Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 05-15-2012, 06:03 AM   #626
kev2809
low n' slo
kev2809's Avatar
Re: Project 67 DRGNWGN - 67 Burban!!
Originally Posted by mcbassin View Post
Lots of good progress here since I checked in last. Keep at it Kevin!
thanks, still working at it!
Originally Posted by Slick67 View Post
That's an odd ball problem.....kinda like "my buddy ran over my seats thinking they were in the scrap heap" problem. I am not sure if the turn signal cam would have anything to do with this, but I doubt it. The shift indicator should move freely, but down at the base where the turn signal is I don't think it should. Maybe test it by taping the column so it won't move like it is hooked to linkage. Is everything tight on the column outside the firewall?
lol, ya, he just got the truck and wanted to run something over...bastard.
im assuming everything is tight inside the column, i put everything back the same way it came out. steering wheel bolt is fully tightened, everything under the hood is tightened... the base is the only thing that moves, its buggin the hell out of me!
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is online now   Reply With Quote
Old 06-01-2012, 04:10 PM   #627
1sik7t2
dave
1sik7t2's Avatar
(*$%_...NOW U DID IT...LOOKS AWESOME EXCEPT NOW UR CONTROL ARMS AND FRAME STAND OUT...better fix that man....lol....
Originally Posted by kev2809 View Post
thanks!
heres some pics of the motor and trans dropped in, and the new booster/mc..
check out my build "DIRTY BURB"
1sik7t2 is offline   Reply With Quote
Old 06-01-2012, 04:31 PM   #628
Slick67
Sofa King Crazy!!
Slick67's Avatar
Clean up the frame and front end Kev! As much work as you have done to it, what's holdin you back?!?! This is a classic example of the snowball effect!!
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 06-01-2012, 07:38 PM   #629
kev2809
low n' slo
kev2809's Avatar
lol, you guys are right. i should have done it when i had the motor out...ah, oh well. im hoping my tubs can cover most of it lol
-_--_--_ _________
Old 06-04-2012, 03:14 PM   #630
kev2809
low n' slo
kev2809's Avatar
not a whole lot of anything goin on..
i did pull out all of the airbag wiring, the gauges, gauge airline. i re-routed the gauge line, put new wiring (trailer wiring), made some nifty weatherpack connectors for the valves, pulled all of the metal clamps that touched any airline and put rubber insulated clamps, then ran the wiring and gauge airline through the rear floor. also re-grounded all of the valves to a ground strip, cleaned up all the connectors and put some dielectric grease. also changed out the pressure switch wire with some that is designed to be in weather (other wire i had was crap). then wire loomed almost all of it...
-_--_--_ _________
Old 06-04-2012, 03:15 PM   #631
kev2809
low n' slo
kev2809's Avatar
-_--_--_ _________
Old 06-04-2012, 03:20 PM   #632
kev2809
low n' slo
kev2809's Avatar
going to wire up the compressor switch today and get the gauges back in today. i moved all of it so that the wiring wont go through the firewall. its going under the carpet, under the front seats, and come out through a custom console that i will build later.
been working on all the under hood wiring also, just waiting on getting the driver fender back on so i can finalize the routing of the main under hood wiring. will be buying everything else under the hood this week to get this thing running hopefully. might even start on the tubs and rear wood for the floor i am going to build..
-_--_--_ _________
Old 06-14-2012, 08:51 PM   #633
hotrodchevy1999
Hotrodchevy
hotrodchevy1999's Avatar
looks like it all comeing together nice work
2017 1500 CREW CAB GMC
1997 C1500 Chevy
1971 CHEVY CHEVELLE SS 402BB :
1971 CHEVY C10 Stepside Project 71 cluncker http://67-72chevytrucks.com/vboard/s...ferrerid=89816
My Build Second Chance Suburban (SCS)http://67-72chevytrucks.com/vboard/s...d.php?t=424650
hotrodchevy1999 is offline   Reply With Quote
Old 06-16-2012, 01:35 PM   #634
kev2809
low n' slo
kev2809's Avatar
trying!
im having problems with these stupid manifolds i have. im gonna try to sell them and get some ramhorns or something, these are fore passenger side dipsticks.
i did get my radio in, its just for show. i will be putting a double din under the dash..
-_--_--_ _________
Old 06-16-2012, 07:36 PM   #635
Slick67
Sofa King Crazy!!
Slick67's Avatar
That looks cool in there. Nice touch leaving the old head unit! Lookin good, hope you will be hittin some shows soon!
Old 06-16-2012, 08:32 PM   #636
kev2809
low n' slo
kev2809's Avatar
tryin man! once again, deadline is for march/april for texmex, if not, then def by next june for showdown. (thats been the deadline for last 3 years lol)
once i get some new manifolds or headers, im gonnga try to fire this thing up. pulled my gas tank out today, gonna clean the crap out of it, make some spacers to raise it up some, then put it back in.
to fire up i need: headers/manifolds, battery, oil, filter, trans fluid, coolant, u joints for drive shaft, and carrier bearier mount. this should be enough to fire up and DRIVE it out of the garage and maybe around the block (pending no problems!)
-_--_--_ _________
Old 06-22-2012, 05:12 PM   #637
Slick67
Sofa King Crazy!!
Slick67's Avatar
Don't forget to take a vid and post it when you cruise it under it's own power!!
Old 06-25-2012, 05:04 PM   #638
kev2809
low n' slo
kev2809's Avatar
lol..one day...soon......hopefully......
i got the driveshaft pulled, put all new u-joints and carrier bearing, that will be going back in today. pulled the gas tank, cleaned up the top end and flipped it over..
theres a patched hole.....i filled it up with water to see if it leaks and sure enough, it does. sucks..
im wondering what all the bagged burban guys are doing for tank swaps. i pulled this one to clean up, paint, then raise it since it hit the ground. im looking for the most simpliest, cheapest route for a tank! (maybe even fix this one...?)
-_--_--_ _________
Old 06-25-2012, 09:22 PM   #639
Slick67
Sofa King Crazy!!
Slick67's Avatar
Check with Eastwood, they have a really good sealer for gas tanks. We used it on Ronnie's Cutlass and it worked perfectly.
Old 06-26-2012, 06:28 AM   #640
kev2809
low n' slo
kev2809's Avatar
is that eastwood product for holes..or is it just a rust encapsulator? if i can get this hole sealed up..ill be set!
-_--_--_ _________
Old 09-22-2012, 08:36 AM   #641
XxCHEVYMANxX
XxCHEVYMANxX's Avatar
just read thru your build. Nice work ! por 15 would work great on that frame, and it likes to go on top of rust.
John
Mild Custom 68' Work Truck Build
Facebook LoL
1977 Trans Am (Project)
1965 Chevelle (Project)
XxCHEVYMANxX is offline   Reply With Quote
Old 10-09-2012, 01:07 PM   #642
NSK
NSK's Avatar
Whats up Kev you making any head way on this thing?
NSK is offline   Reply With Quote
Old 10-09-2012, 01:14 PM   #643
kev2809
low n' slo
kev2809's Avatar
thanks..i try not to look at the frame..lol. it will be covered up anyways..still thinking about doing the front tho.
well, i did, then went way back.
i finally got the motor in position to fire..sort of. i got the tank cleaned up, raised and painted (gonna have to make a new filler hole). i got everything for the motor to crank, was trying to set TDC to stab the distributor..so i go to rotate the motor and just before a full turn it stopped on me. went to turn it back the other way and again..just before full turn it stops again. i posted a thread in the engine section and from the advise i got from there...its gonna have to be pulled it replaced or worked on. sucks big time...
for now im gonna get the seats mounted, and get the whole truck back together for body work. i did get some grant hinges so i can work on getting the hood on, also an EDC for the air ride, some struts for the liftgate mod..the rest was pretty much blown on the stuff for motor...which is useless for now.
i may just pull all of my new stuff off the motor and sell the block and heads and look for something else..i got a $1600-1800 quote for a rebuild..and thats nowhere near my budget for now.
-_--_--_ _________
Old 10-09-2012, 02:43 PM   #644
NSK
NSK's Avatar
Man that sucks. If you need a hand let me know. I can pull a sbc apart and get it back together in a weekend as long as theres no machining involved.
Old 10-09-2012, 02:51 PM   #645
kev2809
low n' slo
kev2809's Avatar
thanks..thats what im afraid of.
i think machine shops usually charge about 300 im guessing to hot tank it and clean it up..?
ive seen rebuild kits for about 250-400 bucks i think..then labor to put it back in. i wouldnt even know where to start buying stuff for a rebuild though!
-_--_--_ _________
Old 10-09-2012, 02:57 PM   #646
NSK
NSK's Avatar
I've had a lot of good luck with kits from summit. But you need to have all the info on the motor first as far as bore and crank bore. They do run about 400 for a basic one. Like I said I have a huge shop that's full of tools so if you want to have menhell you check everything out to see if it's even worth fixing let me know and well tear it down
Old 10-09-2012, 03:42 PM   #647
Slick67
Sofa King Crazy!!
Slick67's Avatar
That sux Kev. Let me ask around for a short block and see what I can find for ya. Maybe we will get lucky and find something good on the cheap for ya. Hope I can help.
Old 10-09-2012, 04:12 PM   #648
kev2809
low n' slo
kev2809's Avatar
thanks fellas. im hoping i can try to get this motor out and up on the stand by this weekend so i can see what im looking at. maybe i dropped a socket in there somehow lol
-_--_--_ _________
Old 10-09-2012, 10:07 PM   #649
project 67 sub
project 67 sub's Avatar
That sucks about the motor. But look at the bright side.... you can now clean up and paint the front end and frame before a new motor goes back in
project 67 sub is offline   Reply With Quote
Old 03-06-2013, 03:07 PM   #650
dr69burb
dr69burb's Avatar
Whats kev any updates?
Baggin 64 lwb project
http://67-72chevytrucks.com/vboard/s...d.php?t=537406
dr69burb is offline   Reply With Quote
