09-07-2015, 04:53 PM | #651 |
Re: What did you do with your truck today, take 2
looks awesome earl! nice job with the battery relocation too!
Frank 1957 Chevy 3100 2000 Silverado z71 SOLD 2012 Ram 1500 Quad Cab 1992 International 4700 |
09-07-2015, 05:09 PM | #652 |
Remeasured for air ride tanks and ordered two of these. Like the fact they come with adjustable mounting brackets.
09-08-2015, 12:06 PM | #653 |
Weekend project:
Installed new HEI Dist and new Edlebrock carb and fuel pump and lines. Other than the massive vacuum leak that from the carb everything looks an runs good. I will have to pull the carb and reinstall.
Tire Guy ---------------------------- Yep I'm a Corvette Guy... 2014 Corvette Stingray 1957 Chevy 3100 |
09-09-2015, 10:13 PM | #654 |
Took a couple of pics to send in for a calendar contest. The least I'll get is a free shirt!
My build http://67-72chevytrucks.com/vboard/s...d.php?t=495795 |
09-10-2015, 12:08 PM | #655 |
Just noticed that, does it drop down or ?? for removal.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
09-10-2015, 12:42 PM | #656 |
ATOMMIK
lookin great ! |
09-10-2015, 11:23 PM | #657 |
OrrieG. I made the battery box so that the tray slides out and then tilts forward for battery R&R or maintenance.
You have to have patiences or you'll be one. |
09-13-2015, 04:52 PM | #658 |
Fixed my gas tank sender unit that not worked because of rust.
Also started to prepare for Mustang II installation
1948/50 Chevy 3100, CSB 327/TH350, M II IFS |
09-13-2015, 05:01 PM | #659 |
No pix (they'd be boring anyway) but finally got out two VERY stubborn clutch head screws holding in the window winding mechanism on my driver's door.
After not having a clue how to get the guts out of our doors I figured it out on the passenger side and thought the driver's side would be a snap - NOT. The clutch heads tore out and I had to use a chisel to get them to rotate. Both doors are now ful,y naked and will be dropped off at the blaster's tomorrow and later in the week to the bodyshop.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
09-13-2015, 05:46 PM | #660 |
thanks for the reply.
09-13-2015, 06:43 PM | #661 |
Looked under mine...then mowed the yard. Oh, and I counted the splines on the axle for the diff center section....28.
09-14-2015, 12:02 PM | #662 |
Installed the horns, but had to troubleshoot the wiring for them. Turned out that either the wire between the horn relay and the column harness came loose, or was hidden in the harness and I did not notice it. After I got it corrected found one horn has decided to bleat instead of honk so will need to dig another out of the stash. I tested it before I cleaned and painted it, but who knows what happened. Nice to know my steering column adaption is going to work. First time ever the truck has had a horn, it was MIA when I got it in 76.
09-14-2015, 01:54 PM | #663 |
That ATOMMIC truck is sweet. Nice job. You should absolutely make that calendar.
09-15-2015, 07:20 PM | #664 |
Picked up the new block and heads this am. Prepped, primed and put color on it. Waiting on the new high rise to come in, hopefully we'll have it back in the truck next week!
1955 2nd Series Truck |
09-18-2015, 11:54 PM | #665 |
Worked my tail off looking for pictures of '58/'59 truck three on the tree shift control rods on the internet, to no avail....
09-20-2015, 12:15 PM | #666 |
Took a ride out to Holt train station for a 1940's weekend event. Had a lovely day, spitfire flying over added to the 1940's atmosphere
yoshi's 49 project |
09-20-2015, 01:12 PM | #667 |
Buy a factory assembly manual $30 all over the internet. It gives you information like this: (sorry for the orientation don't have time to fiddle with it).
09-20-2015, 06:49 PM | #668 |
Reaffirmed my build direction and motivation by reading this forum (thanks for the pickmeup, guys) and re-watched some favorite how-to videos online. Then coming to the realization that another parts buying frenzy may be needed...and the plastic money i was using for this build was getting hot enough already.
09-20-2015, 11:37 PM | #669 |
working on getting my firewall prepped for some paint so I can then work on freshening up the engine and putting it back in. no pictures sorry.
09-21-2015, 04:54 AM | #670 |
Installed a battery isolator switch after having the battery drained two times (after 3 weeks not running the truck).
Hope this will solve the trouble.
'55, Chevy 3600, 2nd serie, 3/4 ton, 235, 4 speed Muncie SM420, 4.57:1 rear axle |
09-21-2015, 09:20 AM | #671 |
Over the weekend I built a custom overhanging brake pedal and steering column bracket assembly for my 56 GMC. Part of it came from a '70 Chevrolet pickup. It's definitely unique!
09-21-2015, 06:41 PM | #672 |
Bought clear to finish the doors and misc interior stuff. Also go a pint of the green I think will work to try out.
09-21-2015, 07:36 PM | #673 |
Changed my thermostat/housing to the newer style, installed a higher temperature unit (187 degree) and solved the issue with electric fan control. Truck now runs at a constant 185 to 195 degrees and the fans never come on until I'm setting for about 5 Minutes. Before it would average 165-175. Oh, also yesterday I installed insulation under the seat to the back of the cab.
Rob
My '47 C.O.E build |
09-22-2015, 12:04 AM | #674 |
Finally pulled the body off after installing M11 front suspension and four link rear.
Also took 21" out of the wheelbase to make it a short box. Now I need to pull the motor plum the brakes and paint the frame.
Doug 48 chev LWB pickup 350 turbo400 tri power 48 GMC S10 350 700R4 48 che 5 window 2012 Camero suspension & power train |
09-22-2015, 04:07 PM | #675 |
Stripped the front end of the frame in preparation for installing the Mustang II cross member this weekend. Finally getting some time to get the project going again.
