07-21-2014, 11:46 AM | #651 | |
Re: Project '64 Cheapskate
Thanks!
I won't tell you how many hours I have in those lines. If I had a shop and quoted someone a fair price for the job, I would have taken it in the shorts. Once I got the lines bent at the master cylinder, I must have measured and remeasured for at least two hours before I made the first bend at the firewall. I should have taken a picture of the way I measured everything. I had straight edges clamped in every direction and a notepad full of scribbled measurements. Quote:
It sucks when you're all proud of the bends on the line, only to find out that you left the fitting on the wrong side of the bends. Now, I always grab some masking tape and tape the fitting to the end of the line before I start bending to keep it from moving around. The proportioning valve that I'm using is from SSBC, and it's identical to the one that Wilwood makes. It's just for the rear brake line only, and has the adjustable knob to control pressure. It will be mounted inside the driver's framerail, about 12" behind the transmission crossmember. I have to account for the e-brake cable and any wire harness routed in the same area, so I tucked it up out of the way.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
07-21-2014, 05:16 PM | #652 |
Been there done that. Once while working I did this complex bending and all this really jazzy neat stuff, and flared my line. Picked it up admired my hard work. Then realized I forgot the flare nut. Oh well. First was just practice right.? Killer work on the lines!
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
07-28-2014, 09:25 AM | #653 |
A320 Pilot/USAF Retired
I Love what you've done with this one too!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
07-29-2014, 05:23 PM | #654 |
That looks fantastic, Alex! Nice job!
08-03-2014, 03:17 PM | #655 |
Still working brake lines, specifically the rear. With my truck being so low and the rear tires being so tall, getting the rear wheels off is going to be a challenge. The original route of the rear brake line is down the passenger side frame rail and the flex line drops down right above the rear end, but it's too short to allow enough droop of the rear axle to get the rear wheels off.
Running the brake line down the trailing arm seemed to be the best alternative. My plan was to bring the line to the trailing arm crossmember and use a bulkhead connector (Earl's part# 989543ERL). These connectors are -3 AN on one end and 3/8 inverted flare on the other. It is held into place using a spring clip. The only problem is, the frame is too thick and the receiver groove for the spring clip is obstructed. So, I handed them over to Brad, and he chucked them into the lathe and turned them down. They fit perfectly now. Here is a before and after picture: I built a bracket to hold the forward part of the line and attached it to the trailing arm with two 8-32 button heads. Here it is with the fitting installed, the spring clip in place, and the line connected. It's a very secure assembly, nice and tight with no movement. Starting to clamp up the line..... Here's where it got tricky. I tried a couple of line routes using a piece of scrap tubing, but I didn't like the way it wrapped around the edge of the arm. I didn't want a brake line hanging out in the breeze, especially in an area when it can get damaged from everything in the road. The only alternative was to use another one of the modified Earl's fittings. The best place to install the fitting was right between the perch and the coil spring, but that was right in the area of the reinforcement plate. Here is a picture of the hole drilled to final size (5/8"). You can see what I mean about the reinforcement plate. I figured that chucking the arm in a mill and milling away a part of the plate was the answer, but Brad had a better one. He used a flat bottom mill and just spot-faced the arm. I actually liked his idea better! Here's a picture of the arm with the brake line installed. Once it's back on the truck, I will bend a small line to connect the fitting on the arm to the tee on the rear end. I used a 1/4" clamp along with a 1/2" spacer to secure the line. (there is a 3/8" clamp in the picture, but it has been changed to a 1/4") A HUGE thanks to Brad for opening up the shop on a Saturday night to do the machine work for me. I can't thank you enough!
08-03-2014, 05:48 PM | #656 |
Looks good.
08-03-2014, 06:28 PM | #657 |
I'm glad I was able to help! I'm diggin' how this setup is looking so far! I would never know that you're still a rookie in the bending lines department either because your quality is absolutely first class! You may have to bend up the lines in the streamliner! Great job dude!!
It's all about the stance, baby! http://67-72chevytrucks.com/vboard/s...d.php?t=320546 |
08-03-2014, 10:17 PM | #658 |
That...is slick. Nice work, both of ya!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
08-04-2014, 11:17 AM | #659 |
Okay,
This build is so slick I've re-read it over again. Staying on budget with top notch mods. Killer workmenship all the way! |
08-05-2014, 10:29 PM | #660 |
This is what sets him apart from most budget builds (actually ANY budget) is that it all comes down to taking your time! Most guys are in such a hurry to drive the truck they get in a sloppy hurry and say they'll fix it later even though they NEVER do! Alex is dying to drive the truck right now and he is soooooo due to have a fun driver, but he's NOT going to do something halfass just to rush the final product. Take notice people, THIS is how you build a truck!
08-06-2014, 04:28 PM | #661 |
I agree^^^^
08-06-2014, 04:38 PM | #662 |
Man, words cannot describe how badly I want to get this thing done and start driving it.
However, I want to build it ONCE and be done with it, so if it takes a little longer to do it right, it's worth it in the end. Having to do something over again because it wasn't done right is one of my pet peeves.
08-07-2014, 09:17 AM | #663 | |
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
08-15-2014, 05:04 PM | #664 |
Love readin your build. It gives me a lot of ideas for my 64.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 08-16-2014 at 05:36 PM. |
08-16-2014, 03:54 PM | #665 |
brake line is as slick as they come, great job
my 65 fleetside build http://67-72chevytrucks.com/vboard/s...d.php?t=442370 big back glass conversion http://67-72chevytrucks.com/vboard/s...dow+conversion |
08-16-2014, 11:34 PM | #666 | |
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
This has been my philosophy from the start of my build! I know for sure that once that I start driving mine that the last thing that I want to do is fix things that I rushed over...Nor do I want for anyone else to notice them... Nice work!
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=512904 |
09-16-2014, 06:56 PM | #667 |
Awesome build!! Any updates?
1960 Chevy Stepside 2wd 1966 Chevy Fleetside 2wd 1965 Chevy Suburban 2wd 1965 Chevy Fleetside 4X4 1960 Chevy Fleetside BBW 2wd |
09-17-2014, 01:05 PM | #668 |
Yeah! Yeah! What he said!
09-17-2014, 06:16 PM | #669 |
Me tooo^^^^^^^We need our cheap fix.
09-21-2014, 12:59 PM | #670 |
I agree but I've also been told that their never done. lol
09-23-2014, 01:22 AM | #671 |
What a cool truck and quality build!
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
10-29-2014, 12:44 PM | #672 |
We know you're there, Alex!
10-29-2014, 01:07 PM | #673 |
Hah, caught me snooping!
I have been doing a ton of stuff on the '64, and although I have taken a bunch of pics, I don't have anything to show. I gave my computer to a buddy at work, who is our IT guy, so he could give it a tune-up (add more RAM, update to Windows 7, etc). Well, he's slower than molasses, and on top of that, he went out on Medical and there's no timetable for his return. My next step is to see if any of his co-workers can help me out. I need that computer back, because my tablet has limited capability. In a nutshell, I bent some more hard-lines, made some frame reinforcement gussets to help support the front sway bar, started to restore the grille, spent way too much time trying to make a 2002 Camaro rear sway bar fit (I'm too low, won't work no matter what orientation you put it in), built emergency brake cable brackets, and bought a American Autowire Classic Update wiring kit but haven't started it yet. And I sold my '83 shortbed fleetside. Too many projects, and I needed to thin out the herd. The guy got a helluva deal on an incredibly solid California rust-free, dent free-truck that had a bunch of work already done. I have been busy, and will post up pictures very soon.
10-29-2014, 02:03 PM | #674 |
I just bought the same wiring kit, hurry up and do yours so you can save me all the do overs LOL
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
10-29-2014, 04:41 PM | #675 |
Glad to see you're still out there. We've been waiting on our cheap update....lol.
