08-12-2010, 09:55 AM | #626 |
Re: What did you do to your truck today!
Hung the doors on my 67. What a PITA!!!! Passesngerside took hour and a half. Driver side 5 minutes. WOW!
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
08-13-2010, 08:06 PM | #627 |
I worried that something has happened to it while I am away on vacation.
08-13-2010, 08:15 PM | #628 |
Today I got the alignment done and now my truck really handles well!!
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
08-13-2010, 10:24 PM | #629 |
Backed the Burb out of the middle bay so I could get the Harley out. Rode to the 50th Friday the Thirteenth Rally in Port Dover Ontario Canada. Thousands upon thousands of people and bikes descended on this beautiful little Lake Erie Port Village. Great time. Super day for a nice 220 mile round trip ride. Tomorrow I'll actually do some work on one of the trucks.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
08-13-2010, 10:29 PM | #630 |
Replaced u joint in rear and took her for a spin.
08-13-2010, 10:40 PM | #631 |
My buddy & I just got my 72 K-10 Surburban running tonight after 2+ months of rebuilding the transmission & transfer case! It spent 2 years in the driveway, not being driven, because it only went backwards and I was lazy. Just the 200lb. cast iron transfer case took us 3 hours using a cherry picker down through the floor, floor jack underneath with a 2x10 board, and all the while pushing with our feet and pulling from up above to get it mounted! It was all worth it ... even though it was throwing serious smoke all the way home from the garage.
08-14-2010, 07:35 AM | #632 |
Replaced some cancer on my 68 C20. Got the inner rocker, lower A piller ext., front lower piller and kick pannel tacked in. Was tacking in Outer rocker to check door fit, but had to stop and unplug my econotig because of lightning storm. Already lost a computer, modem and big screan TV 3 yrs ago. Not loosing my econotig.
Man, I hate 3D puzzles. Nothing seemed to fit right. Taking longer than I expected, but getting there. |
08-14-2010, 09:43 AM | #633 |
carb swap/ 670cfm back to 600cfm just to much fuel for my stock motor to manage. plus, retarded the timing back to 8 degrees. the thing was burning fuel like a saturn 5 rocket!! now runs as it should. cheers, Pat
08-14-2010, 12:58 PM | #634 |
Cruzin
installed my junkyard swaybar with new moog bushing boy that last bolt was a pita that stuff fits tight, haven't drove it yet
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
08-14-2010, 02:40 PM | #635 |
order a bunch of parts from ece.....
08-14-2010, 03:54 PM | #636 |
Installed my 7.00 (= some vinyl paint) pair of junkyard visors!
[IMG][/IMG]
08-14-2010, 04:07 PM | #637 |
PROJECT 7DEUCE
I and getting ready to do the rear brakes on the blazer and not looking forward to it..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
08-14-2010, 08:12 PM | #638 |
thursday and friday my carb (quadrajet) flooded on the way to work. contemplated on rebuilding it but had some truck money saved that i have been saving to buy old air ac. so today went out bought an edelbrock 600cfm 1406 w/ electric choke and put it in about an hour. now have to figure out while she idles really high. also found out my truck got hit on the new aftermarket lt bedside. to bad i wond find out out who hit it.
08-14-2010, 08:15 PM | #639 |
I put a new inside door handle on my daughters 98 surburban. Also bought a new radiator at O'Reillys for my 72 suburban but it got too hot outside. I will try to get it installed in the morning.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
08-14-2010, 08:30 PM | #640 |
Redefining LowBudget
yesterday tore part a 425 I got that I was going to use the heads off of only to find out they arn't as good as the ones I have.....
so today I pulled the heads on the 500 and pulled all the valves out put in new oil rings and lapped them all in.... well except the one that was bent.... I was surprised how well everything came out even after hearing all the horror stories about beating the fire wall back just to make it fit..needless to say the vavle covers came off used the engine hoist to pull the intake off in 1 piece unhooked the exhaust pulled the head bolts ( torqued to 115 lbs 50 years ago) hooked the hoist to it let it sit for 20 min with tention till the gasket let go the lifted it all out cleaned up the valley....tomorrow I'll start soaking the lifters till I get the gaskets on Monday....should have it back together in 2 hours....
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
08-14-2010, 08:39 PM | #641 |
What?
Took my burb out for a 150 mile back road cruise.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
08-14-2010, 08:57 PM | #642 |
Cruzin
pushed it up the road, after it quit getting fuel on me A BIG THANKS TO YOU 2 WHOEVER YOU WERE IN THE 67 THAT HELPED ME THANKS!
08-14-2010, 09:24 PM | #644 |
I started degreasing the front axle I picked up for the K10 like three months ago. It has disk brakes and even looks like it'll turn better.
My buddy picked up a 2008 Shelby GT500. Looks like the Camaro is gonna get some money and time spent on her just to keep up. I'll let you ladies know how it goes. Last edited by RossRinSD; 08-14-2010 at 09:26 PM. |
08-15-2010, 12:20 AM | #645 |
Grandpa in the rustmobile...
sat in it and talked on the phone in the rain and played witht he gear shift lever..lol I cant wait to drive it
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
08-15-2010, 12:46 AM | #646 |
Wide n'Low
I finally got the time to finish the frame clean up and today my son and I broke out the Eastwood products and got busy. I used Rust Encapsulator and chassis black (satin). Of course during the work party, we discussed using an after-market cross member, and I convinced him to go for it. So, two things to do, install the c-notch and now a new cross member.. then finish those areas ..
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
08-15-2010, 01:17 AM | #647 |
paited my tilt colum nice red since my tuck i s black with red accents so the steering wheel was painted too
08-15-2010, 06:32 AM | #648 |
stole the tire pressure gage out of the center console so i could check and reduce the air pressure in the tires on my beetle
08-15-2010, 07:59 AM | #649 |
I repainted the front of my frame and removed the motor mounts so it will be ready for the new motor and tranny.
08-15-2010, 10:42 AM | #650 |
Ordered from board member "toomuchstuff" a heater control assembly with cables to replace a half assed installed heater controls from a 73-81 chevy truck that did not even fit the opening.
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride Last edited by chevy88; 08-15-2010 at 10:43 AM. |
