Old 02-01-2011, 09:50 PM   #626
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: my 80 build
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 02-02-2011, 12:50 AM   #627
flamingbig10
6.0 powered square
Re: my 80 build
I found a car show pic from last spring at wind star casino
Aaron
Old 02-07-2011, 11:02 PM   #628
flamingbig10
6.0 powered square
Re: my 80 build
here are the headers I will be getting sure hope they work
http://www.speedwaymotors.com/NEW-Dy...LS2,41921.html
Aaron
Old 02-09-2011, 07:20 PM   #629
flamingbig10
6.0 powered square
Re: my 80 build
I got my valve spring tool and got both sides switched out
Aaron
Old 02-09-2011, 07:41 PM   #630
nbpro
Re: my 80 build
got any pics of the cowl hood side view at the back ?
nbpro is offline   Reply With Quote
Old 02-09-2011, 10:28 PM   #631
87c10slammer
truck addict
Re: my 80 build
good lookin truck. im going with the same drivetrain but a little over the top. LQ9 block, L92 heads, 650 cam, 90mm intake and TB, and some other goodies. also going with a narrowed rear and some 10.5 tires.
trucks
87c10slammer is offline   Reply With Quote
Old 02-11-2011, 11:02 PM   #632
flamingbig10
6.0 powered square
Re: my 80 build
no, if I remember I'll take a pic of it tomorrow
Aaron
Old 02-11-2011, 11:03 PM   #633
flamingbig10
6.0 powered square
Re: my 80 build
thanks, that sounds good
Aaron
Old 02-11-2011, 11:07 PM   #634
flamingbig10
6.0 powered square
Re: my 80 build
today I got the rockers and intake on and torqued, the fuel rails on with new o rings, and painted the valve covers black, tomorrw I'll install the valve covers and mount coils, the cross over tube for the fuel the rails
Aaron
Old 02-12-2011, 08:56 AM   #635
bbbc10
Diggin The SquareLife
Re: my 80 build
keep it up!!!
bbbc10 is offline   Reply With Quote
Old 02-12-2011, 11:44 PM   #636
flamingbig10
6.0 powered square
Re: my 80 build
thanks got the valve covers and coil packs on and swapped out the power steering pump for a non hydro boost unit
Aaron
Old 02-14-2011, 01:51 AM   #637
flamingbig10
6.0 powered square
Re: my 80 build
got the wiring harness and the gauges pulled out of the truck
Aaron
Old 02-14-2011, 10:13 AM   #638
JohnC
JohnC's Avatar
Re: my 80 build
Coming along nicely man.
JohnC is offline   Reply With Quote
Old 02-14-2011, 09:31 PM   #639
flamingbig10
6.0 powered square
Re: my 80 build
thanks john
Aaron
Old 02-15-2011, 12:46 AM   #640
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 02-15-2011, 01:49 AM   #641
92GMCDriver
92GMCDriver's Avatar
Re: my 80 build
good progress
92GMCDriver is offline   Reply With Quote
Old 02-15-2011, 11:57 PM   #642
flamingbig10
6.0 powered square
Re: my 80 build
thanks
wile I have the steering column out I'm going to add a new turn signal, dimmer, and ignition switch also a new coat of gloss black
Aaron
Old 02-16-2011, 11:30 PM   #643
flamingbig10
6.0 powered square
Re: my 80 build
I got a few parts today, thermastat, coolant steam line crossover tube, " the original one was crushed by a chain" ignition switch, dimmer switch, front bumper brackets, lower cowl patch panel, and qt of pr15, also got a little work done, got one leaf spring bushing pressed out and a new one pressed in, steam line installed, and the steering wheel, and levers pulled off the column and started sanding on it
Aaron
Old 02-17-2011, 01:19 AM   #644
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 02-17-2011, 09:07 PM   #645
flamingbig10
6.0 powered square
Re: my 80 build
I got all the old leaf spring bushing pressed out and the new one pressed in, and pulled out the center pins so I can get new ones
Aaron
Old 02-20-2011, 01:29 AM   #646
flamingbig10
6.0 powered square
Re: my 80 build
got a few things done got some rust cut out on the driver side kick panel, also picked up some braided hose, new bolts for the fuel tank brackets and leaf spring clamps, and got the rear suspension back together
I will paint the differential when I rebuilt it
Aaron
Old 02-20-2011, 03:40 AM   #647
flamingbig10
6.0 powered square
Re: my 80 build
I will also be using the braided hose and an fitting for the trans cooler I plan on using these fitting
http://www.sweetperformance.com/prod...&productId=496
Old 02-23-2011, 12:19 AM   #648
o0oabizaio0o
o0oabizaio0o's Avatar
Re: my 80 build
where you bought the grill? looks nice
o0oabizaio0o is offline   Reply With Quote
Old 02-23-2011, 12:21 AM   #649
flamingbig10
6.0 powered square
Re: my 80 build
summit racing
Aaron
Old 02-23-2011, 12:26 AM   #650
breeze85cten
Re: my 80 build
where did you buy the engine mounts, I made my own but my buddy is doing the same swap and wants to know.
breeze85cten is offline   Reply With Quote
