Old 03-04-2016, 07:52 PM   #651
swamp rat
swamp rat's Avatar
Re: Starting my engine build
http://www.summitracing.com/parts/ta...FYlcfgodjRYC_Q
https://www.youtube.com/watch?v=Do4P-AP26eE
Installed on the wires before the boot ends are installed on cut to length wire sets.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-04-2016, 08:21 PM   #652
Mrturner1
I'm installing a new full sweep temp gauge right now, I was going off the stock pos gauge. Stand by.
Also, timing is set at 34 right now when at 3000 rpm so I think I'm ok there, I THINK
Mrturner1 is offline   Reply With Quote
Old 03-04-2016, 10:29 PM   #653
Average Joe
Average Joe's Avatar
http://m.summitracing.com/parts/huu-3160006
Personally I like this better than the megashifter and you can fab a stand for it for easy access.
http://www.jegs.com/images/photos/60...ACA-1800-1.jpg
Or....you may be able to utilize this and keep your column shifter and have more room for baby and fiance 😃
Or just track down the factory parts to make it work.
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 03-04-2016, 11:33 PM   #654
cadillac_al
What's wrong with your linkage? Is it loose and sloppy or something? Does the crossbar have the bushing on the frame side? There isn't much to go wrong there.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 03-05-2016, 12:08 AM   #655
BrianG
BrianG's Avatar
This will be controversial, but you may want to ditch the electric fans, get the proper fan shroud, a clutch and fan for it. Electrics can work when everything is just right but clutch fans have been used with great success on many a hot rod.
BrianG is offline   Reply With Quote
Old 03-05-2016, 12:14 AM   #656
Mrturner1
The guy who took the inline 6 and 4 speed manual out, made some contraption for the new column shift and auto that has a big U shaped metal peice bolted to the frame. And there's a hole in the center of that where a rod slides in the keep the linkage at the trans from moving while you shift. It was wrong and sloppy when I bought it. Need to be done right especially now with much more power. Safety is #1 on the list because fiance loves to take rides and eventually wants 3 point harnesses for the car seat.
Old 03-05-2016, 12:16 AM   #657
Mrturner1
Dual electric fans will cool MUCH better than single clutch. I want this thing dialed in and running great, so temp won't be an issue before long.
Old 03-05-2016, 12:25 AM   #658
Mrturner1
I decided to tackle a different project because anothe boot melted and was arcing so tuning was out of the question. I dented the header (opposite side this time lol) and put the spark plug in, plenty of room but can't get a new boot until tomarrow. But that should take care of the plugs and boots issues for good. All others have clearance. If not I'll get 16 dollar boots like Mike said, hopefully not though. The project I tackled was gauges. I've had them sitting around and decided it was a good time to start and finish something so K don't go crazy lol here's a few pics, lights on and off.
Old 03-05-2016, 12:25 AM   #659
Mrturner1
Gauges
Old 03-05-2016, 12:26 AM   #660
Mrturner1
Lights on
Old 03-05-2016, 12:27 AM   #661
Mrturner1
Old 03-05-2016, 12:28 AM   #662
68c10owner
68c10owner's Avatar
Not always true. Ive seen many guys go this route only to go back to a clutch fan. Sometimes those cool dual fans dont move enough air.
Anthony
68c10owner is offline   Reply With Quote
Old 03-05-2016, 12:28 AM   #663
Mrturner1
Stock dash lights have always been really dim, even when turned on the brightest setting, not sure how to fix that
Old 03-05-2016, 12:31 AM   #664
Mrturner1
At an idle your saying a clutch fan can move more air than dual electrics? I can't see it. I don't doubt your knowledge by any means, and I am certainly a beginner.
.....sheesh I sure hope your not right. I LOVE those fans
Old 03-05-2016, 12:38 AM   #665
68c10owner
68c10owner's Avatar
What im saying is dont discout the clutch fans. You might be just fine but I have seen the electric fans cause a lot of cooling issues. There are different ratings on the fans. Not to mention the fan, along with the corrdct clutch and shroud will cool as good or better. Most coolig problems are from not choosi g rhe correct parts to start with.
Anthony
Old 03-05-2016, 12:38 AM   #666
BrianG
BrianG's Avatar
Yes. I know some won't agree but many more will. I said it would be controversial didn't I?
Old 03-05-2016, 12:41 AM   #667
Mrturner1
It's a really nice setup. Flexalite duals with a big thick built in shroud around the whole thing
Old 03-05-2016, 01:17 AM   #668
Sklptrljay
Sklptrljay's Avatar
Just a thought, it's hard to tell in the pictures, but they do make header spark plugs that are shorter. Might help your issue with touching the tubes
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 03-05-2016, 01:43 AM   #669
Mrturner1
I picked up two of them today and they worked well. I have to get a new plug wire boot tomarrow so I may grab a few more short plugs
Old 03-05-2016, 02:40 AM   #670
storm9c1
*** That's interesting ***
storm9c1's Avatar
Eh, I can provide a real-world example here. When I bought my '69 Charger, the previous owner had a belt driven flex fan (no clutch) as a puller. On the front side of the rad, he mounted a dual flexalite shrouded fan as a pusher. And of course the car overheated on the highway all the time. And ran hot just about everywhere else.
So I did some experimenting. First I deleted the flex fan and tried the shrouded flexalite setup on the proper side as a puller. This worked just OK, still ran hot on the highway. Tended to push coolant out of the cap. Ran reasonably cool in traffic. I wired a LED to tell me when the fans were running and they ran constantly. Sometimes they ran on the highway at 55MPH. Not good. At highways speeds, fans become a nuisance not a help. Eventually the wiring burned up. I was sick of that hack and started over.
Next step was to delete the electric fan and install the proper factory 7-blade big block fan with thermal clutch and factory shroud. Wow. Night and day difference. No more overheating in traffic. No more overheating on the highway. Engine sits at about 180-190 degrees on the gauge on the hottest days no matter what. Clutch freewheels the fan when not needed, so doesn't rob much power. The engineers knew what they were doing. So every vehicle I've gotten since that originally came with mechanical fans and were hacked to electric were reverted.
I really like electric fans on computer controlled vehicles, but only because the computer knows to shut the fans off at highway speeds, handles cooling hysteresis, etc.
A properly shrouded seven blade clutch fans pulls a ton of air. When that clutch locks, it roars, I don't have the calculations, but I imagine it's on par or better than the best electric fans. And what I like better is that clutch fans constantly move air, keeping everything cool, whereas electric fans cause a heat soak cycling effect where everything heats/cools/heats/cools.
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
Old 03-05-2016, 04:39 AM   #671
Mrturner1
so I spent 400 dollars on something that won't cool my engine, but the same fans are on hundreds of other hot rods and cooling just fine. I don't get it. It's my tune and timing is what I think, but I won't know for a while
I broke a header bolt off in the block taking it on and off to many times I'd guess. Its inside with nothing sticking out to grab and I just drilled for an hour and I got a 16th of an inch at best with steel bits. I don't have a welder, so I can't go that route....I'm tired of looking at this thing, it's just bad news after broken bolts after whatever's next.
Old 03-05-2016, 06:48 AM   #672
68c10owner
68c10owner's Avatar
On the cooling issue, what I ment was never say never. You said a clutch fan would never cool as good as your dual fan set up. Speaking from actual personal experience electric fans are not better or worse. But I will never again run electric fans on a street car.
For your broken bolt, sounds like you may have cross threaded the bolt. They dont just break from beig taken out multiple times. Not sure what steel bits you are using but the bolt shouldnt even be tight in the hole unless you have too long of a bolt and it bottomed out and you kept tightening it anyway. Find some good cobalt bits and a ez out kit.
Anthony
Old 03-05-2016, 10:34 AM   #673
cadillac_al
It's pretty hard to break header bolts. You must be extremely rugged or have very very bad luck. I'm thinking I don't like your Hooker headers if they are so hard to get the plug wires routed. I have Heddmans and no-name headers and the spark plug and wire access isn't that bad. The no-names are too close to my oil filter though.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
Old 03-05-2016, 01:07 PM   #674
Mrturner1
I was so mad last night lol couldn't get it tuned right, kept burning plug boots (which are 6 bucks a peice!) got the headers bright red and then broke a bolt. I think the header bolt broke from getting so hot a couple times when the headers went red, I didn't wrench on it very hard at all and was backing it out. Then after all that I thought, my 400 dollar fans that I love aren't going to work, but a stinkin clutch fan will?!
Anyway, rough night lol but I did get the gauges in that made me happy. I'll grab a couple plug boots, some good drill bits and an easy out and be back at it
Old 03-05-2016, 01:56 PM   #675
Mrturner1
I've got a B&M mega shifter at home, so I'm trying to decide on that, or that lokar column shift someone posted earlier. Anybody have a lokar column shifter linkage to give experience on?
