Closed Thread
Old 03-08-2015, 03:25 PM   #626
rudyyloverboiii
Re: What did you do to your truck today part III
Originally Posted by pimpston65 View Post
thks, i bought the 292 for $100. had it totally redone new head,piston over bore, the works. all before i got the suburban, it was stuck in canada dealing with customs crap. all i knew was it had a pontiac 283, that wasnt original. so i research'd and 292 kept coming up as the engine to have so thats what i went with, now since my build is here and an NOS beast i would have saw the mounts and got a 250, also in canada gm has a place you can get info on older vehicles so i got that info and sure enough my burban came with a 250, oh well... do you have a build thread?
Not yet sir. Ive done a lot to mine though. I have pictures. I started putting pictures up on a different blog to remember maybe i'll post them here as soon as i figure out how tp put em up wit ma phone.
rudyyloverboiii is offline
Old 03-08-2015, 07:22 PM   #627
TJ's Chevy
TJ's Chevy's Avatar
Worked on my new 64 a bit. New tires(not shown in pic) and had a set of plug wires layin around that I put on, also found out that wires 4 and 6 were crossed so fixed that and the thing runs like new. Also found some blow by through the oil fill hole. Not a blown head gasket to my knowledge( no bubbling water) so looks like I might have a bad valve guide. Compression test in the making. Ah well, runs super good though.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline
Old 03-08-2015, 08:12 PM   #628
Like the 4-eyed look TJ!
Palf70Step is offline
Old 03-08-2015, 09:35 PM   #629
pimpston65
pimpston65's Avatar
20 BAGs of nuts,bolts and washer. that what it takes to attach everything to my 292. im sure there are some stray bits. now off to have black phosphate coated!!!
pimpston65 is offline
Old 03-08-2015, 09:56 PM   #630
pimpston65
pimpston65's Avatar
cant wait to get this butte dirty, grand canyon or bust roadtrip!!!
Old 03-08-2015, 11:20 PM   #631
Turtleman
Turtleman's Avatar
Coming to Arizona Pimpston65?
Turtleman is offline
Old 03-08-2015, 11:33 PM   #632
TJ's Chevy
TJ's Chevy's Avatar
Thanks man! lol I got a 3 stooges crew now!
Old 03-14-2015, 05:24 PM   #633
Grizz1963
Grizz1963's Avatar
Not much........
Just a quickly tonight.
After lunch time, Martin came over to change the drivers door glass in the MX5 for me, took him a total of 18 minutes to remove the donor glass and fit it, and close up the cars door. WTF?? Talent or what.
Then I had planned to remove the towbar and paint it all, despite knowing it was far from right as it was mal-aligned and to pack it away before starting the blasting as I have done nothing with it the last couple of weeks.
Martin again forced me via my own vanity and realisation that geometry was not my friend to take the whole lot apart and redesign it all.
Then to cut, grind, fit and tack it all together.
Tacked the corners, then disassembled and started to weld it all up.
At this point the welded decided to go to sleep, so I shut shop and came indoors.
Tomorrow we continue.
Looking forward to wrapping up this bloody towbar and getting on with other stuff.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline
Old 03-14-2015, 08:14 PM   #634
Lugnutz65
Lugnutz65's Avatar
I finished stripping the DS inner door shell. Still need to weld the new bottom into place after a do a little media blasting. This was hard work. Polycarbide disc on a grinder for the flat surfaces and a drill with a wire wheel for the tight areas. Now it shines like a piece of tin foil.
I also installed a Jeep Cherokee door check on my PS door. Now the door opens with 2 detents. It's a nice easy bolt on upgrade.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline
Old 03-14-2015, 10:30 PM   #635
Joemomma1
Joemomma1's Avatar
I got the same door checks that i pulled from the jeeps but I've seen a different version with rubber mentioned on other posts. Do you know anything about those things?
Joemomma1 is offline
Old 03-14-2015, 10:35 PM   #636
revjames
What year jeep
Cherokee
revjames is offline
Old 03-15-2015, 12:25 AM   #637
pimpston65
pimpston65's Avatar
yup this summer
Old 03-15-2015, 01:56 AM   #638
mattbert56
mattbert56's Avatar
Hung out with my buddy who I have been trying to get on this forum site. He's got the 51. And helped him pull the 55 out of the field with my little toyota so we can start Swapping on the painted body parts. Also got a full size spare and matching rim for 20 bucks. Picked up new front lift springs for the truck and a set of Y Pipes for the truck. For 10. Super stoked about Those.
Well that didn't go as planned.
1965 k20 buikd thread: http://67-72chevytrucks.com/vboard/s...=628346&page=6
mattbert56 is offline
Old 03-15-2015, 07:34 AM   #639
canadian_diesel1964
New Interstate battery, 1 wire Alternator, Belt and Battery ground...she startts real good now
canadian_diesel1964 is offline
Old 03-15-2015, 08:04 AM   #640
Lugnutz65
Lugnutz65's Avatar
Originally Posted by revjames View Post
What year jeep Cherokee
This link about the Cherokee door check says 1984-2001, but only Cherokee, not Grand Cherokee.
The link mentioned shows the version with the rubber stop, like you have. I bought a pair of those too but decided to go with the set without the rubber stop. If the rubber stop part gets rotten, then it can fall off and that will allow the door to open TOO FAR, which is the same problem the factory door check has. When the door opens too far, then you get a dent in your door from the rear edge of the front fender.
The version I chose to use is all metal, so no rubber stop to dry up and crumble. However, it could still fail from metal fatigue. If I only had the rubber stop kind, I'd still use them if the rubber was in good shape.
Here are some links about the Cherokee door checks.
FAQ Link
Van Pershing Main Idea Page Link
Old 03-15-2015, 03:32 PM   #641
Grizz1963
Grizz1963's Avatar
Today the weather turned wet and cold again, so I finished the final welding on the towbar, tried it out for fit and then removed the lot, including mounting plates, took the flap wheel to the lot and cleared the rust and tidied the welds.
Then the parts that will be sliding inside the receiver got a coat of rattle can black, just to cover the metal as well as the ball bolt heads.
I decided to hold off on the Hammerite till the weather is more conducive to drying.
Last year I bought a new triple chromed front bumper for my truck, problem was, it was a damaged item that I was prepared to take a gamble on to try to repair.
When Offering it up to the truck, it came up that the passenger side tip was bent in by 40mm meaning it could not even be fitted.
I am also painting the rear of both new bumpers as they often rust there despite the chrome, obviously because most of us do not wash, dry or polish the rears of our bumpers.
So at lunch time I contacted mate Darren who is a local rodder with a machine shop to see if I could come down to his place 30 miles from where we live, to use his 8 ton hydraulic press to try tease out the crease in the bumper, he agreed, as long as I was done before 13.30 as he still had Mother's Day to deal with.
My old and new bumper in front of the press.
When trying to determine where the energy had entered the bumpers tip when it fell from the top of a shipping container and thus how to press it to return it to shape, I realised that hooking it into Darren's forklift truck, and persuading it with a large lump hammer while putting pressure on it in the opposite direction would work.
So within 10 minutes we had the bumper straightened out and that without any damage to the chrome.
So the gamble pair off, for once.
While I was there, Darren was also busy preparing some of his cars for Easter weekends Chatham Festival of Steam show.
Thanks again to Darren for the help and offer of machinery.
Old 03-15-2015, 05:19 PM   #642
Grizz1963
Grizz1963's Avatar
Thought I would post this up on here as well.
Feeling good, as the bumper came out good, and now I got more of what I wanted/needed.
Just spent £63.00 on a bid in the last 10 seconds on Evilbay and won a pair of used vent windows.
The passenger window on my truck is very rotten, and judging by the photos on the ad, these should be an improvement, as these parts are not re manufactured or readily available out there.
Also never seen them for sale here, and plan B which would involve Don in Arkansas and trawling multiple breakers yards till he found a pair for sale, then adding in postage, taxes and the risk of them arriving intact, meant that I needed to hit the bid button quite high.
Hopefully Disasterbus will be able to pick them up for me some time this week.
So there you go, now my weekend is over.
Old 03-15-2015, 09:42 PM   #643
XLCOR_65
XLCOR_65's Avatar
I took the sand bags out of the bed, cleaned her up, and took her for a nice long Sunday drive! Such a gorgeous day out in the Ozarks!
1965 C10 LWB SBW, 292, SM420
1963 Chevy II SS
1951 Chevy Business Coupe Gasser
1949 Willys Overland
XLCOR_65 is offline
Old 03-15-2015, 09:48 PM   #644
mattbert56
mattbert56's Avatar
Sanded my apache 10 hood down to Its original color. Then to 320 g and waxed it. Also got the cab and bed bolted down to the new frame and aligned the trim. Nice and straight Now.
Old 03-15-2015, 11:06 PM   #645
mattbert56
mattbert56's Avatar
Forgot pics. Oops.
Old 03-16-2015, 07:09 PM   #646
jb9281
jb9281's Avatar
Here is a current picture of my truck and the custom autosound radio I installed. A friend of mine made a faceplate for me out of oak. My dash had been butchered up. I think it looks really good now.
jb9281 is offline
Old 03-16-2015, 08:23 PM   #647
Lugnutz65
Lugnutz65's Avatar
It does look good. In fact, it looks great. You've done a nice job.
Old 03-17-2015, 10:47 PM   #648
jbgroby
jbgroby's Avatar
Got the front and rear glass installed tonight! Getting a little closer every month
jbgroby is offline
Old 03-17-2015, 10:48 PM   #649
jbgroby
jbgroby's Avatar
Front glass
jbgroby is offline
Old 03-17-2015, 11:08 PM   #650
mattbert56
mattbert56's Avatar
Looking good
Closed Thread
