#6276 |
![]() ![]() Join Date: Jul 2002
Re: Restoring Rusty
Yes it uses the grounds thru the turn signal/park lampo on the front. When 12V for park lights is run thru the brown wire, it goes back to the front lamp thru the blue, then to ground. When turn signal is on, the blue line becomes the alternating 12V feed, and interrupts the ground that was in the side marker blue feed (thus it blinks). Took me a while to figure out that the front was the ground, but still not sure if all the science behind it is set in my mind yet.
#6277 | |
Post Whore
![]() Join Date: Aug 2014
Re: Restoring Rusty
#6278 |
Moderator
![]() Join Date: Oct 2008
Re: Restoring Rusty
The side marker grounds through the signal lamp except when the signal lamp is powered.
Light Blue is LH Turn power Dark Blue is RH Turn power Brown is Parking lamp power The peanut bulbs in the side markers are connected from one of the blue wires to a brown wire. The 1157 bulb is the only one that's connected directly to a ground. It's behavior is more complex than I stated originally. The side marker and front turns alternate when the parking lamps are on. They operate in sync when they are off. The 168 peanut bulb in the side marker lamp actually has two hot leads when the turns and parking lamps are powered so it shuts off. When the turnsignal flasher is in the off part of its' cycle or just plain off there's a path to ground through the turnsignal filament so the side marker bulb lights. Slick way to get a single filament bulb and two wires to do the job of a two filament bulb with three wires.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 06-03-2020 at 05:42 PM. |
#6279 |
Post Whore
Re: Restoring Rusty
#6280 |
Post Whore
Re: Restoring Rusty
#6281 |
Post Whore
Re: Restoring Rusty
#6282 |
Moderator
Re: Restoring Rusty
194 168 are the same size glass envelope peanut bulb.
168 is actually higher wattage more light. I assumed that was the bulb in use in that socket. I'd have to look at a 73-86 CK bulb chart to be sure which one is used there.
And please let us know if and how your repairs were successful. |
#6283 |
![]() Join Date: Jun 2015
Re: Restoring Rusty
Well dang! The do alternate with the parking lights on. Whew, I thought I was losing it.
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
#6284 |
Re: Restoring Rusty
What's going on in Rusty's world?
#6285 |
Post Whore
Re: Restoring Rusty
ha ha thanks for checking up on the green machine, he's getting new shoes tomorrow!
#6286 |
Re: Restoring Rusty
I was wondering the same thing. Seems Busty is taking up all the spotlight lately.
1972 K10 1986 K30 crew cab dually 2002 Z06 2007 Escalade |
#6287 |
Post Whore
Re: Restoring Rusty
#6288 |
Re: Restoring Rusty
Twin turbo 496 stroker??
On a side note...how is the side of your house not black???
#6289 |
Post Whore
Re: Restoring Rusty
#6290 |
Re: Restoring Rusty
You have a full on fabrication shop on the side of your house yet the pavers and house look like there’s nothing to see there move along.
#6291 |
Re: Restoring Rusty
Oh and a paint booth!
#6292 |
Post Whore
Re: Restoring Rusty
ha ha you mean my single angle grinder, a hand drill, and a BFH? and I do vacuum about 1/8th of metal dust off the concrete once in a while and just got a pressure washer so may actually try and clean the patio
#6293 |
Re: Restoring Rusty
Don’t forget the tumbler.
I’m not sure which is more impressive - the fabrication or the clean up.
#6294 |
Post Whore
thanks mate, it's definitely not the welding
#6295 | |
Re: Restoring Rusty
That's going to be da' bomb! Can't wait to see it!
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
#6296 |
Post Whore
Re: Restoring Rusty
#6297 |
Post Whore
Re: Restoring Rusty
so we almost made it one year without a true LS related issue
however yesterday I replaced this little guy (pronounced: "expensive" $73) aka the fuel pressure regular the problem started right after I replaced that front driver side turn signal light bulb, so of course I went chasing electrical problem, ha ha the issue was that the truck went from starting on the very first try each and every time to never wanting to start on the first try but always 100% of the time simply starting on the second try after checking all my electrical connections (grounds, grounds, and more grounds, ha ha) checking every fuse and every relay, I really dreaded having to drop the fuel tank to replace my brand new Spectra fuel pump which everyone talks bad about yet it has been wonderful for me - so I said well the fuel pressure regulator is expensive but at least it's really easy to get to, ha ha |
#6298 |
Post Whore
Re: Restoring Rusty
Rusty took us kayakin' taday, ranned like a champ
#6299 |
Re: Restoring Rusty
That’s cool. Glad he’s finally able to get out and about.
Are you experiencing some weird gravitational issue?
#6300 |
Post Whore
Re: Restoring Rusty
