Old 10-13-2015, 09:32 AM   #626
reaper71
reaper71's Avatar
Re: Dutch '59 Fleetside Longbed
Nice Progress Kees!
reaper71 is offline   Reply With Quote
Old 10-19-2015, 04:06 PM   #627
RockinKees
RockinKees's Avatar
Originally Posted by Kim57 View Post
Looks real good.
I like the back glass idea.
Kim
Thanks Kim!
Hope it works out the way I want. Spraying paint on glass is a different discipline
reaper71
Nice Progress Kees!
Thanks Mark!
Some small things done this time:
Painted the back of the cab.
First semi gloss black:
Then white:
Then finally, two coats of high gloss red:
In the near future, when all is dry enough, I pinstripe a fine white line between the black and red.
Now some fabwork again, the doorlatches...
You probably know I use BMW latches. I want the original doorhandles to work with de BMW latches, so some fabwork is required.
To freshen your memory:
Some ordinairy homemade steel parts:
Turned a bushing that goes over the pin of the doorhandle:
Fast forward.....made the ordinairy steel parts into something I could use
When you push the doorhandle, this is what it looks like, actuated:
After several times of pushing the handle and lock and unlock, I made an adjustment: I made the lower lever 5 mm longer, now it's way better
Also it's fully adjustable by turning the bushing or the nuts
It's now rough, but it gets cleaned up before the steel plate covers it all
Again, this plate is going to be a lot nicer when I'm finished....
Next is to make the inside handle to work with this latch, but that should be an easy task...
Also, I wanted to use the electric BMW lock motors, the black box on the top of the latch, but that doesn't work, I don't have the room for it anymore.
Now I have to search for an aftermarket Central lock system that works with this latch. I think an universal set will work, we'll see.
Till next time!!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 10-19-2015, 04:29 PM   #628
Kim57
Kim57's Avatar
Looking real nice.
Nice fab on the door latches.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 10-19-2015, 05:08 PM   #629
oldman3
oldman3's Avatar
Kees, nice job on getting everything to work, and adjusted. Once cover is done it will look great...Jim
oldman3 is offline   Reply With Quote
Old 10-21-2015, 03:07 PM   #630
RockinKees
RockinKees's Avatar
Thanks again guys!
Quite day at home...
A few weeks ago I cleaned the hood emblem.
Now all emblems are painted the way I wanted, it looks great!
Too bad I don't have the "Fleetside" emblems....
As it was when I bought the truck:
After cleaning:
Painted, you can hardly see the difference
Next I made some indicator lights ( or Idiot Lights as some of you call them ) and drilled them into the dash.
A high beam indicator, which is blue in Europe, at the original place, at the left side of it, a red charging light, and at the right side a yellow brake fluid warning light. All LED's.
Cheers!! Kees.
Kool Guyz CC
Old 10-21-2015, 04:32 PM   #631
lowrodderchev
lowrodderchev's Avatar
I'll keep a eye for some if your looking. Once in awhile they pop up on Craigslist
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 10-21-2015, 04:57 PM   #632
Kim57
Kim57's Avatar
Very nice looking stuff.
Kim
My build thread
Old 10-21-2015, 05:50 PM   #633
RockinKees
RockinKees's Avatar
Thanks! That would be nice!
If only I could afford it then...
Cheers!! Kees.
Kool Guyz CC
Old 10-22-2015, 02:14 PM   #634
RockinKees
RockinKees's Avatar
Spent the whole day making door latches
I think I've got them covered, besides the paint that is:
Only thing now is connect the inside doorhandles and make a central locking system.
So, on to clean the doors and put some paint on them!
Again, a little problem off the list
Cheers!! Kees.
Kool Guyz CC
Old 10-22-2015, 05:42 PM   #635
lower50's
lower50's's Avatar
Lookin good I'm using similar led lights in my truck.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 10-23-2015, 02:51 PM   #636
Cuttin up
Cuttin up's Avatar
Late to the party, just read your thread all the way through today. Fantastic job, always amazed with what folks do with what they have around in other countries. Keep up the great work.
Cuttin up is offline   Reply With Quote
Old 10-23-2015, 06:16 PM   #637
Advanced Design
Advanced Design's Avatar
Kees, that is some nice work there on the door latch and led's. Very creative!
Advanced Design is offline   Reply With Quote
Old 10-25-2015, 09:21 PM   #638
deejaaa1
you are doing a fantastic job. looks sharp.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years.
96 ECLB 2500, 6.5 diesel, auto, gone.
Originally Posted by gottattooz View Post
...68 Chevy Shortbed... guy clearcoated..and...threw glitter all over it...like he was feeding chickens!!!...
deejaaa1 is offline   Reply With Quote
Old 10-27-2015, 04:36 AM   #639
bogape
Hi Kees
A quick question about the inspection.
You say you had to change the headlights.
Did they not like the US ones?
Also do you have to drive there or can I take on a trailer?
I have my inspection in 4 weeks.
thanks
Nick
(Englishman living in Holland)
bogape is offline   Reply With Quote
Old 10-29-2015, 04:13 PM   #640
RockinKees
RockinKees's Avatar
Nick, sorry for the late replay...
Sealed beam headlights are allowed nowadays, IF they give a good image, I mean you must have a certain line between the light and dark side of the light, as you have with halogen headlights.
Mine were not at the right hight, so there I was unlucky....
I also changed them because of the amount of light the halogen gives instead of sealed beams.
You can drive there, but you have to get an insurance and a day registration. That day of registration is called "éendags kenteken" in Dutch, it's free of charge. You can get it online at the RDW website.
It's only valid on the day of inspection.
If you use a trailer, you don't have to have an insurance or an "ééndags kenteken". It's what you prevere...
Where is your inspection taking place?
If you have any further questions, please ask!
Oh, and when will we see your buildthread coming??
Cheers!! Kees.
Kool Guyz CC
Last edited by RockinKees; 10-29-2015 at 04:15 PM. Reason: forgot some important stuff.....
Old 11-02-2015, 06:47 AM   #641
bogape
Kees, thanks for all the info.. really appreciated.
My inspection is in Utrecht
If there are things wrong (likely!) then what is the process for retesting? Do I have to do another full test?
I haven't done a build thread yet, as progress is quite slow... I will have to find out how to load photos then do something... at least you have to recognise me if we meet on the road!!
Also any tips on insurance companies over here?
Old 11-02-2015, 04:27 PM   #642
RockinKees
RockinKees's Avatar
What should go wrong??
If all is in reasonable good shape, all lights work, turning lights, brake lights, low beam, high beam, you have brakes and a horn and not too much space at the steering and wheelbearings...you'll be the King!
If something is wrong, they only inspect those items, not the whole truck again.
For insurance you have to call a few, the companies are not used to big Americans overhere....
Mine is insured via my agent by Aegon, but take a look here:
http://www.oldtimerverzekeringvergel...g-vergelijken/
Slow build? Some guys are years in the build and they have a thread
Start one yourself, and you will see that your coming "problems" are easily solved
And we all love pics!!
Cheers!! Kees.
Kool Guyz CC
Old 11-03-2015, 10:33 AM   #643
reaper71
reaper71's Avatar
Looking really good Kees!!! love the 2 tone..
Old 11-18-2015, 04:16 PM   #644
RockinKees
RockinKees's Avatar
Small update this time.
Due to my downtime on wrenching, I like to pinstripe and make LowBro Kustom Art.
And maybe you noticed here or there, I am a Greaser, so the truck gets some of that art too.
I took the glovebox and painted it:
The Design:
Black and white stripes done:
Old Chevy logo in Silver with clearcoat in between the stripes:
Next was the aircleaner. It's a cleaner for propane filter, only 10" diameter:
This was fun doing.
In all my American Iron I always had homemade Tiki Shifters.
This time I am making something different: a giant Sparkplug out of an wooden pepper mill with aluminum turned parts
It's not ready yet, but I'll give you a sneak preview:
When it's ready I give you a full How To
Cheers!! Kees.
Kool Guyz CC
Old 11-18-2015, 05:03 PM   #645
Kim57
Kim57's Avatar
Very cool stuff.
Kim
My build thread
Old 11-18-2015, 05:08 PM   #646
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Awesome work!!
ChuckDriver is offline   Reply With Quote
Old 11-18-2015, 08:00 PM   #647
oldman3
oldman3's Avatar
Nice job...Jim
Old 11-18-2015, 09:55 PM   #648
Advanced Design
When I started at the top of the page and started scrolling down to see the updates, I was thinking about your pinstriping art. Little did I know we would get to see some. Very nice work Kees! You are really talented.
Old 11-19-2015, 09:57 AM   #649
lower50's
lower50's's Avatar
Very nice work on the pinstripe. Love the shifter so far. I'm using beer tap handles.
1951 MG TD
Old 11-19-2015, 11:49 AM   #650
55 Chevy Dave
55 Chevy Dave's Avatar
The pin striping looks great! I also like how you two-toned the dash! Keep up the great work!
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=654899
55 Chevy Dave is offline   Reply With Quote
