Closed Thread
Old 01-10-2010, 02:59 AM   #626
Rich 5150 69
Rich 5150 69's Avatar
Re: What did you do to your truck today?
I`m thinking you might have to loosen the headboard, shim, the tighten down the headboard again. just a thought...!
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline
Old 01-10-2010, 12:48 PM   #627
ravens65
ravens65's Avatar
Originally Posted by 198plus View Post
Getting tired of trying to get bed adjusted..........Cannot git rid of this problem, how much is to much for shims. To get tailgate to close on this top side I have to shim the other back side of bed up 3/8 inch and then bed doesn't set level..........Help any suggestions.......
first make sure you know what the problem is... use two pieces of string , hold them corner to corner ( diagnal -inside ) to form a x shape if the strings touch in the center ,its not warped- if there is a gap or one string bends the other one than it is warped .this little trick will tell you what is going on
If it has tits or wheels its gonna give you problems!!!
ravens65 is offline
Old 01-10-2010, 05:37 PM   #628
ravens65
ravens65's Avatar
well we installed 41-48 repo tail lights today , it was freezing , even in florida. I had a good helper today ,the youngest of my 3 sons! the fenders were off so I traced the stake pockets of the bed onto a big envelope, measuring off the lower hole and taped it to the fender , this let me center the tail light in the postion that I wanted with out installing the fender again. We used a 1-1/2" holesaw then cut between the holes , left a little adjusting room just incase the holes were off a little -I love the look !!!!!!! custom yet old school!!
ravens65 is offline
Old 01-10-2010, 05:49 PM   #629
ravens65
ravens65's Avatar
OK , people are wanting to see how that hood tilts forward here is a pic. of part of the hinge notice how the flat stock runs across the back of the radiator support and ties the left and right together, the part that hooks to the hood is a " H " shape w/ angles on a 45% that ties the " H " structure together , ea leg of the " H" have a lug nut welded inside and a heim joint threaded into the lug nut - a 2"x2" angle was then bolted to the stock hood support , Now my stock hood supports were fiber glassed to the fiberglass hood -simple right? I'll post better pics. later when I can get to the hood Eric
ravens65 is offline
Old 01-10-2010, 06:58 PM   #630
aboz
aboz's Avatar
I crawled underneath my '63 just to see how rusty the flywheel is getting. My new clutch has been waiting for over six weeks to be installed. Between being sick for the entire month of December and the fact that here in NC we've had the worst cold snap in 33 years, I really haven't felt like doing much.
ABOZ
aboz is offline
Old 01-10-2010, 09:11 PM   #631
Envy
Envy's Avatar
Today I pulled the "new" sbc 350 out to make room for the cummins swap, next weekend hopefully take the coils out and put the bags in and my new center crossmember and cpp trailing arms.
Envy is offline
Old 01-10-2010, 09:38 PM   #632
protrash64
Resistance is Futile
protrash64's Avatar
'Burb got a new Optima and some 255/60/15's to match the rear tires...looks good and starts even better.........
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline
Old 01-10-2010, 09:49 PM   #633
sams60gmc
sams60gmc's Avatar
Did a quick little video blog trying out my new camera
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline
Old 01-10-2010, 09:51 PM   #634
198plus
198plus's Avatar
Alright I pulled the strings and one string bends the other, I shimmed it with washers up to where the strings barely touch..........9/16 of an inch.
Whats next ?
198plus is offline
Old 01-10-2010, 10:07 PM   #635
truckdrivinsob
Gear Jammer
truckdrivinsob's Avatar
I towed mine back to my shop Damn timing chain! Its gear drive time!
truckdrivinsob is offline
Old 01-11-2010, 03:55 AM   #636
NF65Fleetside
NF65Fleetside's Avatar
I took off my hideous side mirrors and replaced with a peep mirror. Put a new chrome dome light and lens in. Attempted to replace my turn signal switch with no luck of getting the steering wheel off....and chipped it too! suxs! will try again tomorrow.
NF65Fleetside is offline
Old 01-11-2010, 09:35 AM   #637
lakeroadster
well we installed 41-48 repo tail lights today .... custom yet old school!!
I am loving the way the 41-48 tail lights turned out! Good job.
On Saturday I finished all the mounting bracketry for my stretched 67 Camaro dash. 9 bolts hold it in and it is very sturdy, yet removable. Now on to the wiring and center gauge pod.
lakeroadster is offline
Old 01-11-2010, 09:49 AM   #638
ravens65
ravens65's Avatar
Whats next ?
well looks like you will have to replace the tailgate , this is common with these old truck- all of them were used as work trucks . take it off get the bed right ,shop for a new tailgate . the old one will never be right . the string trick is something that I do to ck doors with ( houses and commercial , wood and metal ) if it was a metal door I would put a hammer handle in it and slam the door to bend it back !!! you could try that but it might damage the box. but if you buy a used tailgate at least you know how to check it Eric
ravens65 is offline
Old 01-11-2010, 09:56 AM   #639
ravens65
ravens65's Avatar
well I like the impala lights on yours but they cost to much hahaha so I chose the 41-48 , both ideas look better than stock don't they???
ravens65 is offline
Old 01-11-2010, 10:16 AM   #640
C10Slim
Mounted PS pump, plummed brake lines and cables, installed gas tank and a new set of drum shoes.
C10Slim is offline
Old 01-11-2010, 04:46 PM   #641
blackmopar
got my motor painted and started putting her back together - scored a set of used hooker super comps for $40 bucks! [IMG][/IMG]
blackmopar is offline
Old 01-11-2010, 09:51 PM   #642
sams60gmc
sams60gmc's Avatar
Today I made my lower bag plates and got them set up on my axle. I set my pinion at 3 degrees. I set a tool in the mill to cut the radius on my upright pieces and they fit great. I took some 5 1/2 stock and machined it down to 5 1/4 for my plates and got them welded up and tacked onto the axle.
Old 01-13-2010, 03:59 PM   #643
63 extreme low
63 extreme low's Avatar
Today I finished making my small back window into a big window!
63 extreme low is offline
Old 01-13-2010, 06:30 PM   #644
SCOTI
SCOTI's Avatar
Tips, suggestions, pics, general things to avoid?? This is on my list so I'm trying to learn from everybodys efforts before the 1st cut begins.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is offline
Old 01-14-2010, 02:08 AM   #645
DWright
Shlong Bed Club
DWright's Avatar
pulled the 'ole 6 out to make room for my hopped up 350 undercover. next the front cross member is gettin' pulled to install the '78 member, power steering, and bags. then onto the dreaded body work.my goal is to be rollin again by spring. fingers crossed.
DWright is offline
Old 01-14-2010, 02:12 AM   #646
NF65Fleetside
I got my steering wheel off and replaced my turn signal switch. Should have snapped photos and did a tech thread but was in a rush so i could move the truck before street cleaning!!!! =)
Old 01-14-2010, 02:29 AM   #647
SCOTI
SCOTI's Avatar
Originally Posted by SCOTI View Post
And finally, my list for this week....
Set the steel floor in place to finalize my fuel fill routing planned for Sunday.... DONE
Finish fitting my fabricated upper shock plates to the shock x-member DONE
Trim the PB dropped truck arm Panhard bar bracket DONE I finished this before cutting the shock x-member c-sections
I updated my list today. I even c-sectioned my upper shock c.member while finishing the shock brackets. I should have them burned in before my 'new list' is made next week.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
SCOTI is offline
Old 01-14-2010, 02:33 AM   #648
DWright
Shlong Bed Club
DWright's Avatar
I also started putting my boss' F**D together for him. sorry guys, i had to do it; he cant do anything by himself.
DWright is offline
Old 01-14-2010, 02:38 AM   #649
SCOTI
SCOTI's Avatar
Gotta love those Falcon Sprints!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
SCOTI is offline
Old 01-14-2010, 02:43 AM   #650
DWright
Shlong Bed Club
DWright's Avatar
he's a self proclaimed " chevy guy" and this is his first ford. i found it for him this time last year for $200. i also supplied and built the 311 cid motor for it. it was the only way i could keep him off my a$$ about working on my truck at the shop. i figured if i got him something to work on he wouldnt bother me; it worked.
DWright is offline
Closed Thread
