Old 11-07-2009, 09:13 AM   #651
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: ''Project '64 SYT Super Yenko Truck"
Has the truck been sitting long? I had a car that was running great and I let it sit for a while. I started it up and had a lot of valve train rattle. The varnish inside the motor got a little sticky. I remember my dad using Marvel mystery oil. I put in about a 10th of the oil capacity and let it run for about 30 minutes and it went away. It was a cheap fix.
Alan's Classic is offline   Reply With Quote
Old 11-07-2009, 11:49 AM   #652
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
i got a little bit of water in it because i hooked up a line wrong
the engine was in a rolled vehicle so i dont know if it had any problems before
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 11-07-2009, 10:41 PM   #653
2manyprojects
2manyprojects's Avatar
If you got water in it you might have knocked a chunk of carbon loose. I just went through that with my S10. It got left out in the rain with no hood and got water in the engine. It had a bad knock. My Dad poured something in the throttle body to break it up. The noise went away after a few days. I just drove it 500 miles today to get a front clip for my 50, and it ran perfect. I'll find out what he used and let you know.
Cool Build by the way. I wish I could have made progress like you are when I was 15. I think I ended up fixing more of my screw ups on my 68 than actually moving forward.
2manyprojects is offline   Reply With Quote
Old 11-07-2009, 10:49 PM   #654
shortbed70
shortbed70's Avatar
Nice thread jacking on your own post...JK We had a ferd with v6 thats did that same thing and turned out to be a lifter had turned or froze up we dont know but proceeded to destroy the motor but ran ok during the time until it was bounced off the limiter to blow it up for warranty.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 11-08-2009, 12:28 AM   #655
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
well let me know
i just put some flowmaster super 40s on it earlier it sounds good
Gage
Old 11-09-2009, 12:40 AM   #656
dammitmitchell
the pollock
dammitmitchell's Avatar
im theinkin exhaust manifold gasket...... same loud tic...
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 11-11-2009, 12:42 PM   #657
2manyprojects
He used AC Delco X66P Upper Engine and Fuel Injector Cleaner. I'm sure you could find something similar at your local parts store. Just look for something that will break up carbon deposits. Even if that doesn't fix your problem it wont hurt to clean it. Good luck!
I had flowmaster super 40's on my old S10. they do sound sweet. You should post a video.
Old 11-11-2009, 08:15 PM   #658
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
thanks i will post a video after i get it to quit knocking
Gage
Old 11-11-2009, 08:44 PM   #659
dammitmitchell
the pollock
did you replace and check the exhaust gasket yet little dude?
Army vet 02-08
Old 11-11-2009, 09:34 PM   #660
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
no but im going to try this first this is much easier and cheaper
Gage
Old 11-15-2009, 11:42 PM   #661
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
well i put a different carb on this stupid thing
the holley is a total piece of sh!t and so is this quadrajunk that i just put on
it is better than the holley though
i have to use an adapter because of the intake
man i need another carb
it suks to be too young to get a job
Gage
Old 11-15-2009, 11:50 PM   #662
Strodder
Daring to be Different
Strodder's Avatar
It's about time you did some work on it. Why don't you rebuild the Quadrajet. They work good for me. The biggest problem is the plug on the bottom leaks gas, and has to be epoxied. The rest of the rebuild is easy. Make sure the shafts are ok too, and not worn out, or you will have to install bushings.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 11-15-2009, 11:53 PM   #663
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
it was just rebuilt a few years ago ran for 2 months and put on the shelf
i pulled it down the other day and pulled the top off it looked really clean
the only things it wont idle down and i have to use an adapter
why wont it idle down about 1200 rpms is as low as it will go
Gage
Old 11-16-2009, 11:07 AM   #664
Strodder
Strodder's Avatar
Drive it over here and I'll look at it.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 11-16-2009, 08:35 PM   #665
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
yeah that sounds like a good idea
Gage
Old 11-17-2009, 10:44 PM   #666
highperf4x4
So you ran the idle jets all the way in and it was still idling at 1200??
highperf4x4 is offline   Reply With Quote
Old 11-17-2009, 11:03 PM   #667
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
i got it now
i thought the idle screw was all the way out but it wasnt
it runs a little rich but runs good and has excellent throttle response
Gage
Old 11-17-2009, 11:07 PM   #668
highperf4x4
You can adjust the idle jets to lean it down some. It will pull fuel through them even under throttle. Getting the mixture right will increase mileage without hurting your performance. You'll just be getting less unburned fuel/carbon. Q-jets get pretty good mileage when you keep your foot out of them. I'm with Stodder. I like to use them myself. I haven't found a carb that will perform as well when you get them set right.
Not to mention they have that monster sound when the secondaries open.
Old 11-17-2009, 11:11 PM   #669
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
so how do i do that?
Gage
Old 11-17-2009, 11:25 PM   #670
highperf4x4
There's 2 idle jets on the front of the carb. They may have caps on them that need to be knocked off though if they've never been adjusted. You can either use a skinny flat head screw driver or a flexible tool specifically for carbs.
http://www.oreillyauto.com/site/c/de...PartType=C0374
I like to run my jets all the way in and them back them out about 1 to 1.5 turns. It might be better to set them by sound though. Whatever makes the engine run the smoothest and then set your throttle adjsutment again to get the idle you want. While you have the engine down to about 800 rpm you can set the timing again with the vacum advance disconnected to where you'd like it to be. Stock would be about 4 degrees before tdc and mid performance could be as high as 8 or 10 degrees.
Old 11-18-2009, 12:00 AM   #671
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
oh okay ive gotcha ya now
i have them set at 1.5 turns
but its running rich still
should i go more
Gage
Old 11-18-2009, 12:15 AM   #672
highperf4x4
If it's still rich then you need to go back in with them. I'd run them all the way in and then back them out a half turn at a time until the engine will idle smooth on it's own and then up your set screw a little if you need to.
Old 11-18-2009, 12:23 AM   #673
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
why do they have such good throttle response
Gage
Old 11-18-2009, 12:26 AM   #674
Rich 5150 69
Rich 5150 69's Avatar
jgh64pkup, this site might help. i`m with these guys, once set up right performance is great. There are several sites in this link not all work.
http://www.florida4x4.com/tech/quadrajet/index.php
Rich 5150 69 is offline   Reply With Quote
Old 11-18-2009, 12:36 AM   #675
highperf4x4
Throttle response is controlled by many factors. A dual plane intake is good, no vacum leaks, a split plenum, a strong accelerator pump, proper timing, etc etc. When you have these factors taken care of you can get great throttle response from almost any carb that doesn't have issues.
