Old 01-16-2011, 08:28 PM   #626
JasonBird
'67 C-10 LWB Driver
JasonBird's Avatar
Re: slik ricks 67 short wide CST
well cool! i didn't know you had a spotlight! hubcaps are looking good! need some pics of them installed!
'67 C-10 LWB - My Build Thread
'67 C-20 LWB - My Donor/ Parts truck - SOLD!
'92 GMC SAFARI VAN - My Parts Go Getter
'06 KIA SPORTAGE EX - My Commuter
"All of this crap better make a truck!" - my wife Sue.
Proud U.S.M.C. Dad!
JasonBird is offline   Reply With Quote
Old 01-16-2011, 08:35 PM   #627
67chevy1series
67chevy1series's Avatar
thanks,yep i got that spotter off of a 70 gmc truck!,thanks the vision of those hub caps painted like that came to me in my sleep! i cant install them until i get my 72 5 lug steel rims ,right now i am running 80's rallie rims
i am kicking around the idea of getting a speed reminder.....
67chevy1series is offline   Reply With Quote
Old 01-16-2011, 09:52 PM   #628
67chevy1series
also that hub cap i stilll need to work on as you can see the red where it should be black
Old 01-16-2011, 10:16 PM   #629
67chevylongbed
67chevylongbed's Avatar
Truck and hub caps look great keep it up man
Eric
1967 C10 LWB SOLD....
1995 Ford F-250 4x4 Powerstroke, 342k
"Each generation goes further than the generation preceding it because it stands on the shoulders of that generation. You will have opportunities beyond anything we've ever known."
-Ronald Reagan
67chevylongbed is offline   Reply With Quote
Old 01-16-2011, 10:20 PM   #630
67chevy1series
you too eric!!!!
Old 01-16-2011, 10:35 PM   #631
67chevylongbed
Originally Posted by 67chevy1series View Post
you too eric!!!!
thanks!
Eric
-Ronald Reagan
Old 01-16-2011, 10:36 PM   #632
67chevy1series
your welcome eric
Old 01-16-2011, 11:21 PM   #633
69C-owner
Re: slik ricks 67 short wide custom/10
thanks ya my dad said i should get different ones but i like them
Nothin better than factory
http://67-72chevytrucks.com/vboard/s...d.php?t=43855069 LWB Fleet
1994 Buick Roadmaster
1994 GMC Sonoma
69C-owner is offline   Reply With Quote
Old 01-16-2011, 11:23 PM   #634
67chevy1series
i know right i love those vavle covers
Old 01-17-2011, 06:55 PM   #635
nds1968
nds1968's Avatar
Are you practicing on those caps Are you gonna use that tailgate with the dent in the top?
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 01-17-2011, 08:27 PM   #636
67chevy1series
actually no those caps will stay painted red and black ,then your caps will be left alone he only thing i will do is paint the back side white on the one with the surface rusta and after that they will be waxed and kept clean yes i will be using the tailgate with the dent on the top , i got that tail gate of of the same truck that i got my cab from i have a 68 tail gate that will give a chunk of its life to make this one perfect!
Old 01-17-2011, 08:29 PM   #637
67chevy1series
well today i cleaned up the floor under the seat and in front of the seat it was filthy but now it is all clean and i gave the tires and rims a good scrubbin so no major porgress today but i did find more screw to screw the heater box on the inside to the fire wall so now all i need is the outside box and i should be set
Old 01-17-2011, 08:46 PM   #638
nds1968
nds1968's Avatar
I had a similar dent like that on my original tailgate. I welded a piece of flat stock to it then pulled up on it with a crane. I then used a BFH and still had to add heat to get the dent out. I turned out nice in the end
Nate
Old 01-17-2011, 08:48 PM   #639
67chevy1series
nate that is definaltly somthin to about i need pics
Old 01-17-2011, 08:56 PM   #640
nds1968
nds1968's Avatar
I don't have any pics My tailgate wasn't as bad as yours, I'm just throwing some ideas your way. If you don't have a 10,000lbs over head crane handy maybe you could use an engine hoist or chain block.
Nate
Old 01-17-2011, 08:57 PM   #641
67chevy1series
oh no crane handy so i guess i will just cut it out then
Old 01-17-2011, 09:00 PM   #642
nds1968
nds1968's Avatar
I would try to straighten it before cutting it out. Like I said maybe you could use an engine hoist or something. You could also weld a piece of chain to the top of the dent and pull on that.
Nate
Old 01-17-2011, 09:04 PM   #643
67chevy1series
i will try that
Old 01-17-2011, 10:10 PM   #644
67chevylongbed
i will try that
I would try the engine hoist too, if it works it'll be a lot easier then cutting that piece out.
Eric
-Ronald Reagan
Old 01-17-2011, 10:47 PM   #645
67chevy1series
yes it will so when the time comes i will do it
Old 01-18-2011, 12:16 AM   #646
67chevy1series
well sleepertruck72 is going with the newer pullies and will not be needing his old pullies if he gets the newer pullies then i will get the old pullies!
Old 01-18-2011, 12:52 AM   #647
67chevylongbed
Cool, hope you get them so you can get your motor going
Eric
-Ronald Reagan
Old 01-18-2011, 01:55 AM   #648
mcbassin
Still Learning
mcbassin's Avatar
The truck is looking great! I like the brake pedal mod. Need more pics.
mcbassin is offline   Reply With Quote
Old 01-18-2011, 03:18 AM   #649
67chevy1series
me to!
i did a brake pedal mod? if you are taklin about the e brake cover then i will get more pics
Old 01-18-2011, 04:05 AM   #650
69C-owner
grab all ur buddies, the bigger the better and have them stand on the hoist so it doesnt just start lifting itself off the ground when you start raising the boom on it
1994 GMC Sonoma
