#651 |
Re: What did you do to your truck today?
Hey Scoti how do you quote like that with my pic? And my first suggestion would be to find a big back window cab!
#652 |
I went and picked up my cab after having new floor sheet metal installed. There is still some body work to be done before it is ready for paint. We went ahead and set the cab on my frame. It has been eight years since I took it apart and I have almost forgot what it looks like with a cab. It was too late to get any pictures last night but will try to get some this weekend.
1965 c-10 swb 1997 c-1500 extended cab 2004 tahoe 1993 mustang gt BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653 |
#653 | |
![]() My plan was to get an 'inner' cab skin from the upper seam down to the area where it 'rolls' under adjacent the gas tank & to the doors each side. I figured splicing it together .250" below the OE upper seam to keep things from warping when welding it up. Since there are multiple ways of doing the job, I like to see if someone has done something different that allows for a 'better' (easier, more consistent) finished task.
#654 |
Rods
![]() Join Date: Nov 2002
if you removed the entire rear panel like i did you can take off the inner from the spot welds. more work but looks factory. I drilled all the welds at the door and rear and the window. then removed the whole panel. you can see from my what it looks like when you removed the back.
Just keepin it simple. ![]() 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) |
#655 | |
I'm not sure what you were trying to say in bold??
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-14-2010 at 12:58 PM. |
#656 |
Rods
not sure why its in bold there?... its not on mine. i did it to remove the rear for my extended cab. if someone was goin to take the time to install the inner panel from another truck. i think it would make it ezer to remove.
#657 |
I put it in bold because I wasn't sure what you were trying to say.
#658 |
Rods
lol oops. I have some pics on my build thread that shows the rear panel removed
#659 | |
#660 |
Rods
ha......
#661 |
I finished putting a steering knuckle back together and brake shoes on that side, then moved the truck to a spot where it'll be easier to do the other side.
"Off the grid and on the seven day weekend plan" "One person cannot know everything, but between all of us, there isn't much we don't know." |
#662 |
new cab corners!!
![]() ![]() ![]() Last edited by 63 extreme low; 01-14-2010 at 04:07 PM. |
#663 |
Today I pulled the long bed off my truck got it loaded on a trailer to sell tomorrow. Sorry to see it go and for so cheap but I had no where to put it and needed to make way for my short step bed and tube back half.
![]() 1960 GMC short fleet, full frame build... http://67-72chevytrucks.com/vboard/s...d.php?t=329718 |
#664 |
I picked-up my fuel fill hose (it was required to finalize my tank fill piping). Now I can finish that tank related stuff this weekend & mark it off the list.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-15-2010 at 01:32 AM. |
#665 |
Put shocks on all four corners.
Andrew '69 C-20(292, 4-speed) Retired Daily Driver '64 C-10(250, 3-speed) Fixerupper '97 F*rd Mustang GT(4.6L, 5-speed) Daily Driver If I only wanted two pedals I'd have bought a bicycle.
#666 |
![]() Join Date: Sep 2006
I pulled the carrier out of the diff becuase I was going to swap in the carrirer from my 4x4 seeing it was a posi diff. I found out I have 3.08 gears in my truck and the 4x4 has 3.73 so I don't think the ring gear is going to swap on to it and work, so I put the carrier back in so I can bust the yolk nut loose so i can change the seal some day/.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
#667 |
I patched the front of the drivers side inner fender on my 66 today. No photos as the welds are snotacular! First welding I've did in 23 years.
I'm quite pleased with myself. ![]() |
#668 |
tore out my old bedwood I was surprised at what actually holds the bed down. The bolts actually go through the wood to the frame. I'm afraid to over tighten the new bolts for fear of splitting the wood. Also see new wood in waiting
#669 |
So what`s your plans for coating the wood `62...?
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
#670 |
In the March 09 issue of Custom Classic Trucks there is a 50 Chevy. The guy used Boiled Linseed Oil on the planks which actually soaks into the pores of the wood and provides good protection and leaves a satin finish I'm not fond of the high gloss so if you happen to have that issue or look it up if it's good enough for his truck then I'll use it. Mark-K also has a write up about it.
#671 |
My CPP drop crossmember came! gonna put it on sunday
#672 |
Today I did a little bit of work to the backhalf. Then I threw it under my new bed and put the gas tank between the rails just to check it out. Looks so sick. I want it done!! Probably won't run a floor in the bed for a while just cuz I like to see my handy work. Then I dropped my old bed off to the new owner. I was happy to see when I pulled up a short bed Chevy with no bed. I was happy because for the price I sold it for I was scared it was going to get made into some sketchy trailer and not be used for what it was. He was going to make it a short bed and put it on. He had a pretty nice body shop and I think it was for a customer. He didn't need the tailgate and said I should have left it at home then I asked if I could pull it off and he said for 20 bucks lol. I left it. PICS!
#673 |
We ran the wires for the back of the truck and installed the loom. I've been busy with a new job and haven't had any time to work on my truck. I had a good helper today ( my 10 year old son , the youngest ) he crawled up under the truck like he knew what he was doing. it does my heart good to see him so excited to help dad with the truck . looks like we have a gearhead in the house. I didn't get much done explaining what to do to him, but...if you have kids please get them involved in your build. there is alot of bad things to do as you grow up , but if they are into rodding it gives them a positive outlet for all that extra energy that they have. its also a good way to bond with them!!!! they grow up so fast! notice that the wire comes thru the bed for thru 41-48 tail lights that are mounted in the fenders
If it has tits or wheels its gonna give you problems!!! |
#674 |
Member of the longbed union.
Looks good Eric. Keeps them boys busy. Hows the wifey?
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
#675 |
replaced a broken push rod in my 62 c10 283, thank god it wasnt anything too serious like stuck valve or broken spring.
