![]() Join Date: Aug 2010
Re: What Did You Do With Your Truck Today ?
Walked by mine
Ha! Finally had the transporter come get mine and take it to it's new owner. Now to start on my new 55 project......
Boy, are you ever going to be mad (after all you did for that fellow who purchased you truck), if the Leafs ever beat the Canes in the playoffs. Wait a minute...................you're ok.......that will never happen. What was I thinking. The Leafs haven't made it to the first round in seven years.
Test fit my new 22 inch steelies on both trucks. Decided they make them look like crop sprayers and will need major lowering and fender widening.
Posted via Mobile Device |
56 - autocross
#6 | |
the black 48 gmc truck is on a 2000 4wd chevy tahoe chassis and drivetrain. the grey chop top 49 gmc is all original except the top. 48 wouldnt set all the way down due to fender, 49 is sitting on the ground but rust build up around the base of the hub( or 3 inch center bore is too smal) prevented the wheel mounting flush agianst the drum and studs are too short for a spacer small spacer that would make it roadworthy. ![]() ![]() ![]() ![]() |
#7 | |
56 - autocross
I made a template to cut the boxing plates for the rear of my frame.
big guy
Almost have 235 ready, just need carbs.
![]() Guess I should start a build thread Last edited by mknittle; 05-19-2012 at 10:01 AM. |
after a few times trying (unsuccessful) i had to go and buy a new holly fuel pump - with a rotating bottom section to change he position of the inlet and outlet of the fuel lines .
#13 |
great looking engine !
#14 |
That is a really nice engine, old inline sixers are super cool!
RIP John (Lambis), my beloved Father & best Friend. My Build 56 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=486721 |
#15 |
The shop was tied up so i dinked around trying to come up with a clutch linkage that that will work.
#16 |
![]() ![]() Join Date: Nov 2008
Very, very nice 235. NOT fault finding but I'd suggest you put something on the exhaust manifolds so they don't rust/crust up and ruin the beautiful look of that. Eastwoods has a brush paint that is supposed to cure with heat and look like a new casting. Have heard good things but never used it. Congrats, niiice engine
#17 | |
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
#18 |
finally got my headers ceramic coated - picked them up today - will install manana - the shop did a great job.
#19 |
Swapped the old 250 cube 6 & the attached toyota 5 speed, plus a disassembled 454 for a 28 Model A Tourer, thats mostly complete, tho fully disassembled.
We replaced the 250 & manual with a 350/700R4 combo over the past six weeks. |
#20 |
Cut my van steering coulmn down a total 5 inches and main shaft 8 see my build.
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
#21 |
Sand, plastic, sand, plastic on the hood and bumpers. Also down to the final (cross my fingers) sand on the steering column. Gettin' itchy to start painting...
#22 |
Got the right side cab corner welded on, and started fabing up the left side. First time welding in a patch panel, i think it turned out good enough for the woman i date!
#23 |
Installing tubular control arms.
Truck's just for the fun of it. ![]() |
#24 |
big guy
I think you did great with the welding rednek13!!! trucks looks good.
Ray |
#25 |
Old Heap Driver
x2!
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
