Old 02-19-2011, 11:54 PM   #626
85burb
85burb's Avatar
Re: 85 burb meets 6.0 lq4
Originally Posted by joe231 View Post
Cool
Sorry if I missed it, but what kinda mileage are you getting?
Seems to get the same milage as last motor. I filled up on tuesday and made sure to wright the milage down but somehow i messed the numbers up cause according to my numbers i have wrote down i still need to drive some. What i put down was 69497 and i have not even made it to 69490. Cant figure out what i did but i will fill it up sunday again to retest. Then in 2 weeks i will know.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 02-27-2011, 02:21 PM   #627
85burb
85burb's Avatar
Well got to play more today. Changed my main jets to 69 from factory 65s. Made huge differance. O2 gauge stays above 16:1 even in overdrive. No more shaking when i throttle in to it. Will check plugs tomorrow. But seems to be right on.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-27-2011, 08:04 PM   #628
y5mgisi
Second Chance Program
y5mgisi's Avatar
Nice!
y5mgisi is offline   Reply With Quote
Old 02-28-2011, 04:51 AM   #629
lechez71
did those ebay headers work? if no what was the problem? thanks
lechez71 is offline   Reply With Quote
Old 02-28-2011, 12:27 PM   #630
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
dont go too lean!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 02-28-2011, 12:59 PM   #631
68 TT
Still plays with trucks
68 TT's Avatar
16 to 1 or higher is too lean for a carbureted system. Try to get it closer to 14.7 to 1.
You will create too much heat and start to damage your engine if you maintain 16 to 1 or higher on a sustained trip of more than a couple minutes constant cruise at that ratio.
It won't take long at all to burn a hole in a piston or burn a valve running that lean with no transitions into richer mixtures to cool things off.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 02-28-2011, 09:21 PM   #632
85burb
85burb's Avatar
Hold on fellas i am trying to fatten it up. With the 65 jets that came with it the O2 would take a nose dive to over 18:1. Now with the 69 jets it only hits 16:1. It is around 14.5 to 15 going down hiway. Gas milage has went to hell for some reason. Maybe i need to recheck my idle mixture. First few days of this tank went great then when it got to 3/4 tank thusrday it just plumited tell today. Drove like semi normal person except for a few moments when foot "sliped" and made pedle go smooth to floor.....Whoops. I am kind of on the edge about going to 70 or 71 jets. I want to receve some kind of mpgs but still not kill my motor. I checked my plugs today. Was going 2000 rpm in 4th with converter unlocked and help steady pace for a while and then shut truck off whale holding pedle at some position and coasted to a stop and pulled plug. This is the #1 plug the same one that few weeks ago was covered in burned oil. Still lean. But has massive gas smell at idle. Think i will recheak mix at lunch tuesday.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-28-2011, 09:24 PM   #633
85burb
85burb's Avatar
They hit everything within 5 foot radius of the engine. They hit trans, and shakle on the passenger side and on the driver they hit the shackle and that was it i thought tell i tryed to put trans in N to push it back and clean under it and could not shift. If it was 2wd with shifter on the trans tunnel it would problely work out fine.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-01-2011, 05:31 AM   #634
lechez71
last weekend i saw an 85 c10 with ls1 camaro pacesetter headers, they fit good without any problems, only the driverside collector was cut and welded at an angle to not hit the frame. so if these ebay headers are similar to pacesetter they should they work. im looking for some headers that wont cost an arm & a leg. you think they would work on my 82 c10? just spent 40 minutes reading your thread good job with it.
Old 03-02-2011, 12:23 AM   #635
85burb
85burb's Avatar
Hear is where i got the idea. His is a 2wd and seamed to fit great. You must read fast. Takes 40 mins to compose a post sometimes...JK. Thanks.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-12-2011, 12:04 AM   #636
85burb
85burb's Avatar
Buying a eaton true trac tomorrow for buddy with install kit. YAY getting sweet deal on it also. Just in case i destroy the one that is in now.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-13-2011, 01:32 PM   #637
68GMCCustom
I thought it was a peg legger?
Kurt -
Old 03-13-2011, 03:06 PM   #638
85burb
85burb's Avatar
It is a one legger right now. My friend had this eaton true trac sitting around and wanted to sell it. For only 300 i got brand new true trac and master install kit. Could not pass it up. I think mine i have in now may be going bad. If i stop then try to start out again something binds up then popps and then goes nicely. My dad had same problem and it was his diff. I redone the rear brakes and it did not change anything. It has done it for a while now. Even befor the new trans. So that leaves t case or diff.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-13-2011, 09:31 PM   #639
kSStamp0182
LSX addict
kSStamp0182's Avatar
where you on front street yesterday? say around 3:30?
-1982 C10 SWB GMC Sierra [undergoing 6.0/4L80E swap with mild restoration]
kSStamp0182 is offline   Reply With Quote
Old 03-13-2011, 11:06 PM   #640
85burb
85burb's Avatar
I was...........................
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-14-2011, 01:28 PM   #641
kSStamp0182
LSX addict
badass! i thought i seen ya, that thing sounds so damn sick man, we were at the kawasaki dealer there
Old 03-14-2011, 07:49 PM   #642
85burb
85burb's Avatar
Thanks. I love the way it sounds if i goose it in first gear. Scares most people....... Was at chilies other night and scared crap out of like 4 teen age girls several time. Was great every time i goosed it they jumped i did it atleast 5 times.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-15-2011, 08:37 PM   #643
85burb
85burb's Avatar
I HATE TOYOTAS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! The wifes yota costs more then my dang burb to keep running. Her breaks were squeiking so i took the wheels off one buy one with gas lug wrench that came with the car. Needs rear pads and rotors, front pads rotors and both front axle shafts, driver side wheel bearing. Of course it has pressed on wheel bearings, and needs alignment when you do any of the major work so it is not worth doing your self due to how bad the alignment will be off for the drive to the shop. I am just going to buy her an old truck so i can do almost everything myself. Sorry just so pissed off at how work went today then find out car needs grand worth of work. Money that i was going to use to for the burb now has to go to gay yota that has massive jelousy problem!!!!!!!!!!!1
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-27-2011, 01:02 PM   #644
85burb
85burb's Avatar
Well not a hole lot going on any more. I put my new steering box in yesterday and shipped my rented jets back. Not happy with the jetting but not really sure what i need to do so i wont do anything. I need to call holley and talk with one of there techs i guess. Still running stronge with no smoke or drips or consumption of any kind. My next oil change i will have my oil analyesed cause we got a oil analyser thing at work now. Still need to get my front breaks and put them on. Slaking on that big time.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-27-2011, 08:31 PM   #645
my4by2
my4by2's Avatar
Really nice build thread man! Love the old Burbs!!! Will keep checking back for more updates!
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 03-31-2011, 11:23 PM   #646
68GMCCustom
Have you run a laptop hooked to your MSD while running? After a bunch of head scratcing I finally did...and noticed the 6LS-2 adds whatever timing shows in the MAP's table...even though no MAP sensor is connected. With 0* base and 4* at 1k (per one of their pre-programmed chips with 20* in the MAP table for low vacuum).... you'd have nearly 24* of timing at idle.
Kurt -
Old 03-31-2011, 11:42 PM   #647
85burb
85burb's Avatar
Yes i have even driven around with it hooked up. The chips have tons of timing put in them. I dont know what they should be set on to run the best but mine runs ok with 2 in it i think. Not really sure what timing i need on my motor would like to play with it but i not sure i would set it right. Have no played with it much. Could that be part of my mpg problem?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-01-2011, 11:22 PM   #648
85burb
85burb's Avatar
Well as it truns out i need new floor mats. Today after work i parked truck in front of my work to let it warm up a bit and i backed out of my spot and put in drive and punched it. Spun tire for like 25 feet the decided it was time to let out of it so i took foot off pedle and that is all that happend my pedle stayed on the floor and we just kept on accelerating. (not the first time this has happend the first time it happend i had two coworkers in it and the one i the back seat was screaming like little girl....I was laughing so hard i could bearly reach down and pull pedle off the floormat) The guy out side was almost on ground cause he seen the hole thing and was laughing so hard. So i shut it off and skidded to stop and ajusted my mat and reversed over to him. We were both in pain due to the laughing. Was the funniest thing that has happend in a while. Any way made good end to a crappy day at work. So i am in the market for new floor mat now..........
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-01-2011, 11:25 PM   #649
my4by2
my4by2's Avatar
Man, you'd think you were driving a Toyota not a Chevy... haha
Old 04-02-2011, 12:09 AM   #650
85burb
85burb's Avatar
I should call chevy and expaline this to them...Then they would put out a recall and save millions of lives........... Will put that on list of stuff to do monday. I will set burb aside and drive my wifes avalon tell they get the recall put out.
They did not find any thing wronge with any of the cars they recalled....... Smells like massive scam. All started out buy some hoople head getting pulled over and told cop oh i was trying to slow down....... Pedle was stuck...... Can you tow it to toyota for me..... Sure it was somthing like that. The best one was the guy with a pruis that was getting chased buy cops and the car overpowered the breaks..... Ya right............. I have yet to see one that can get to speed limit within a mile.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
