#6626 |
Re: What did you do to your truck today!
Installed a new intake and HEI distributor
Posted via Mobile Device Posted via Mobile Device
Jeff 1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt 1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior |
#6627 |
Got Big Orange back on the road Saturday with new timing chain,water pump, thermostat and also added some new valve cover gaskets. Runnin great now!
Somedays your the windshield and somedays your the bug! |
#6628 |
![]() Join Date: Dec 2012
I got my money
![]() Going to get the Truck this weekend, really nervous
1971 GMC Sierra 1959 GMC 100 |
#6629 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I started taking all the crap off the truck that looks more like a shelf..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#6630 |
Photos French
#6631 |
Posted via Mobile Device Dropped my buddies of at the upholstery shop today
![]() Posted via Mobile Device Posted via Mobile Device
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=563712 Instagram: http://instagram.com/rockylakekustoms Rocky Lake Kustoms Russ |
#6632 |
Sheetmetal Psycho
Pulled the 350 to ship off for repairs. Getting cam and valvetrain gone over / replaced. Fely good to be wrenching on the ol gal. Now I have to see what all I will need to fix or replace while the engines out.
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up! Project "Rigginstine's Monster" 1971 C-10 longbed 355/4spd Future mods: 67 front clip Webby's Rigginations - where everything has potential! |
#6633 | |
![]() Join Date: Jun 2012
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son ![]() |
#6634 |
moved it out of the garage to work on my DD turd
#6635 |
I missed it. Having new AC/heating system installed. First time I've let anyone else work on it and I'm having seperation anxiety. Should be done by Friday.
#6636 |
I want to drive my truck ... but problem : new battery, new regulator, but same issue, low battery after some miles. it seems to me that battery passes off by driving, not in the stop !
any idea ? is it possible that the starter puts itself in short circuit and empties the battery by driving ? I drive only by the day, and just after 10 miles, good new battery is empty ![]() thanks for help
'70 C10 shortbed - 350 Edelbrock equipped - 4/1 headers - 3" flowmaster exausts '07 MUSTANG V8 convertible - CAI Spectre - Brembo's - 3" flowmaster exhausts |
#6637 |
You should open a new thread in the electrical section for this. Have you tested the voltage output of your charging system both at an idle and at driving speed?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 Last edited by Lee H; 04-16-2013 at 04:19 PM. |
#6638 |
Planning on how to get my Truck
#6639 |
Alternator testing is far easier than most think .
Did you place a volt meter across the battery terminals when it's running ? . That's just one of many tests . More if you but ask .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#6640 |
RAT1968 '68 Cab/'71 Parts
Played with the hood, played with the headliner (carpet from "Big Lots"
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#6641 | |
![]() ![]() Join Date: Jul 2002
Sounds like the alternator/regulator are not adjusted correctly It would be good to see what the differences in the voltage are while driving or what is coming out of the alternator. As mentioned a small multimeter check across the battery terminals to watch your voltage draw/changes at RPMs is a quick easy way to go. Also are you required to drive with your lights on all the time over there?
#6642 |
100% won't be the starter causing charging system problems, it would have to run with the engine and you would know that.
#6643 |
thanks to you, will verify the charge when engine is running ; battery is charged this morning, so I hope i can start my engine.
battery gauge (factory) doesn't work correctly ==> always good... what is to say "Sounds like the alternator/regulator are not adjusted correctly" ?
#6644 | |
#6645 |
OK, I bought a regulator item 36-2520 at LMC store. it is not precised for which Ah it is. I thought it was a standard one, because it fits with electrical plugs.
i've any information regarding alternator. Perhaps it's a high Ah powered and the standard regulator does'nt work with. So do I change the alternator to a standard like item 36-2760-Z (LMC store) ? First I have to see if charge works or not.
#6646 |
Then, started my truck. ... 13V, no change when I accelerate !
solutions : 1- condensator ? (not changed) 2- alternator ? 3- regulator ? ==> new one ==> before I changed it, when accelerate alternator gave 18V !!!
#6647 |
![]() Join Date: Feb 2012
#6648 |
OK done, sorry for disturbing
#6649 |
I made front upper shock relocation brackets and am about to make the rear ones. Hopefully Ill be able to get them installed friday. Ill post pics soon.
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase 1955 Chevy Stepside "Dudley" My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288 1972 Chevy C10, Project "Chevro~Layed out" Nether Storm Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523 |
#6650 |
Looked at the truck as I walked by.
