#651 |
![]() Join Date: Oct 2009
Re: Not Another Rebuild Thread....
looking good lewis... feeling good billy ray.
don't know why trading places popped to mind. maybe its because i'm missing having a current project. and i really like yours. |
#652 |
looking good, cant wait to see the cool seat, and other gadgets
my 65 fleetside build http://67-72chevytrucks.com/vboard/s...d.php?t=442370 big back glass conversion http://67-72chevytrucks.com/vboard/s...dow+conversion |
#653 | ||||
Good humor !! Quote:
Speaking of CHiPs, the one episode I remember best was the domestic disturbance one where the wife was out on the lawn and had set her soon to be ex-husbands Trans Am on fire. I recall Ponch got the car for like $50.... Quote:
Some days I impress myself dude!! I like that blue you shot this week on your rig! that is going to be some rich color brother !! Quote:
I am getting closer to the seat. So far I am trying to work from the top down inside the cab. Next on the play list is working the dash extension, tranny hump access door, Herculiner the floor, sound deadner with carpet, and some of the wiring. I wont worry about the seat until it is time to reinstall the doors and door seals. Once the seat is done I wont want it getting dirty. I also picked up an engine balancer to make pulling the motor back out a lot easier. Also today, in keeping with my wiring and dash extension plans, I picked up the sound system. I admit I bit the quality versus price bullet this time. I stood in WalMart for almost an hour just staring at the stereo display playing with the demos and listening to the speakers. My Tempest has $2,200.00 of sound in it but I have to keep in mind that this is a small truck cabin compared to the land yacht convertible the Pontiac is and I will be sitting in and on the speakers in this build. The acoutics are going to be 180 degrees of difference from my Tempest. These next two are just quick shots of the ceiling, and how the progress is, well, progressing ..... LoL
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
#654 |
Going to steal the Hood Release and EBrake mods as well as the vent pull cables... Awesome forward thinking Man...
DON Proverbs 27:17 ![]() US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
#655 | |
Well, in this manner anyways.. ![]()
#656 |
Theft in progress here too. Using them when I get to that stage in my build. I got your stuff bookmarked.
#657 | |
Hmmmmmmmmm I best get down to the garage ![]()
#658 |
Got my Spyglasses on!!!
#659 |
Well old business first...
I did a mount for my cyclops light but I didnt really like it. I goofed it up and the light mounted up side down to what I wanted, then it turned out to be too shallow for the light housing. I really did not want to cut any more than totally neccessary so I re-did it. This is what it came out as. I also added amber bulbs to it for the left and right turn signals. Flips you asked for a dead on side shot to check angles, I think this should cover that question Heheheh. If anyone is interested, I will post next on how I made the gasket that is between the mount and the cab.
#660 |
Since I did not take any photos while I was actually doing this, I have recreated the process here for FYI purposes.
Like many of us I tend to get on a roll, focused on what I am doing, having fun and not only do I miss the photo ops--- but dinner sometimes too !! For a water proof gasket that will follow an edge on flat surface, or be pancaked down like a plate but not torqued too hard this is what you can do. For this application I used 1/4" or 3/8" vacuum line and split it down one side. I suppose you could use larger hose for larger applications as needed; I just have not needed to yet. As some of you know every thing is spooled in a standard direction that is why it is easier to loop a hose or extention cord left handed than it is right handed, and why they twist up when you dont. So I try to cut the hose on the inside of its natural curve so it will follow the corners more easily. then you run a bead of form-a-gasket on the inside. Here I am using the Permatex stuff I used for my water pump. Then carefully feed it onto the edge you are working on. Be sure to tape it down every inch or two, as the silicon will make it as slippery as buttered snot and you will be mad and messy.... Then it is just a matter of working it on all the way around. If by some chance you did not measure right, or the line was stretched when you cut it and you come up 1/8 or 1/4" short with a gap, dont dispair. You can just fill that space with the gasket sealer. I ran tape over my gap filler so it would have the same contour as the rest of the gasket. Put it aside and work on something else for a day or two while that sets up. Impatience is my worst enemy. And that is it, easy peasy.
#661 |
Yesterday I decided it was time to face the tranny access door issue again.
My first attempt was off to a good start, but I got ahead of myself and physics kicked my butt on it. So I tried again. There is just something that is too cool about taking a flat square of sheet metal, and making something out of it that really gets me going...how weird is that? Here it is installed: I may go with some beefier fastners, I snapped the heads off two of them installing it for the second time. Since the my dome light shared a hole with the cyclops light on the outside, I decided I would mess with both of these at the same time. So here I got the dome light installed as well. I made the mount for this so it would house my spot tweeter speakers. This dome light is from 69-71 Caddillacs, Caprice, and probably a few more GM models. This particular one came out of an Eldorado. I like the map reading lamps is why I grabbed it and added it to my build. Installed: Just the dome light, and dont mind my light lens, I made it out of a milk jug. Just the map lights: I have started on my dash extension console side panels, after I get that all mocked up, it will be time to weld it in.
#662 |
![]() Join Date: Mar 2011
#663 |
Cool ideas! Gotta watch this!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#664 |
Like all the mods so far. Have them bookmarked,,,,, Plannin on comming back at a future time to ssstealll them for my truck.
I do have to ask though.............. Is there a seal or gasket around the tranny inspection cover to prevent leakage? I might have just overlooked that bit of info. Since Im at it............Is there a vid on the subject matter? ![]() |
#665 |
thanks for the side shot, looks great and i really like the dome light, who would have guessed a milk jug,great thinking.
#666 | |||
Thanks for taking a look, the encouragement helps a lot !! Quote:
![]() I know about the bookmarking, I do that, and save a lot of build photos from different projects going on here!! I am not 100% done with that tranny access cover... after I pull the engine back out, I am going to mark the cover from the underside and weld in baffles that will help prevent water intrusion. I will also be making a gasket for that, either a snug up with rubber hose, or some sort of flat gasket with bicycle inner tube. Either way, it will be waterproof !! More to follow on that. Quote:
I also have to confess that the angles of the cyclops light, and the mount I made were purely accidental in how they countered each other so effectively. I clearly recall mounting it up, and then taking the photo, and after posting the photo saying to myself "wow, that really looks like it was made for that..." ![]() Got my HURST C-shifter in yesterday !! Gonna get that tranny mocked up with the shifter and cut the hump before I pull the engine back out this weekend. Hooray for progress !! ![]()
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 Last edited by McMurphy; 11-20-2012 at 02:37 PM. |
#667 |
Wow the truck is coming along awesome. Just got caught up on your thread. Just got back to town. Need to get started back on mine. Keep up the great work.
LIFTED OR LOW THE ONLY WAY TO GO!!!! Check out my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=517346 Projects 56 Chevy pickup Porterbuilt FR/RR dropmembers |
#668 | |
Just in time for the a$$ snapping cold too, you really planned this one good ![]() I think we broke the -20 mark earlier this week.... ![]()
#669 |
good progress mcmurphy, i like the mods you have been doing! i got a third brake light for a s-10 blazer! i got the idea from 'protrash64' here on the forum it looks good too! i just need to get busy doing stuff to my truck before the cold weather really gets here! you can keep it all up there with you, lol!!
my project: http://67-72chevytrucks.com/vboard/s...d.php?t=456163 |
#670 | |
Good luck with that down there ![]() ******************************************************** So this week my shifter handle arrived and I was like ---- Yay !!! Then today I mocked it up to cut the tranny hump and access door, and decided to toss in the seat too, you know just to be sure. Then I was like ------- bummer !!! This is with the shifter in 1st gear..... Le'Sigh.... I always knew this may be an issue so I made sure to remember the adaption that Markb did with his build here: http://67-72chevytrucks.com/vboard/s...=444502&page=2 with this adapter plate he made, So tomorrow before I yank the engine and tranny this weekend I am going to make one of those and ensure it clears all tolerances because there have been a lot of parts to this project that have been held up or set aside waiting for the transmission and shifter considerations. I hope each and eveyone had a wonderful day, Happy Thanksgiving to all those so inclined to celebrate it. Time for dinner here !!
#671 |
Can you heat up the handle and bend it forward?
Posted via Mobile Device Oh, Happy Thanksgiving too. |
#672 | |
1 thing at a time is progress.
Very nice work and mods!!
Alan
Philippians 2:14-16 |
#673 | |
I confessed to the wife I was feeling like an idiot because I was handling the shifter with kid gloves because it was so shiny and new.... Thanks Alan, as you know, your build has been a huge influence and reference for me to do this !!
#674 | |
![]() Posted via Mobile Device
Alan
#675 | |
Not to make lite of your situation,,,,,, but in conversations past.......this situation would be a great topic for your show idea. ![]() |
