#626 |
Re: 1977 Chevy C10 known as SharkBite
Super pumped right now guys, been searching on the infamous CL for the past 2 days and I've made a super score!
This weekend going to be going to pick up me a Chevy 350 putting the original motor back in the truck and it comes with the Crank and Cam so that's going to be my weekend is starting to clean up the motor and sweet what happens from there guys! Super stoked going to be building and I will do a write up on it as it goes but going to do my best to do a budget build 400whp 350 so stay tuned guys more fun to follow! ![]() Here's the link if you want to check out the block http://houston.craigslist.org/pts/3886226317.html
Korwin 77 C10 Silverado Sharkbite LWB Build 67 Chevy C10 Frame Off 06 Dodge Magnum 2.7v6 aka swag wag! 2010 Honda Accord 2.4I4 DD aka Liquid Metal |
#627 |
Did you buy that block yet?
Scott 87 Chevy 2WD SWB, 88 4x4 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=610652 |
#628 |
No not yet, I'm picking it up on Saturday morning probably.
#629 |
Hey man, not sure if I ever told you but the tires on my truck right now are 235/75/R15
http://67-72chevytrucks.com/vboard/s...d.php?t=580955 http://youtu.be/JYoQJYTXKqI 1984 Chevrolet Scottsdale C10 "Project Platinum C10" 1971 Chevrolet Chevelle "Project Car" |
#630 | |
Thanks for getting me the info on the tires I appreciate it man! ![]()
#631 |
It rubs if I turn the wheels all the way. Not much but some.
#632 |
Maybe I'll still give it a go then!
#633 |
Korwin, I sent you a PM...
#634 |
Replied my man
#635 |
Well the guy I was going to buy the 350 block from has bailed on me so back to searching again....
#636 |
Hers one in your area....http://houston.craigslist.org/pts/3962640286.html
Hope you can track one down..
#637 | |
#638 |
Theres plenty of 350s out there, mainly if you can find an OEM 87 on up roller block with a mechanical fuel pump boss,(dealership options, carbed or Tbi) spider tray and all the roller lifters, youd have one hell of a block. there dressed up with TBI heads.... theres many of them SGI blocks
Her name is Quicksilver 1978 Chevrolet silverado, shortbox stepside currently being swapped IN is a LM7 5300 vortec, 4l80E, factory 4.11s, slammed, a dream ride and coined QUICKSILVER gotta pay $$ if you wanna play ![]() |
#639 | |
![]() Yeah I keep an eye out for them everynow and then see if I run past a good deal haven't found much of anything at this point but I know it will pop up at the right time.
#640 |
I knew I was forgetting something yesterday!
![]() My build has gone on officially for 1 year now, though it may not seem like I've done a lot at times, I've sure came a looooong way from what it was and possibly what the PO intended to do with the truck. So from the bottom of my heart I want to thank everyone who has followed along with my build and help kept me motivated, you guys are awesome and I thank y'all for all the opinions and suggestions y'all give me. Well that's all I have to say for today ![]() I also wanted to say I actually bought a new Dash Bezel from Corts he had a very sharp looking Bezel for an A/C truck so scooped that up and I should have it here by next thursday so I'll post pictures when I get it and install! ![]()
#641 |
Keep up the good work!
#642 |
#643 | |
#644 |
did you ever find an engine?
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#645 |
No I sure did not. I really haven't been on the search for one here recently either.
#646 |
I'll keep an eye out and ear open. I don't search much, but if I come across something before you buy, I'll let you know. You looking for any 350 or specific year range? something salvageable obviously, but what kind of shape? Long block/short block/complete with intake and pulleys???
#647 | |
4bolt preferably, so i think that's pretty much an 80's and up on the block. If I could get a complete set up with everything that'd be great the pulley's and such aren't a must as I want to run a serpentine set-up eventually. I think I have a short block so I'd like to keep that if possible.
#648 |
A short block is just the block with rotating assembly (crank, pistons, rods) and a long block includes the heads, cam and valve train, normally without the intake.
If you don't need the brackets and pulleys, you'd want to replace the timing set and water pump, so really, if you've got or plan on replacing the distributor, intake manifold, valve covers and timing cover, a long block would be fine. If you're going to be buying aftermarket heads, a short block would be better.
#649 | |
#650 |
So as far as condition, are you wanting to completely rebuild the engine using the stock parts, or replace everything from crank, rods and pistons to cam and valve train?
