09-18-2017, 02:46 AM | #651 | |
Re: S10 Swap how to
no, its not. the fan would be through the core support. you can buy V8 S10 swap mounts and flip them side to side so it moves the mounts back 5 inches, but for a 4.3 moving it back 8 inches is a lot better.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
09-18-2017, 10:31 AM | #652 |
Re: S10 Swap how to
Does the motor mounting position come down to what a guy plans on doing with the fan? I have seen electric push fans used on the front side of the rad. Does this allow enough room to use the flipped V8 mount option, or do you still suggest the full 8" move.
09-18-2017, 11:51 AM | #653 |
Re: S10 Swap how to
I would still recommend that the engine goes 8 inches farther back. You cannot get away with leaving the 4.3 in the same spot as it was in the S 10.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
09-18-2017, 11:54 AM | #654 |
Re: S10 Swap how to
It doesn't matter too much what is done with the fan. I tried to get away with not moving the motor at all. You need every bit of space you can get. My radiator didn't fit at all with the core support mounted and the radiator in place. It hits the lower engine block pulley.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
09-18-2017, 01:12 PM | #655 | |
Re: S10 Swap how to
both of those were 4.3. which is a good point to bring up. the engine mounts are in different places on the block on 4.3 vs V8s. the V8 mount is very forward, the 4.3 is more to the middle of the block so flipping S10 V8 mounts moves a V8 rearward more (its like an 8 inch total move on a V8) than a 4.3. I guess what I am saying is, if the mounts were in the same place on V8s and 4.3, using the swap mounts would move it enough, but if they were in the same place on V8s and 4.3, swap mounts wouldnt exist!
09-19-2017, 10:23 PM | #656 |
Re: S10 Swap how to
Great to know. Well since I have no choice but to move the motor back, is there specific years of S10's that works better for doing this? I believe I read some of the earlier years chassis worked better? I would appreciate any suggestions on what all my options are for ideal donor vehicles. I live in an area with smaller population and therefore limited selection of used vehicles to choose from. I understand S10, S15, Sonoma, any others like Blazers, etc.? What years? (Would like to use the stock 4.3 motor). Thanks,
09-20-2017, 12:12 PM | #657 |
Re: S10 Swap how to
I like to use first generation S 10/ S 15 as a donor the reason is only that the brake pedal Assembly is usable. The Second generation is doable, but you'll need to source a brake pedal Assembly from like a G body. You Will also look for one with a 4.3/ 700R4, as the 2.8 transmission doesn't fit a SBC.
09-20-2017, 10:01 PM | #658 |
Re: S10 Swap how to
I like using the second gen trucks, they have the vortec CFI 4.3 and 4L60e trans, bussed electrical systems, there are a lot of positives. but like skymangs says there can be an issue with the brake pedal, most second gen trucks (98+) have a big aluminum pedal box. also, if you want to keep the electronics you need to keep the steering column and it also attaches to this big pedal box. I have done two AD with 98+ s10 4.3 donors, and made an interface bracket that keeps the aluminum pedal box and steering column mount.
I am doing a 95 4.3 right now and while it doesnt have the aluminum pedal assembly I am going to design a bolt in bracket to hold the pedals and column. its not in an AD, its a 41, but I will document the design.
09-21-2017, 11:42 AM | #659 | |
Re: S10 Swap how to
09-22-2017, 03:10 PM | #660 |
Re: S10 Swap how to
I have looking into the S10 frame change. I have a 3600 1947. Its a California truck, frame in good shape. I was thinking of using a 4WD Blazer for the drive train and the engine and trans. Is that doable, also any suggestions on what to do on the front suspension and axle. I don't have a bunch of extra cash, I just want to make it a daily driver.
09-23-2017, 12:39 AM | #661 |
Re: S10 Swap how to
I havent done it, so I am not an expert, but I think the problem with using a 4x4 is that when you move the motor back the transfer case is right in the middle of the torsion bar attachments.
I know there is a guy who used a 4x4 frame but got rid of the front drive, and therefore the transfer case, that was his solution.
09-23-2017, 08:45 AM | #662 |
Re: S10 Swap how to
I've read about using muriatic acid on the S10 frame, but this frame has so much surface rust, I'm wondering how you would treat it
IMG_1735 by Robert Moorman, on Flickr Thanks, Robert |
09-23-2017, 10:10 AM | #663 |
Re: S10 Swap how to
Sandblast or wire brush/cup.
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
09-23-2017, 11:13 AM | #664 |
Re: S10 Swap how to
muratic acid is mostly to remove the wax the manufacturer put on the s10 frames, if its that rusty there probably isnt a lot of wax left.
I have had good luck with the braided wire cup on a grinder
09-23-2017, 11:23 PM | #665 | ||
Re: S10 Swap how to
See post #622 of this thread.
09-25-2017, 08:23 PM | #666 | |
Re: S10 Swap how to
09-26-2017, 01:25 AM | #667 |
Re: S10 Swap how to
My thinking was to keep the frame off the 1947 and adapt the rear suspension, motor and trans. no transfer case, of course I would need a new drive shaft. The other issue is what to do with front suspension.
09-26-2017, 01:52 AM | #668 |
Re: S10 Swap how to
well technically, an "s10 swap" is using the whole frame, so you can ask for opinions on front suspension and using the S10 rear on the regular forum. a couple guys will dance a literal jig that you are keeping the original frame.
09-29-2017, 03:43 PM | #669 |
Re: S10 Swap how to
I've read and reread I guess it just ran together.....thanks
09-30-2017, 11:29 AM | #670 |
Re: S10 Swap how to
don't I show that?
10-19-2017, 04:06 PM | #671 |
Re: S10 Swap how to
im curious to know what is wrong with the threads that have , bagged, lowered, or slammed in them ... i just posted my first thread and it has bagged in it .. i understand you dont like the style , but we need help just like anyone else .
mr48chev, anyone who's been on this forum for any length of time is well aware of your opinions of lowered or frame-swapped trucks. You don't need to seek out these types of threads to keep reminding everyone. Just a suggestion; when you see a thread titled "bagged" or "lowered" or "slammed" or "S10 swap" DON'T CLICK ON IT. __________________ Bill US Army Vet -193rd Infantry |
10-19-2017, 04:21 PM | #672 | |
Re: S10 Swap how to
Funny... very funny.
10-19-2017, 04:52 PM | #673 |
Re: S10 Swap how to
for anyone wondering how to move the stock 4.3 or want to install a sbc, and dont think you want to build the super simple engine mounts skymangs shows, I have recommended and just recently installed for the first time the universal weld in engine mount crossmember from speedway motors. It comes with two new motor mounts and is $75.
to keep the motor at the same height as stock, I ended up with the tube almost exactly 1/2 way over the frame then boxed in the open end. you can measure from the center of the original mount to the center of the new mount to get the right amount of move, mine is moved 10 inches because its a 41 going on the frame, measure your own to be sure. also, dont forget to offset about an inch to the passenger side for steering shaft clearance, and install the mount at a 4 degree down angle. you dont have to level the frame, just put an angle finder on the middle part of the frame and note the angle, then install the motor mount with 4 more degrees down to the rear IMG_7385 by Joe Doh, on Flickr IMG_7415 by Joe Doh, on Flickr IMG_7418 by Joe Doh, on Flickr IMG_7437 by Joe Doh, on Flickr what about the trans? what if you dont want to section your original or dont have it? speedway makes one of those too. get the one with the 4" drop, I got the 2" drop and it wasnt enough for exhaust. Messages Image(4025115421) by Joe Doh, on Flickr you might need to cut the center of it out to fit a later trans mount. IMG_7408 by Joe Doh, on Flickr it comes with two triangle mounts, but so does the engine crossmember, if you use them all on the trans mount you have a removable trans mount, easy peasy. IMG_7453 by Joe Doh, on Flickr if you order them at the same time you get free shipping, and its under $130 for both WITH new engine mounts. you can build them like skymangs shows and its not very hard and is defintely cheaper, but I spent more time at homer derpo getting the parts to make my own on the last truck than I did installing BOTH of these
10-19-2017, 08:56 PM | #674 | |
Re: S10 Swap how to
http://67-72chevytrucks.com/vboard/s...d.php?t=517098 The nice part about an Internet community is you can ignore anyone you want no matter how loudly they type I'm currently working on putting an accuair e-level and firestone bags on my S10 swap. Be happy to share my mistakes and research with ya.
10-19-2017, 10:20 PM | #675 | |
Re: S10 Swap how to
There's nothing wrong with coming on here and asking for help but before you act like you own the place and start telling everyone how it is you need to put in your dues. Learn, share, show us how you got it done, what your experience taught you, and what you've ****ed up so we don't **** it up too. Then maybe, we, or at least I, will give a **** about your opinion. Sorry to hyjack the thread, rant done. Please, back to "S10 Swap how to". |
