of it bouncing around inside. The honeycomb in the back looks to be clogged with pieces that came off the balls. The car has no power. It idles and runs ok but will only do about 40 mph. We pretty sure it is due to a plugged exhaust at this point having seen this.
RIP Bob Parks.
Old 11-08-2024, 03:20 PM   #604
Boog
laying low
Boog's Avatar
I've posed the question before how long a cat is good for and it remains unanswered. I could see the pellet type cats maybe wearing out. My 91 truck has the original exhaust system on it other than the muffler. 33 years old now.
I have no idea if it's done anymore but I remember folks running a long drill bit or something up in the cats to break up the catalysts to open up the flow while maintaining the stock appearance outside. Today's honeycomb style cats might be difficult to do the same with?
An exhaust shop can insert a pressure sensor in the upstream o2 hole to measure the back pressure to help determine if there is a blockage down stream.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 11-08-2024, 04:46 PM   #605
HO455
Post Whore
HO455's Avatar
I'm no expert but I will share what I know.
If your getting the rotten egg smell out the exhaust that in a good indicator of a cat that is no longer working properly. Most newer cars will give you a code if it isn't working correctly. Hence the upper and lower O2 sensors.
The best test to see if it is working is an emissions test.
You can test to see if it is plugged yourself. Just drill a 1/8 inch hole between the engine and the cat and hook a 0 to 20 PSI pressure guage up to the hole. If it reads above 3 PSI the exhaust is clogged. You will need to rev the engine up to be sure it is not clogged.
If you get a high reading then drill a 2nd hole after the cat and test again. If the cat is clogged you will get a lower PSI. If the PSI doesn't drop then the plugged area is farther down the exhaust pipe.
After testing you can plug the hole(s) with a self-tapping sheet metal screw, tap the hole for a machine screw, or do a plug weld. If you weld it shut make sure your ground lead is attached to a clean area near the hole your welding closed.
RIP Bob Parks.
Old 12-10-2024, 12:57 PM   #606
70STOVEBOLT
70STOVEBOLT's Avatar
Originally Posted by Steeveedee View Post
That wagon must have had the warranty work (overheated because of a 2-row radiator, and AC in the California heat) done (new, larger radiator and an engine rebuild) and the people just wanted it gone. Those things were famous at my dealership, for overheating. I remember one with a blued converter, it got so hot. I'm amazed that it actually hadn't caught fire.
One of our customers had a '69 SS 427 Impala convertible. It was drop-dead gorgeous, but it was only 3 years old at the time. It had a light color interior (I think "parchment?") and was a color that I would call "amethyst". Man, that was a nice looking ride. I went and looked up paint colors from '69, and that color wasn't on the list. Probably special order.
Curiosity got the better of me, I went and looked for the color. Cadillac "Wisteria Firemist". A pic-
https://find-great-cars.ebizautos.co...-f9113052.html
That color was known as "evening orchid" in 1966, and was a rare color on an impala.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 12-10-2024, 01:20 PM   #607
70STOVEBOLT
Ooooh. That reminds me of a guy who loaded up his 1/2 ton pkup with logs. It snapped a rear axle shaft and turned upside down in the middle of the highway.
I used to work for a diesel parts/rebuild shop, and one of our vendors had an earlyl 90's Ford F350 dually diesel that they hauled Cummins 855 cylinder heads in. They weigh about 100 lbs each. They brought us 120 heads on that truck from Knoxville, TN, to Pierceton, IN, and took 120 cores back with them.
with the truck loaded the rear wheels looked like they had a lot of camber, lol.
That truck made that trip for at least a couple years.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 12-17-2024, 10:24 PM   #608
yuccales
yuccales's Avatar
Someone caught us at the cemetery Sunday doing Wreaths Across America. It was a great turnout to place the wreaths. We would do 14 then head back for more.
yuccales is offline   Reply With Quote
