#1 | |
Re: What did you do to your truck today.The 3rd chapter
Vendor at the truck nationals was selling one pound disposable cans for 40$
Just spent a crapload of $$ to get the tranny fixed in the 96 Silverado (along with a transfer case seal, rear main seal and new U-joints) so I can drive it instead of using my 67 GMC as a daily driver.
![]() Join Date: Feb 2019
Removed front and back glass for Upper cab paint this weekend, new glass to install and new door weatherstrips.
Minimal rust found which is always a plus.
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
BlahBlahBlah
Nothing ... again
In the process of disassembling the step side bed. Got all the old wood out and the fenders and steps off.
Bed sides probably usable as well as the sills. Bed front and rear cross sill will have to be replaced. Few more bolts and I’ll have it all apart. Will probably jump to cleaning up rear frame and do rear brake and suspension work before tackling stripping the bed for primer. |
laying low
![]() Join Date: Mar 2001
turn
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver 'primer is finer' Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
laying low
I have my step bed nearly as disassembled as yours. I bought a new headboard, cross sills, corner angle strips and floor strips for mine along with all new hardware. My bed sides are in pretty good shape. I hope to blow mine apart before long and get all that done.
Boog,
Where did you order your bed parts? I’ll need angle strips as well. And all the bed wood and hardware as well but I’d like to get all the metal parts first. Getting this apart for easy access to the rear frame to do brakes, springs, and all the usual stuff. |
Got her off the trailer and started my plans for a build. Made a deal to have a 454 built for her. Started planning my drum to disc swap and in my mind decided to paint her bright red instead of the dark maroon color. Will build her with my 21 year old son, so I'm excited to get started.
#10 | |
laying low
Finished up the air box .
![]() Join Date: Aug 2019
I started drilling out about a 1,000 spot welds on the donor lower cowl vent. Then I can drill out the one on my truck. Going to replace the rusted cowl.
#13 |
Made a apron bracket, finished making my filler panels(still need to paint them) and cleaned her up.
#14 |
-Chris
![]() Join Date: Sep 2002
Started putting on the Wilwood disc brake kit on the rear end until I realized I had the wrong Moser axles.....so, I went ahead and put the front bumper on and got a brake pedal assembly coming from SpecialyRetail this week. Going back at it next weekend....
1970 Chevy C-10 P/U, Shortbed, Fleetside - 5/7 drop, 496, TH400, 12 bolt. BUILD THREAD - http://67-72chevytrucks.com/vboard/s...d.php?t=404481 2012 F250 Super Duty P/U - intake, exhaust, tuner, 4" lift with 35's 2017 Chevy Suburban (Wifes Car) - Fully Loaded & Stock "Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem." Ronald Reagan, President of the United States; 1985 |
#15 |
Finished up the passenger door piller
#16 |
Removed the snorkel
#17 |
So I carefully cut the frame
#18 |
![]() Join Date: Dec 2012
A friend helped me along in my interior project by painting these interior parts for me
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
#19 |
Built me a custom 6 AWG alternator ground cable. Used Lowes primary wire @$0.93/ft and some terminals I had in my junk drawer. Will ground this sucker to the frame and be done with it! -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#20 |
Old member
I ordered new trim for my ramp truck this past week. So I decided to see how hard the trim removal would be. It turned out not being bad at all.
The drivers side was gone and only had the 3 screws to get out. I used my saws all on them and the passenger side they came right off. I even saved the wedges for inside the fender for the new trim. I took the trim piece and straightened it best I could. I may end up putting the new trim on my daughter's truck and using her old trim on the ramp truck.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#21 |
Got an S10 steering wheel (been looking for a long time!) from a salvage yard for dirt cheap and in great shape. Had an 88-92 Chev steering wheel before and this gives me about 1" more of belly room
I love it. AND, I can see ALL of my gauges without making an effort. SCORE! (yes, I painted the letters and horn logo to match the interior).
#22 | |
![]() Join Date: Nov 2014
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
#23 | |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
#24 |
I'm ALMOST positive that it came on 86-91's.
#25 |
I can confirm 1991. My Blazer has that wheel.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
| Bookmarks |
