03-05-2011, 08:30 PM | #651 |
1 thing at a time is progress.
Re: Project: Recycle
Determination paid off on the drive shaft. You can Check that off the list now.
Alan
Philippians 2:14-16 |
03-05-2011, 09:28 PM | #652 |
VA72C10
Glad you got it fixed and they did the right thing!!!
Looking for a 67-72 swb or blazer project in or around VA. |
03-05-2011, 09:31 PM | #653 |
this calls for a testdrive
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
03-05-2011, 09:58 PM | #654 |
Still have a few items to go on the list before a 'test drive' is possible....
03-06-2011, 10:14 AM | #655 |
PROJECT 7DEUCE
Good to see the shaft problem fixed..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
03-07-2011, 10:40 AM | #656 |
67cheby
i am glad they didnt try to SHAFT you this last time (pun intended)
03-07-2011, 11:51 AM | #657 |
Hey Scoti,
Where did you get those conical spacers you are running with the Del-Spheres on the trailing arms? Did Nate include them or did you source them? |
03-07-2011, 12:01 PM | #658 |
Got them from Nate w/the pivot joints.
03-08-2011, 08:55 AM | #659 |
Looking good my man! Maybe this will inspire me to finish one of my projects!!
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
03-08-2011, 09:04 AM | #660 | |
67-72 parts collector,…
http://www.summitmachine.com/index.php?p=customParts.
03-11-2011, 12:31 AM | #661 |
It felt good to get the d.shaft hurdle over with & then....... more hurdles.
I got some new (China) 2.5" ram-horn manifolds in on Monday. Picked them up @ lunch & installed them that night only to find the driver side exhaust flange exits dead center in front of the R&P shaft. They look really good on there but are a no-go unless I add another u-joint, support bearing, & shaft to the mix. In the end, I'll spend an extra ~$150 only to have the steering/u-joints snaking around the manifold which is a visual detraction IMHO.... For the same $$, I could use the Speedway 'horns' (because they tuck just a little closer to the block) & utilize a single shaft w/u-joints @ each end. Much less complicated & should allow the focus to remain on the motor. I also tried working on the 'pre-bent' 3/8" suburban fuel line I had. I wanted to try & tweak it to work w/the chassis. Of course, as I was trying to get things looking right, I just couldn't get it how I wanted & wound up cutting it into 'sections' making it work better. Unfortunately, w/everything snaked & tweaked to fit the chassis, what I could utilize wasn't enough length. I researched online for an obtainable (local) alternative & bought some new 60" lengths of 'poly-armour' lines. They're supposed to be easier to work with & much more resistant to the elements (rusting). Well, they might be easier to bend, but they certainly don't like the flaring tool. So, that's where I am tonight. No 60's exhaust manifolds (I do have the shorty headers on there for now while contemplating options) & no fuel line (seriously contemplating rubber FI hose as it would reeeeeeeeeeeealy make plumbing within the confines of the frame rail easier).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-11-2011 at 12:34 AM. |
03-11-2011, 01:35 AM | #662 |
would if flare eazier if you heated the end up ?
03-11-2011, 01:51 AM | #663 |
VA72C10
you need some cunifer
I might know someone who has some for sale... http://67-72chevytrucks.com/vboard/s...d.php?t=452251 Or find some locally....supposed to bend and flare easier....
03-11-2011, 09:55 AM | #664 |
PROJECT 7DEUCE
Hey scoti I ran braded hose from my tank to the fuel pump and used made for you products line clamps seemed to install really easy and I had no problems making any corners I needed to make.
03-11-2011, 10:38 AM | #665 | ||
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-11-2011 at 10:43 AM. |
03-11-2011, 11:15 AM | #666 |
one way to get coiled line straight is to clamp one end in a vice on a sturdy table and the other end in vicegrip pliers roll it all the way out slack it a little and yank on it hard so it will whip/twang and it will be straight
handle it carefully so it doesnt bend again while setting it down , having someone helping you at the vice end does help with that , you then only need to get the flatten ends cut of it
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts Last edited by watahyahknow; 03-11-2011 at 11:16 AM. |
03-11-2011, 11:33 AM | #667 |
Slots go on anything!
Since you are going carbed, the FI hose might be overkill, too. The guys here told me I was good with regular fuel hose going with TBI. I just put small barbs in my hardlines to hold it, and it seemed to be doing fine.
1974 Jimmy- 5.3/4L80e/NP241 |
03-11-2011, 11:52 AM | #668 |
PROJECT 7DEUCE
I may have mislead you mine is just rubber hose with the stainless sleeve ove the top with regular hose clamps holding it all together got it all from summit IIRC and it was pretty cheap..
03-11-2011, 01:03 PM | #669 | |
I used several feet of rubber FI line on my 68 as well & simply made replacing it part of my 'annual' maint program.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-11-2011 at 01:04 PM. |
03-13-2011, 11:57 PM | #670 |
I got some sheet metal work done this weekend. The rear cab-wall pinch weld was removed & about 1" was taken out of the rear cab support. I also cut out a 5.5" wide section of floor under the seat (from the tallest part of the floor aft of the trans hump to the rear cab support). The cab should drop down onto the rolling chassis w/o issue now & clear the 1pc. d.shaft @ full dump. Once the cab is set down & I can 100% confirm everything clears (& is symetrical), I'll close out the open sections.
I also hit the local cruise joint on Sat night & got some good reference views from a truck that had a PB Dropmember. I confirmed my estimate of where the front inner wheel wells need to be trimmed for upper a-arm/bag mount plate clearance. My buddy came over to help me get the bed back on late this afternoon (early evening). The sky was pretty dark/cloudy most of the day & it appeared we might get some rain so we loaded the truck back onto the trailer & returned it to storage. We were jammed for time so I didn't stop to get some pics but I will this week. I'm freakin worn out.....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-14-2011 at 09:00 AM. |
03-14-2011, 07:24 AM | #671 |
03-26-2011, 09:43 AM | #672 |
67cheby
come on its been since 3-13 and no pics !!! do be stingy we want to see !!
03-27-2011, 12:24 AM | #673 | |
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
03-27-2011, 01:26 AM | #674 | |
I did get the exhuast manifolds in & ordered some other parts to finish up the doors/door glass installation. I also took several pics of factory 67-72 truck accessory set-ups @ the GG's show to determine how the brackets are assembled & how compatible (if) they'll be w/the different manifolds. Yep. I went out there the weekend before Good Guys.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-27-2011 at 01:33 AM. |
04-03-2011, 04:07 PM | #675 |
No 'real' update but I did get the pics of the cab notch & floor opening for the DS hoop....
