06-30-2014, 09:25 AM | #651 |
Re: Brave or crazy? crewcab build
06-30-2014, 10:36 AM | #652 |
Junk Yartist
looks really good!
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
07-01-2014, 11:05 PM | #653 | |||
Thanks guys
check out my crew cab build http://67-72chevytrucks.com/vboard/s...d.php?t=557019 |
07-01-2014, 11:09 PM | #654 |
I put the bed on to get a look at it with the cab corner.
07-01-2014, 11:21 PM | #655 |
I also ran into another snag, apparently my cab has been sitting on the trailing arm crossmember. Not sure exactly how i'm going to fix it yet but I have a few ideas.
07-01-2014, 11:28 PM | #656 |
6>8 Plugless........
Great work! Looking at your thread is always a bad deal for me as I want to build one so bad......
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
07-02-2014, 12:02 AM | #657 | |
If not you may have too many washers on the wrong side of the frame mounts. |
07-02-2014, 12:39 AM | #658 |
Well it happened because the rear portion of my floor is stock suburban and in the suburban the trailing arm crossmember is farther forward then it is now. I added like 20 some inches to the wheel base so there is no clearance in this area of the floor to clear the crossmember. It is not a big deal I knew it was close, just need to decide how I want to fix it. This is one of the things I would have done different if I started this project today I would of used the truck cab floor in the rear and I wouldn't of ran into this problem. I am also going to have to fab all seat mounting points as well because of this.
07-02-2014, 01:04 AM | #659 |
Oh geeze yeah I somehow convienantly forgot you merged a suburban and a c10 haha can I delete that post and we can pretend it never happened?
<--- Last edited by Xeen; 07-02-2014 at 01:21 AM. |
07-02-2014, 08:25 AM | #660 |
Still Learning
Looks great! I'm sure you can fix that little interference problem pretty easy. Just a matter of making a cover plate and welding it in.
07-03-2014, 12:52 AM | #661 | |
It shouldn't be a big deal I think I may cut out the orginal one and move it back then use a flat peice to replace that hole. In the pic you can see the orginal one and where I need to move it.
07-03-2014, 09:21 AM | #662 |
That should work
07-08-2014, 09:52 PM | #663 |
got a little done over the weekend I cut out the hump for the crossmember and welded in a flat piece got in tacked in.
07-09-2014, 08:17 AM | #664 |
Still Learning
Looks good. Nice progress.
07-09-2014, 09:37 AM | #665 |
nice
07-10-2014, 10:23 PM | #666 |
all finished up
07-10-2014, 10:54 PM | #667 |
Very nice!
07-10-2014, 11:05 PM | #668 |
Good work
07-16-2014, 10:10 PM | #669 |
Thanks guys,I have made some more progress will post pics soon!
07-18-2014, 10:48 PM | #670 |
I made mounts for the rear seat. I made some plates with nuts welded to them then welded them on the botom side of the floor. then I cut some 14ga
out for the top to help distribute the weight from the seat. I also made the other speaker mount and seam sealed everthing. Only thing left for the rear is the seatbelt mounts.
07-19-2014, 08:50 AM | #671 |
Man you are killin this thing! I love it. Need more!
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase 1955 Chevy Stepside "Dudley" My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288 1972 Chevy C10, Project "Chevro~Layed out" Nether Storm Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523 |
07-19-2014, 09:41 AM | #672 |
I always forget about floor bolts until I am installing stuff. Again, your are doing great work with this conversion.
07-19-2014, 09:11 PM | #673 |
working on door gap today the I set the driver side up at 1/8 gap so I had to make the passenger side match it was like 3/16. the first pic is the driver side rear door second is what the passenger side looked like before I started
07-19-2014, 09:17 PM | #674 |
I used the old welding wire trick to build up the gap
07-19-2014, 09:56 PM | #675 |
here it is almost done just a little fine tuning with a straight file and it will match the other side. 2nd pic is of the door edge
