Old 03-15-2016, 11:42 PM   #626
66ChevyMax
66ChevyMax's Avatar
Re: Mesquite 1966 C10 - LS3 W/Air Ride
All buttoned up, a few things to take care of on the bottom and put fuel cap in.
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 03-16-2016, 08:17 AM   #627
dwcardfan
dwcardfan's Avatar
You are welcome. Glad I could help. Keep up the good work your truck is looking awesome.
dwcardfan is offline   Reply With Quote
Old 03-16-2016, 09:52 AM   #628
greg65
greg65's Avatar
Wow. The bed wood turned out great. Congratulations on your sons marriage. Any bride that wants and old truck in their wedding is a keeper.
1965 c-10 swb
1997 c-1500 extended cab
2004 tahoe
1993 mustang gt
BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653
greg65 is offline   Reply With Quote
Old 03-16-2016, 05:21 PM   #629
66ChevyMax
66ChevyMax's Avatar
She's a keeper!
Craig
Old 03-16-2016, 10:20 PM   #630
66ChevyMax
66ChevyMax's Avatar
One last look at the bottom:
And the final touch, small I know but you know your done when this goes on:
Craig
Old 03-17-2016, 08:55 AM   #631
dwcardfan
dwcardfan's Avatar
Put some gas in that thing and fire it up. Looking good!
Old 03-17-2016, 08:12 PM   #632
chevy.c10
chevy.c10's Avatar
Is there undercoating or bedliner under the bed and in the wheel wells? Or just paint?
chevy.c10 is offline   Reply With Quote
Old 03-17-2016, 10:31 PM   #633
66ChevyMax
66ChevyMax's Avatar
The bottom of the wood has 2 coats polyurethane, the wheel wells and inside of side panels has lizard skin coating.
Craig
Old 03-17-2016, 10:48 PM   #634
66ChevyMax
66ChevyMax's Avatar
Hood supports back in:
Got all the trash sanded out and polished, still have one more polishing to do:
Craig
Old 03-18-2016, 02:14 PM   #635
Austin_Jim
Craig,
Just read through the entire build. Great work and way to stay strong through the tough family issues. One thing I just read about is the AN fittings you are using to connect to the regulator. Apparently, the ones with the plastic inserts are know to fail, spraying fuel everywhere and causing fires (no bueno). They have been updates to two piece metal ones. I just returned mine and got the new style.
Bad ones - Amazon.com: Russell 640853 -6 AN Male to 3/8" SAE... Amazon.com: Russell 640853 -6 AN Male to 3/8" SAE...
Good ones - Amazon.com: Russell 644123 -6AN Male to 3/8" SAE... Amazon.com: Russell 644123 -6AN Male to 3/8" SAE...
Austin_Jim is offline   Reply With Quote
Old 03-18-2016, 07:48 PM   #636
66ChevyMax
66ChevyMax's Avatar
Thanks for the heads up Jim I appreciate it. I had to change the regulator which now has threaded connections. The only place I have the connection you showed is to the fuel rail and I already have the ones you showed for that. Thanks again,
Originally Posted by Austin_Jim View Post
Craig,
Bad ones - Amazon.com: Russell 640853 -6 AN Male to 3/8" SAE Quick-Disconnect Female Push-On EFI Fitting
Good ones - Amazon.com: Russell 644123 -6AN Male to 3/8" SAE Quick EFI Adapter Fitting
Craig
Old 03-18-2016, 10:00 PM   #637
siggyfreud
siggyfreud's Avatar
Nice, I'm using the red version of their FPR. What were you using before that prompted the change?
siggyfreud is offline   Reply With Quote
Old 03-18-2016, 10:24 PM   #638
66ChevyMax
66ChevyMax's Avatar
The below was the original setup, it runs at 58psi I think, supercharger I added needs 66psi.
Craig
Old 03-19-2016, 12:22 AM   #639
Austin_Jim
Cool. Just making sure. I'd hate to see that beautiful ride go up in flames.
Old 03-25-2016, 10:43 PM   #640
66ChevyMax
66ChevyMax's Avatar
You and me both!
Craig
Old 03-25-2016, 10:44 PM   #641
66ChevyMax
66ChevyMax's Avatar
Got the tailgate back on
And a little interior work:
Craig
Old 03-25-2016, 10:56 PM   #642
Winmon
Winmon's Avatar
Looking great!!!!!
Winmon is offline   Reply With Quote
Old 03-26-2016, 02:11 PM   #643
dwcardfan
dwcardfan's Avatar
Man that is looking sweet. I know you are proud to have that setting in your garage.
Old 03-26-2016, 11:55 PM   #644
66ChevyMax
66ChevyMax's Avatar
Thanks guys, it's getting exciting!
Craig
Old 03-26-2016, 11:59 PM   #645
66ChevyMax
66ChevyMax's Avatar
Got some more cab work done today:
Craig
Old 03-27-2016, 12:01 AM   #646
66ChevyMax
66ChevyMax's Avatar
Some might be wondering why am I working over the new carpet, that is a low hump carpet I ordered years ago before I change to a high hump. So figured I would use it, it's much more comfortable to lay on.
Craig
Old 03-28-2016, 10:37 PM   #647
66ChevyMax
66ChevyMax's Avatar
First, does anyone else have gremlins in their shop that hide parts you ordered or saved years ago
Started putting the doors back together tonight:
Craig
Old 03-28-2016, 11:04 PM   #648
Turtleman
Turtleman's Avatar
Yeah... I thought I did,, but it always seemed to find the parts where I left them years ago.. normally in a spot that I wont forget...
I'm told its the 5th sign of senility..............
Turtleman is offline   Reply With Quote
Old 03-28-2016, 11:12 PM   #649
66ChevyMax
66ChevyMax's Avatar
I have a lot of those, "I'll put it right here so I won't forget it" sign of something for sure!
Craig
Old 03-29-2016, 10:11 AM   #650
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
They are everywhere brutha. .. I set traps.. I'll git them little sum biches..
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
