Closed Thread
Old 05-05-2014, 04:28 PM   #626
mcm1209
mcm1209's Avatar
Re: What did you do to your truck today? Chapter II
Now what?????????????
(Torch was not there to cut, had to heat up the rivets a bit to get the old cab mounts off)
mcm1209 is offline
Old 05-05-2014, 05:16 PM   #627
Elliot949
Elliot949's Avatar
Attachment 1250349
Looks like a Stacy David type of Cut... Nice work... Slide it all together... make sure you are square and level then weld away...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD
Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847
Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD
B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210
Elliot949 is offline
Old 05-05-2014, 06:16 PM   #628
Econman
Econman's Avatar
I cleaned, primed and painted one head... Doing the second one tomorrow... while the waiting continues...
Econman is offline
Old 05-05-2014, 09:44 PM   #629
In The Ten Ring
The last of the fuel lines are now out! It was a bit of an annoyance but I managed to remove these without resorting to cutting or even bending.
I am a bit fearful of putting the new ones back in, just because it was so much hassle getting the old ones out and I'm even considering using braided steel lines for replacements but I think I can do this.
In The Ten Ring is offline
Old 05-06-2014, 07:02 PM   #630
jtwells
today i replaced the old rusty Grant gt steering wheel the PO had installed with a wheel i took off of an old column that was laying around.
jtwells is offline
Old 05-06-2014, 07:53 PM   #631
BugzC10
BugzC10's Avatar
Finished installing Alan Grove power steering pump bracket. Now I have better clearance between the pump shaft and the alternator belt.
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 05-06-2014, 09:42 PM   #632
jlaird
jlaird's Avatar
Man, what an improvement over the Grant. Love the three gauges under the dash. Classic look!
jlaird is offline
Old 05-06-2014, 09:52 PM   #633
jmking9
jmking9's Avatar
Where did you get your alt brackets? I like those.
1970 SWB Build
jmking9 is offline
Old 05-06-2014, 09:55 PM   #634
bowcoffin
I pulled the 350 out of my 68 C20! Took all day but I am stoked to be able to get in and clean er' up! Going to paint the engine pocket black and the engine and trans red! Stoked!
bowcoffin is offline
Old 05-06-2014, 10:07 PM   #635
Econman
Econman's Avatar
Size:  42.9 KBPainted the second head today... Hoping my new rods that have been back ordered for 5 weeks now finally ship tomorrow...
Econman is offline
Old 05-06-2014, 11:41 PM   #636
Mike_The_Grad
Mike_The_Grad's Avatar
Finally everything is bolted on.fuel lines , new power steering hoses and new belts installed. Vacuum lines next, and then on to core support and body panels so electrical has a place to lay.
1972 C/10 LWB - Mine
1964 C/10 LWB - My Dad's
Instagram: Mike_The_Grad
Mike_The_Grad is offline
Old 05-07-2014, 01:31 PM   #637
zbm100
saved it from the woods
zbm100 is offline
Old 05-07-2014, 02:10 PM   #638
chopnchaneled
chopnchaneled's Avatar
You did REAL ! Good!
I don't think we get smarter as we get older. We just run out of Stupid things to do.
chopnchaneled is offline
Old 05-07-2014, 02:20 PM   #639
zbm100
thanks
zbm100 is offline
Old 05-08-2014, 03:13 AM   #640
Mike_The_Grad
@zbm100 that is awesome. Plus the pic , just so everyone knows exactly what you mean by "the woods". lol.
Old 05-08-2014, 06:46 AM   #641
BugzC10
BugzC10's Avatar
I got mine on eBay. Look up Alan Grove web site. They come in bare metal. You have to plate or paint them. I had to open up the two holes that attach the bracket to the front of the block to get it all bolted together. Kind-of a PIA in that location with the engine installed.
EDIT....I bought it on Amazon.
BugzC10 is offline
Old 05-08-2014, 02:38 PM   #642
zbm100
not good
zbm100 is offline
Old 05-08-2014, 04:15 PM   #643
Andy4639
Old member
Andy4639's Avatar
Talking Re: What did you do to your truck today? Chapter II
Installed a new Sony head unit with bluetooth! I'm ready for the Power Tour now. Just have to figure it all out and how to use it. I have the Iphone stuff figured out pretty good I think.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline
Old 05-08-2014, 04:25 PM   #644
BlacklandCamper
Did this...
http://youtu.be/vAaT_juP-Ms
Took it for a little longer cruise around the area later that day, only to run out of gas, and collapse my fuel filter.
Still have some fine tuning on the carb, and some issues inside the steering column to address.
Its getting there.
Grunt: 1971 C20 Custom Camper. Runs/Drives/Kinda stops. 350Ci, TH350. 4.10:1 D60. Eight Lug LWB is more better. Hell no its not fast!
Donkey: 93 Nissan D21, the farm truck. My 1/2 ton SWB. The Indomitable Datsun.
1st BN 3rd MAR. '00-'04
BlacklandCamper is offline
Old 05-08-2014, 04:48 PM   #645
In The Ten Ring
I spent $50.00 dollars and bought all the tubing, hoses, and most of the clamps I need for the fuel line replacement. Lucked up and caught the tubing 1/2 off! I still need the extra filter and a couple more clamps.
Old 05-08-2014, 10:52 PM   #646
Molberg
Molberg's Avatar
Finished the bodywork on my box!
-Project Nitemare-
http://67-72chevytrucks.com/vboard/s...d.php?t=607359
Molberg is offline
Old 05-08-2014, 11:41 PM   #647
BADAZ chevy guy
BADAZ chevy guy's Avatar
Installed the radiator, new vacuum advance in the distributor, 2 new tires on the back, 1 new headlight, new spark plugs. Tomorrow I take it to get inspected!
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182
700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236
BADAZ chevy guy is offline
Old 05-08-2014, 11:55 PM   #648
In The Ten Ring
Oh wow! Good luck.
Old 05-09-2014, 08:54 PM   #649
Ridgeclimber
I got the windshield and rear glass installed today. Then instal a new dash pad and started to assemble the glove box.
Ridgeclimber is offline
Old 05-09-2014, 10:00 PM   #650
BADAZ chevy guy
So, it didn't pass inspection. failed because of one ball joint and there's no windshield washer.
Closed Thread
