#6651 | |
The 60-66 GMC/Pontiac guy....
Re: What did you do to your truck today?
![]() But on the bright side, SBC motors are the cheapest motors to build anywhere.. so you got that going for you.. Just sucks you have to do it all over.. this time you should upgrade to the LS7.. then you would only be replacing tires once a month ![]() ![]()
![]() Building Genuine Pontiac Firepowered cars and trucks for several decades. ![]() Why Pontiac?? That's just me daring to be different. ![]() Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac ![]() |
#6652 | |
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla Matt. 6:27 "Who of you by worrying can add a single hour to his life?” http://www.67-72chevytrucks.com/vboa...=507266&page=2 |
#6653 |
Hooked up my dome light, one of those little things we overlooked. It is nice will add door switches now that I know how it works......Kieth
#6654 |
![]() Join Date: Apr 2012
Shaved door handles!
I have not failed. I’ve just found 10,000 ways that won’t work. |
#6655 |
That is majorly sweet!
What kit are you using to open the doors? Steven
#6656 | |
![]() Quote:
Sam |
#6657 |
Finally, my son and I were able to get the lower control arm shafts in. Took a bar clamp and a dead blow, but, there in!
![]() Also got the lower ball joints in. Time to assemble the front suspension! I have to say that my 12 year old is a real go getter. I wouldn't have been able to get this far on the truck without him. He is learning to weld, paint and generally learning about how mechanics work. He asks a thousand good questions and you can actually see the understanding on his face. Sorry to go on so much, but, I am incredibly proud of him. Steven
#6658 | |
![]() Quote:
Keep up the good work! sam |
#6659 | |
Senior Enthusiast
For a long time I thought maybe it was a problem with the brand of carburetor (mine happens to be an Edelbrock 1405). The problem turns out to be that modern gasoline (within the last 10 years or so) evaporates at an alarming rate, leaving the float bowls empty. The electric pump will only be used to charge the system and fill the carb. It runs on a momentary switch that will shut off as soon as released. The engine can then be started and run normally on the mechanical pump. When the truck is driven daily the electric pump won’t be used at all. I didn’t want to convert to an electric pump alone as my experience with their reliability has been rather poor.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 Last edited by markeb01; 12-20-2012 at 10:32 PM. |
#6661 | |
Senior Enthusiast
Thanks for sharing. My oldest son showed a lot of mechanical interest at that age. He grew up to be a great machinist. I recognized his apprenticeship was complete at about age 14, when I had him button up the bottom of my engines by himself. He was so dependable by then I realized there was no further reason to double check his work.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#6662 | |
![]() Quote:
Sam |
#6663 | |
1 thing at a time is progress.
Alan
Philippians 2:14-16 |
#6664 |
well as cold as it was. went out to get some gas for my new truck.and took it up the road.BBBBBBBBRRRRRRRR COLD,COLD.......
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
#6665 |
How cold is Brrr cold, it is -17C here and we think it is a warm day.
#6666 |
Only thing I did today was vote for (Alan's 65) for truck of the year. Come on guys let's help him out
![]() Click the link and show his beautiful truck some love !!!!! http://67-72chevytrucks.com/vboard/s...d.php?t=557194
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=346597 https://www.facebook.com/pages/198-C...1434001?ref=hl |
#6667 |
I not, I plan to install Nu Relics power windows and then install Dakota Digital remote system to it. That way I can raise or lower windows by remote and will just reach in and open the door. I also plan to install a emergency cable. Just in case. Marty
#6668 | |
66 shorty ![]() |
#6669 |
I voted for Alan for TOTY!
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
#6670 |
#6671 | |
![]() Posted via Mobile Device |
#6672 |
SIR
....nutt'in...too cold...31 and dropping....
66long low fleet http://community.webshots.com/user/LVNR66 |
#6673 |
This is the rough center console waiting for my shifter to finish the top. Nexus 7 tablet mounts in the opening.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
#6674 |
Senior Enthusiast
Finally finished up the new fuel system after days of working on minor problems the kept popping up. Ended up costing way more than expected, required much more back aching discomfort, and days of living with the stink of gasoline. But man the finished result was worth it!
#6675 |
Went to NAPA and paid for lower control arm U bolts.
They won't be here until Wed. I decided (after reading the thread on broke u bolts) not to reused the originals. I have replaced all the bolts but the rear end U bolts so I think I might get those as well. Steven
