Old 05-27-2014, 09:14 AM   #626
Coach529
Coach529's Avatar
Re: 1949 Chevy 3600 into a daily driver
Originally Posted by 99 to Life View Post
good job, I'm backing you on the manual box too.
I just could not bring myself to do the power steering.....not at this time anyway.
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 05-27-2014, 11:28 AM   #627
Coach529
Coach529's Avatar
Think I have all my bases covered. I just have a couple loose ends.
Any suggestions on what to use as a throttle pedal?
TH350 transmission to a 4 x 4 blazer rear end. Any idea's on a approx driveshaft length or a suggested donor?
1949 Chevy 3600
Old 05-27-2014, 11:37 AM   #628
Katrina/10
Katrina/10's Avatar
I used a 73 87 type truck cable and pedal in mine. S 10 or car drive shaft should work if you can find one long enough.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 05-27-2014, 02:07 PM   #629
Coach529
Coach529's Avatar
Thanks.......I will check it out!!
1949 Chevy 3600
Old 05-27-2014, 03:58 PM   #630
nvrdone
Coach - truck shop has a v8 linkage conversion that works great. I have it in my 49 with a 327 - uses the stock gas pedal
p/n 53-08315 about $51.00
nvrdone is offline   Reply With Quote
Old 05-27-2014, 04:43 PM   #631
Coach529
Coach529's Avatar
That is awesome. Love the fact that I can keep my stock pedal. Thanks!!!
http://issuu.com/truckandcarshop/doc...-59_13_web/107
1949 Chevy 3600
Old 05-29-2014, 12:06 PM   #632
made2drag
made2drag's Avatar
Awesome build....by far my favorite AD on here
made2drag is offline   Reply With Quote
Old 05-29-2014, 12:11 PM   #633
Coach529
Coach529's Avatar
Thanks man......I am getting anxious to get him on the road!!!
1949 Chevy 3600
Old 05-29-2014, 01:46 PM   #634
dubie
dubie's Avatar
I found the same thing with my 56 too. Once we lowered it and dropped the small block in there, power steering really isn't needed. The added weight, lower center of gravity and changing the geometry of the steering arm made the truck turn quote easy
Loving the build bud, my favorite Advance design build on here
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 05-29-2014, 01:49 PM   #635
Coach529
Coach529's Avatar
Thanks man!!
1949 Chevy 3600
Old 05-29-2014, 06:25 PM   #636
NEWFISHER
NEWFISHER's Avatar
coming along nicely! looks like a heated floor in the shop? lucky dog
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 05-29-2014, 06:58 PM   #637
Coach529
Coach529's Avatar
Yes sir............the heated floor was awesome this past winter!!
1949 Chevy 3600
Old 05-29-2014, 10:01 PM   #638
Coach529
Coach529's Avatar
Always work to finish and projects.....but the new shop is a godsend. Soo much more room than my old one!!
Although.......they are never big enough..........
1949 Chevy 3600
Old 05-30-2014, 11:52 PM   #639
Coach529
Coach529's Avatar
Spent some time today cleaning up the frame for paint.
63 years of grease, oil and dirt covered the drivers side. Between a wire wheel on my 4-1/2" grinder, a putty knife and a healthy combination of degreaser and some hot water I got it clean.
I fought rain showers all day....
After the degreasing and cleaning I sprayed the frame down with KBS Rust Blaster and rinsed it again with hot water.
I rolled it into the shop and let it dry for a couple hours and brushed on a coat of KBS Coatings Satin Black. Turned out pretty good. I will follow up with a couple more coats over the weekend.
All my gaskets and misc parts showed up for the 350, so I hope to start buttoning that up this weekend as well. Maybe even get it painted!!
1949 Chevy 3600
Old 06-01-2014, 10:11 PM   #640
Coach529
Coach529's Avatar
Crazy busy weekend......but the motor is in primer.....
1949 Chevy 3600
Old 06-03-2014, 01:08 PM   #641
Coach529
Coach529's Avatar
Motor is now orange......
And my Lokar shifter showed up.......whoohoooo
1949 Chevy 3600
Old 06-03-2014, 01:23 PM   #642
dubie
dubie's Avatar
What length of shifter did you go with?
Old 06-03-2014, 01:53 PM   #643
Coach529
Coach529's Avatar
Went with a 23" long one.......pretty much exact same height as the stocker.
1949 Chevy 3600
Old 06-05-2014, 11:36 PM   #644
Coach529
Coach529's Avatar
I took the day off work and got some stuff accomplished.
I ended up damaging the rear brake line when I put in the tranny cross member, so I re did that. The passenger front brake line was routed next to the old tranny cross member, so that had to be redone as well.
I drilled the holes and bolted in the new transmission cross member. I bolted on the new aluminum intake to the SBC, as well as installed a new oil pan gasket.
I installed the stall converter on the TH350, and was ready to bolt the flex plate to the engine when I realized the bolts are 7/16" fine thread. None of those in my bolt bin.
Oh well.......I will get it done tomorrow and toss the motor and tranny in.
My HEI Distributor and plug wires showed up from Speedway. Sure nice having those guys only 1 shipping day away.
I am running an aluminum water pump, measures like a short pump. I picked up a pulley today at the junkyard, but it looks like I would need to space out the pulley 5/8" to match the crank pulley. Does not make sense. The pulley came off a mid 70's GMC truck with a SBC.
Any advice on mufflers? I plan on piecing together the exhaust myself. The local muffler guy wants almost $500. I can weld and bend pipe.......only concerned about flaring.
1949 Chevy 3600
Old 06-06-2014, 07:23 AM   #645
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Your short pump pulleys needs to come off of a 72 and earlier truck. They went to long pumps in 73. That's why you're having pulley alignment issues.
Old 06-06-2014, 09:07 AM   #646
Coach529
Coach529's Avatar
The crank pulley is the original (70's nova), so that would be for a short pump right? Confused.
1949 Chevy 3600
Old 06-06-2014, 09:48 AM   #647
Tx Firefighter
No sir. Cars, excepting Vettes went to long pumps in 69, I do believe. Trucks held onto short pumps until 73 for sure. Any 70 whatever Nova will absolutely be long pump. Vettes kept short pump till 81.
Old 06-06-2014, 10:30 AM   #648
Coach529
Coach529's Avatar
OK, so I need a short pump crank pulley, and a short pump water pump pulley. Back to the junkyard!! Thanks.
1949 Chevy 3600
Old 06-06-2014, 10:21 PM   #649
Coach529
Coach529's Avatar
Pretty good day despite distractions and multiple trips to the hardware store.
Got the bolts to mount up the flex plate and got the tranny attached to the motor.
Everything went together fairly smooth.
I did overlook during mockup that the fuel pump would hit the frame. A quick cut with the jig saw and some grinding and it was fixed.
Off the jack stands and pushed outside so I could clean out the shop!!
1949 Chevy 3600
Old 06-06-2014, 10:34 PM   #650
youngrodder
youngrodder's Avatar
Looks great. You are well on your way.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
