Old 03-22-2010, 10:43 PM   #626
joe231
joe231's Avatar
Re: And so it begins................
Originally Posted by highperf4x4 View Post
What kind of pistons and cam do you have?
dunno about the cam, stock I assume.
I was figuring on swapping it eventually.
The pistons are slightly dished.
I got it complete for cheap.
CHEVY ONLY
Old 03-22-2010, 11:29 PM   #627
highperf4x4
Then you'd be ok with the 58cc 305 heads. Make it run pretty good in fact. I thought you had a set of those?
highperf4x4 is offline   Reply With Quote
Old 03-23-2010, 07:53 AM   #628
joe231
joe231's Avatar
Yes I do have a pair of those heads.
They are on the engine in the 80 now.
They would need a little work. I have thought about using those or finding some 64cc heads. I know where I can get a set of TBI heads, but they are gonna need work also. I wouldn't mind vortecs either. Maybe after I get the crew on the road I'll do something with it
CHEVY ONLY
Old 03-23-2010, 07:11 PM   #629
tim21391
tim21391's Avatar
man thats chump change no adays isnt it hahaha
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 03-23-2010, 08:48 PM   #630
scotts62
One day...
scotts62's Avatar
Scott
93 crew cab build
Project 62
Old 03-23-2010, 09:54 PM   #631
americanmusc1e
americanmusc1e's Avatar
Originally Posted by JohnC View Post
HOLY COW!!!!!! I liked it when he looked over and flipped him off, and purged the nos
X2..........that was the funniest thing I have seen in a long time
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 03-23-2010, 11:12 PM   #632
highperf4x4
The TBI heads will give you the best gas mileage as well as bottom end torque. They aren't much good above 4000rpm but if you're not going to change the pistons and the cam then you won't be up there much anyway. Make the Vortecs a future project and slap the TBI's on there. You can also use a stock intake with the TBI heads. You only have to notch the 2 center bolt holes at the top. If you use vortecs you will have to buy a special 8 bolt intake manifold to go with them and then you need to upgrade your cooling system if it isn't top notch as you will lose the rear water passages on the intake unless you pipe in a bypass which isn't very pretty.
You probably already know this crap I'm just tossing it out there for consideration again.
are you talking about nuke's 10,000 engine?
Yeah it's a gut splitter. I wonder if they make a fat boy go-ped for people like me. If I got on that one ................................ it would be laying frame all the way down the track. Be a cool light show though huh? If I hit the nitrous it would just amount to alot of tire smoke.
Old 03-24-2010, 12:48 AM   #633
tim21391
tim21391's Avatar
ha ya i am i was being a smart alec tho.. if i had ten grand i could do so much to my truck u have no idea
Old 03-24-2010, 07:05 AM   #634
joe231
joe231's Avatar
the tbi heads will give you the best gas mileage as well as bottom end torque. They aren't much good above 4000rpm but if you're not going to change the pistons and the cam then you won't be up there much anyway. Make the vortecs a future project and slap the tbi's on there. You can also use a stock intake with the tbi heads. You only have to notch the 2 center bolt holes at the top. If you use vortecs you will have to buy a special 8 bolt intake manifold to go with them and then you need to upgrade your cooling system if it isn't top notch as you will lose the rear water passages on the intake unless you pipe in a bypass which isn't very pretty.
You probably already know this crap i'm just tossing it out there for consideration again.
CHEVY ONLY
Old 03-24-2010, 09:07 AM   #635
JohnC
JohnC's Avatar
Very informative. I don't care what Blake says you are a smart feller!
JohnC is offline   Reply With Quote
Old 03-24-2010, 10:13 AM   #636
nuke1
nuke1's Avatar
Hey now guys, I wish I had that money back, To be truthful, I had just finished up a huge job for someone and had a little money, well, to be truthful, I did not want the wife to get it so i did the next best thing, built my Engine, sure it was a little bit, had I known know what i did then, I would have done a new 6L twin turbo for that dollar, oh well, live and learn, And BTW, I sure widh I had that money now, I barely have enough to pay bills, just chugging along rigth now, slowly getting there. Get a couple of cars done for other ppl and I will be close to out of the hole, I hope. On the bright side, I do enjoy my truck immensely, evn thou most of it is on credit card right now, The wife use to spend too mush money on things and we done got broke, well I always felt bad about buying myself things so I said screw it one day and started ordering parts. Do i regret it, NOT A CHANCE. Look at what I am driving!!! HAVOC. Anyways later guys, BTW, that did not peeve me off, just wanted to clarify.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 03-24-2010, 11:11 AM   #637
highperf4x4
Dang.............................
Lay down on my couch and tell me all about it.
Just playing dude. Everybody gets stung by the truck bug. I picked this truck up last April and within 2 months I had already dropped 2500 before I realized it. You could have done a TT 6.0L but then yours would be like everyone elses on the LSx list brother. I prefer to tell people about my buddies 10,000 gen1 engine.
Old 03-24-2010, 11:41 AM   #638
VA72C10
VA72C10
VA72C10's Avatar
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 03-26-2010, 06:42 PM   #639
TheSebring
Total slander. Investigation of Johnathan Cornelius's accusations and lies towards a one Blake Sebring Mullen, is pending...
TheSebring is offline   Reply With Quote
Old 03-27-2010, 12:51 AM   #640
nuke1
nuke1's Avatar
None Taken, it takes alot to stir my tail feathers, besides everyone needs someone to talk about, All good. Besides I also get to tell ppl what I have into it and their jaws drop hehe, the reactions are priceless when I lift the hood.
Originally Posted by VA72C10 View Post
I conquer
LMAO!!!!!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
Old 04-05-2010, 01:07 AM   #641
highperf4x4
I drove the truck all day Friday and it was cutting out on me. Acted like a fuel issue. I'll probably change the filters first since I installed a new fuel pump already last summer. I did run a compression test on it just to see what it had and 6 cylinders were about 120lbs but #5 was 110lbs and #4 was 100lbs. Not terribly bad but I am a little concerned about #4. The truck still runs pretty good though and doesn't smoke too bad yet so I'll probably keep driving it for a while and just do some body work.
Old 04-05-2010, 08:31 AM   #642
JohnC
JohnC's Avatar
I saw you driving on West Main Friday. Didn't make the light to catch up to you though.
Old 04-05-2010, 11:11 AM   #643
highperf4x4
That is not an easy task anyway fella.
Old 04-05-2010, 03:02 PM   #644
JohnC
JohnC's Avatar
Whatever man. I'm not driving some ricer like you usually pick on.
Old 04-05-2010, 10:56 PM   #645
highperf4x4
yeah no doubt. I will have a 383 soon enough and you can test your TBSS on that one.
Old 04-05-2010, 11:56 PM   #646
Zoomin
Man of Mini-Talents
Zoomin's Avatar
It's not like your engine hasn't been stress tested.
Zoomin is offline   Reply With Quote
Old 04-05-2010, 11:57 PM   #647
highperf4x4
I know, I sucked the headlights out of Neil's dodge and Blakes Ferd!!!!
Old 04-08-2010, 03:07 PM   #648
TheSebring
All it takes is one light, man. You can write it off after that.
And you smoked Neil's Dodge. I didn't get into the race with you all. I just watched on. I went on by later to make my inline 6's self esteem go up a bit.
Old 04-08-2010, 06:08 PM   #649
scotts62
One day...
scotts62's Avatar
Do i have to get the wifes Avi and shut you guys up??
Scott
93 crew cab build
Project 62
Old 04-08-2010, 10:41 PM   #650
highperf4x4
Sounds like a challenge! How much power does her avalon have anyway?
