Closed Thread
Old 03-17-2018, 11:44 PM   #6451
69GMCCustom
69GMCCustom's Avatar
Re: What did you do to your truck today? Chapter II
Teardown on my suspension. Removal of original ball joints, tie tods, and the sway bar bushings were missing. Cant get the endcaps off the upper and lower control arm rod bushings tho. Grrr.
"I'm rooting for you, and remember, were all in this together." ~ RED GREEN
1970 Chevy Custom.
Last edited by 69GMCCustom; 03-18-2018 at 09:41 AM. Reason: Picture was upside down
69GMCCustom is offline
Old 03-18-2018, 12:42 PM   #6452
Steeveedee
Who Changed This?
Steeveedee's Avatar
When my son and I did the front suspension on my truck (original parts- 46 years old!) we had to stand on the control arms and use a cheater bar. I'd say it took in the neighborhood of 300 Lb-Ft to break the lowers loose, and they fought the whole way. Anchor them down well and get a good impact wrench.
ETA- they weren't even rusted, having spent the last 43 years in southern California. Good luck!
~Steven
Simi Valley, CA
Steeveedee is offline
Old 03-18-2018, 02:21 PM   #6453
69GMCCustom
I have been surprised by the lack of rust on everything. So far the easiest part have been the control arms, they fell out when I took the nuts off. Everything else is O.E. including the brake drums, and it all had 2 inches of road crud protecting it. I was told the odometer had only rolled once from the p.o., (of course if only has 143k miles on it lol.) But according to the licence plate holder, it was sold from Frontier Ford in Fresno, 3 miles from where it sits now.
I'll try a longer breaker bar, if that doesn't work I may have to run the down to an auto shop for a more powerful impact wrench. Thanks!
1970 Chevy Custom.
Old 03-18-2018, 02:42 PM   #6454
ghalperin
ghalperin's Avatar
I had the same problem last year when I did mine. A little heat from the Victor persuader and they came right off. I had to use the torch to heat up many parts for the tear down.
Glenn
1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca
1929 Ford Model A Roadster - traditional pre-war banger hot rod
ghalperin is offline
Old 03-18-2018, 04:01 PM   #6455
NoStopN
NoStopN's Avatar
All I did was move it out of the garage while I moved some wheels in. Sadly, they aren't wheels for the '69. They're just taking up space.
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline
Old 03-18-2018, 04:02 PM   #6456
NoStopN
NoStopN's Avatar
Double post. We need a "delete post" button around here.
NoStopN is offline
Old 03-18-2018, 04:24 PM   #6457
RodnRudy
RodnRudy's Avatar
I went to install my new Holley valve covers and found they won't fit. They're too narrow to clear the casting lug on the corner of the head. The aluminum covers are 1/4" narrower inside than the factory sheet metal ones. I'll be contacting Summit Mon. and sending them back. I'm not wanting to grind down that lug and take a chance of getting shavings in my new engine.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline
Old 03-18-2018, 04:35 PM   #6458
Killer Bee
Killer Bee's Avatar
picked up a donor D60 4:10 LS FF GM 8 lug last weekend for the '71 K20 Sub and left it in the truck for the week..
craned it out at work Friday after shift to roll it into the wash bay for a good bath..
cleaned up real nice, no road scars, dents, or gouges and all the machined surfaces are smooth to the edges
crappy weather yesterday but nice out today so I lifted it out of the truck with my cherry picker..
now for perch and shock mount research and prep for install..
for reference, going under the white one parked in the street in the background, not the blue one in the driveway..
Killer Bee is offline
Old 03-18-2018, 05:18 PM   #6459
Metaldoc
Metaldoc's Avatar
P/s brackets done.
Metaldoc is offline
Old 03-18-2018, 06:55 PM   #6460
OregonNed
OregonNed's Avatar
Re-gapped that last, elusive, hide-behind-the-headers, spark plug to say the tune-up we did is complete...
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 03-18-2018, 08:40 PM   #6461
Pete K1
Replaced gear indicator and dome light and lens from LMC
Pete K1 is offline
Old 03-18-2018, 10:14 PM   #6462
rjs53
Got the front clip removed, then drilled out the spot welds and removed both rockers. That was it, because both front and rear cab mounts are toast, along with both floor pans and cab corners. Someone had put slip on rockers on and homemade cab corner caps. Now the real fun begins.
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline
Old 03-18-2018, 11:19 PM   #6463
Steeveedee
Who Changed This?
Steeveedee's Avatar
Dig the blue 'burb in the background of that pic. There is a '67-'68 'burb near me that I would like to take a pic of, but it's in the guy's driveway. Kind of a lighter blue with darker blue cartoon flames. 4WD, but I forget what kind of wheels. I don't feel right taking pics of people's stuff without asking. Guess I need to start asking. We'll see.
~Steven
Simi Valley, CA
Old 03-19-2018, 10:43 AM   #6464
beaterku
beaterku's Avatar
Finally put the top coat on my frame and broken down parts to convert from leafs to coils. I'm hoping progress picks up now!
Also, updated my YouTube build series: https://youtu.be/fUetpeVKbpk
beaterku is offline
Old 03-19-2018, 09:25 PM   #6465
stevenfromtexas
stevenfromtexas's Avatar
took apart passenger side vent window. sanded and painted. waiting on backorder rubber to rebuild
Steven
'67 SWB, 250ci, 3OTT.......this is my first build......
I wonder if my grand kids will say, "I would give anything to have my grand dads 2005 Chevrolet Z71"
stevenfromtexas is offline
Old 03-19-2018, 11:20 PM   #6466
toolboxchev
If you like the look, why not grind out the inside of the valve cover? (tolerances permitting)
With the nice work you have done on that engine, I would be hunting for a set of vintage finners.
toolboxchev is offline
Old 03-19-2018, 11:40 PM   #6467
69BUCKET
Finally got it in for last time...getting close...
69BUCKET is offline
Old 03-20-2018, 12:20 AM   #6468
swervins69
Motor/trans pulled, as well was bed.
swervins69 is offline
Old 03-20-2018, 07:53 AM   #6469
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What did you do to your truck today? Chapter II
Got the passenger side exhaust manifold off to fix and installed the rear S/S simulators on the ramp truck.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline
Old 03-20-2018, 06:53 PM   #6470
Baker72chevy
I seat the motor in
Baker72chevy is offline
Old 03-20-2018, 07:22 PM   #6471
RodnRudy
RodnRudy's Avatar
I sent the Holley valve covers that wouldn't fit my heads back to Summit and these came on UPS truck this afternoon. Ran out to the garage and threw one on and the fit is perfect. They're Billet Specialties by the way, nice stuff.
Phil
RodnRudy is offline
Old 03-20-2018, 08:48 PM   #6472
Killer Bee
Killer Bee's Avatar
those are very nice covers!
Old 03-20-2018, 09:17 PM   #6473
stevenfromtexas
Received my Classic Heartbeat rubber stuff.....weather strip, window (front and back) rubber and some door and hood bumpers...yeeeyaaaa
the thought of calling in tomorrow to "play truck" crossed my mind
guess I'll go to work....just got a text that that my GMPaul stuff will be here when I get home Thursday morning.....another
Steven
Old 03-20-2018, 10:05 PM   #6474
Drummerboy
Drummerboy's Avatar
I bought my truck a set of hubcaps.
Drummerboy is offline
Old 03-22-2018, 10:16 AM   #6475
RodnRudy
RodnRudy's Avatar
I bent up a new fuel line to better clear my new valve covers.
Phil
RodnRudy is offline
Closed Thread
