Old 03-19-2013, 08:24 PM   #626
gdavis
gdavis's Avatar
Re: 1968
Tomorrow I will be re-installing the drive shaft. I hope to get my fan and should on to.
Then maybe I should work on the bed get it together. Trying to get all my body parts back on the truck. When my Brothther-In-Law come down he want have too much to do except the fine tuning on the body work.
gdavis is offline   Reply With Quote
Old 03-20-2013, 12:53 AM   #627
Xeen
Xeen's Avatar
Re: 1968
The truck is comming together fast now, here pretty soon you are going to be ahead of me!
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 03-20-2013, 01:08 AM   #628
Mustard72
Mustard72's Avatar
Re: 1968
Gotta love that new orange motor in that new black engine bay!
Nick
Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986
http://67-72chevytrucks.com/vboard/s...d.php?t=545356
Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears
Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck.
Mustard72 is offline   Reply With Quote
Old 03-20-2013, 07:35 PM   #629
gdavis
gdavis's Avatar
Re: 1968
I didn't know we were racing. But yea that's ok. But now I am slowing down. I still have a long rope to climb.
Old 03-20-2013, 07:39 PM   #630
gdavis
gdavis's Avatar
Re: 1968
Went by your build and the fender is in sad shape. But I know that you can make it look good. I install the bed today except for the wood. Got to paint the truck in a few weeks. Then the fun starts. (wiring)
Old 03-20-2013, 07:41 PM   #631
gdavis
gdavis's Avatar
Re: 1968
Yea I do and I am going to paint the truck kubato orange.
Old 03-20-2013, 07:50 PM   #632
gdavis
gdavis's Avatar
Re: 1968
Today, I finshed bolting down the front inter fender on the pass side. I re-installed the drive shaft. and mounted the bed. except for the wood. Going to paint the truck when my Brother-In-Law does the fine tuning. I think I will go ahead and paint the inside of the truck. So I can start with the sound mat and the wiring and putting the inside of the trck back together. Kubota orange. I have 5 quarts to do the job.
Old 03-20-2013, 07:55 PM   #633
gdavis
gdavis's Avatar
Re: 1968
Guys it is starting tlook like atruck again. I can't wait till I put on some color. I am tired of looking at primer.
After I finshed with the bed I went to work on the front panel for the bed. I wire wheeled and sanded and primed the front panel.
Old 03-20-2013, 08:32 PM   #634
Bomp
Bomp's Avatar
Re: 1968
You should change your name to Rocket cause your blastin through this truck.
Bomp is offline   Reply With Quote
Old 03-21-2013, 02:38 AM   #635
Xeen
Xeen's Avatar
Re: 1968
Man that bed is such good shape I'm envious...sigh
Old 03-21-2013, 09:38 AM   #636
~Whitey~
~Whitey~'s Avatar
Re: 1968
Looks good! What are you doing for wheels and tires?
Jimmy
.69SWB Build.
~Whitey~ is offline   Reply With Quote
Old 03-21-2013, 09:41 AM   #637
mjensen
mjensen's Avatar
Re: 1968
That is looking great!
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 03-21-2013, 09:41 AM   #638
67cheby
67cheby
67cheby's Avatar
Re: 1968
Nice clean work ! That Engine compartment is looking good !
67cheby is offline   Reply With Quote
Old 03-21-2013, 07:19 PM   #639
gdavis
gdavis's Avatar
Re: 1968
Yea, and my body is feeling it now. At 63 and a lot of water has run under this bridge. Just want to drive it without something shaking or making some kind of noise. But thanks for watching.
Old 03-21-2013, 07:22 PM   #640
gdavis
gdavis's Avatar
Re: 1968
I have done no work on the bed, except for small dents about the size of a dime. There is some small holes on the front panel and the drivers side rear fender under the tire rack.
Old 03-21-2013, 07:25 PM   #641
gdavis
gdavis's Avatar
Re: 1968
I don't know as of now. Still looking at some of the builds and getting ideas. I don't know but I do know that I do not want too big of a tire.
Old 03-21-2013, 07:26 PM   #642
gdavis
gdavis's Avatar
Re: 1968
Thanks for saying that. I do try.
Old 03-21-2013, 07:28 PM   #643
gdavis
gdavis's Avatar
Re: 1968
Thanks I have been working it this truck for 7 months now. I am almost ready for some color.
Old 03-21-2013, 07:36 PM   #644
gdavis
gdavis's Avatar
Re: 1968
Well, today I just couldn't get into the truck. I guess I am tired and need a break. I did adjust the tail gate now it raises and lowers with ease.I need to order a set of chains for the gate. I think I will go with stanless maybe chrome. They say chrome will get you home.
Next I installed the front bed panel on the bed. I am not satified with the bolts I used. It was all I had on hand. I am going to get some button heads for the inside of the bed. But, that will be after I have painted the bed.
Old 03-21-2013, 07:43 PM   #645
gdavis
gdavis's Avatar
Re: 1968
I have a question? Is there anything that goes under the bed rails? I just don't remember. The mind is the first to go. Between the rails and the supports for the bed.
I looked in several mag. They do not show anything. Again it looks like there should be at least a spacer or something. To bring up the two front and the two back bed rails so the center will be level with the other four. Not counting for the 1/4 inch pads. I know that they go there.
Old 03-22-2013, 07:48 PM   #646
gdavis
gdavis's Avatar
Re: 1968
Had to back track a little today. I pulled the front clip off the truck. 6 bolts to remove the front clip. I needed to do some more adjusting on the pass door. It had too large of a gap on the rear of the door. My neghbor came over and seen the gap and asked me if I was going to leave it like that? I told him that was all I could take out. It always good to have fresh mind to look at a problem. So now I have the right gap at the door. I am really satified with the results.
Old 03-22-2013, 07:58 PM   #647
gdavis
gdavis's Avatar
Re: 1968
After I finshed with the pass door. I cut the bottom 4 inched off te drivers side bed fender. It looked like someone shot it with a shotgun. At least two dozen rust holes. I made a repair panel for the fender. Tomorrow I will weld it back on the truck.
Old 03-22-2013, 08:06 PM   #648
gdavis
gdavis's Avatar
Re: 1968
There was a few holes in the front bed panel. I bondoed them up. Sometimes I amase myself. It came out real nice. There were three holes on each side. Like something was against it and rubbed holes in it. anyway it's gone.
Old 03-22-2013, 08:10 PM   #649
gdavis
gdavis's Avatar
Re: 1968
This is my last repair I have to make. I think I will through myself a finish party and have a coors light to celebrate.
Here is a picture of the bad section of the fender.
Old 03-22-2013, 08:27 PM   #650
gdavis
gdavis's Avatar
Re: 1968
bad fender before repair
