Old 04-01-2022, 07:10 PM   #651
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: My Dusty 71 GMCe Electruck
Originally Posted by Gregski View Post
next it was time to stack sum plates
for this I decided to work out front in my driveway, figuring it's been days since my last HOA complaint!
Thats hilarious right there!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 04-01-2022, 09:58 PM   #652
DoubleDubya
Cool Re: My Dusty 71 GMCe Electruck
here I'm just showing off my protractor and sliding ruler skillz
Better get a faceplate on that outlet. You don't want the Feds showing up at your workplace to shut you down.
I am always impressed with your progress. I can see the first test drive coming just around the corner. Can't wait.
DoubleDubya is offline   Reply With Quote
Old 04-01-2022, 11:43 PM   #653
Low Elco
I like the way the battery trays could stack in the compartment. It'd have been hilarious if the c10 rear shaft and the Lexus front had mated right up. Great work, keep it up. When this runs, it'd be fun to hook it up and get some comparative performance numbers.
Low Elco is offline   Reply With Quote
Old 04-02-2022, 04:34 AM   #654
Gregski
Post Whore
Gregski's Avatar
I was literally waiting months on someone to comment about that outlet, yes it has a perfectly weather tight cover plate which when on renders the darn thing completely unusable as you can not plug anything into it, ha ha
thanks, that's awesome for you to say, not sure about a test drive yet, but the goal for this month is wheel spin fer sure, under her own power
and you did not hear it from me but someone's turning fiddy in May so it sure would be nice to maybe git a test drive for his birthday, just sayin'
Gregski is offline   Reply With Quote
Old 04-02-2022, 04:38 AM   #655
Gregski
Post Whore
Gregski's Avatar
the Mountulator 3000
... and please don't go all Anglesuxon on me, this is just a mockup
Old 04-02-2022, 04:40 AM   #656
Gregski
Post Whore
Gregski's Avatar
looks like both my Transmission and the short drive shaft sit at the same angle of 7.5°
please let me know if you all think that's too much on the slant? I honestly don't know if it is or not, we can raise the tail of the trans sum if need be
Old 04-02-2022, 04:51 AM   #657
Gregski
Post Whore
Gregski's Avatar
oh man and I had them out side by side before I took the Lexor in to git it shortened and a new rear 1310 yoke welded on
fer real
Old 04-02-2022, 04:52 AM   #658
Gregski
Post Whore
Gregski's Avatar
one more look, without the rear rubber donut this time
Old 04-02-2022, 05:25 AM   #659
Gregski
Post Whore
Gregski's Avatar
here's a video update: Electruck EV Conversion Update 1 Lexus GS450h Transmission Mount
Old 04-02-2022, 11:14 AM   #660
yuccales
yuccales's Avatar
Loved your crowstar!
yuccales is offline   Reply With Quote
Old 04-02-2022, 11:22 AM   #661
Gregski
Post Whore
Gregski's Avatar
ha ha, thanx, our son came up with that
Old 04-02-2022, 11:02 PM   #662
Gregski
Post Whore
Gregski's Avatar
let me know if you know what these are and if there is a difference?
Old 04-02-2022, 11:05 PM   #663
Gregski
Post Whore
Gregski's Avatar
so I finally liberated the steering linkage, I believe the disc brake conversion calls for different tie rod ends
Old 04-02-2022, 11:08 PM   #664
Gregski
Post Whore
Gregski's Avatar
time to go after that crossmember
Old 04-02-2022, 11:11 PM   #665
Gregski
Post Whore
Gregski's Avatar
and let me tell ya, she put up a fight
Old 04-02-2022, 11:12 PM   #666
Gregski
Post Whore
Gregski's Avatar
there was no way gently tapping the upper control arm spindle knuckle was gonna brake her loose
Old 04-02-2022, 11:13 PM   #667
Mike Bradbury
Mike Bradbury's Avatar
Removing tie rods and ball joints
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 04-02-2022, 11:13 PM   #668
Gregski
Post Whore
Gregski's Avatar
not even a 4' cheater bar and a vice would press her out
Old 04-02-2022, 11:15 PM   #669
Gregski
Post Whore
Gregski's Avatar
driver side lower control arm
Old 04-02-2022, 11:17 PM   #670
Gregski
Post Whore
Gregski's Avatar
so see them alignment shims, I swear every time I work on the control arms I loose these, or mix them up, or loose track of them somehow
Old 04-02-2022, 11:20 PM   #671
Gregski
Post Whore
Gregski's Avatar
yes sir, and up until today I didn't know there was two different kind, no wonder my ball joint puller was slippin' off the tie rod ends, so I went to Oh' Reallys and rented the proper one
Old 04-02-2022, 11:22 PM   #672
Gregski
Post Whore
Gregski's Avatar
but today I was ready for these little rascals to go flying right into my pre labeled zippie zip baggies
Old 04-02-2022, 11:24 PM   #673
Gregski
Post Whore
Gregski's Avatar
and what did they do after I loosened them bolts? did they drop straight to the floor or some black abyss
No, nope, they just stayed there, laffin' at me!!!
Old 04-02-2022, 11:25 PM   #674
Gregski
Post Whore
Gregski's Avatar
document (although four per side they are of different thickneseses)
Old 04-02-2022, 11:28 PM   #675
Gregski
Post Whore
Gregski's Avatar
well between cleaning the garage a bit, and the 7 trips to the parts house to rent the proper pullers I only got one side removed
