Closed Thread
Old 04-27-2013, 09:34 PM   #6751
OregonNed
OregonNed's Avatar
Re: What did you do to your truck today!
Today I upgraded from some plain aluminum valve covers and chrome air cleaner to finned aluminum replacements. Also a few other cleanup items under the hood.
Before
After
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 04-27-2013, 09:41 PM   #6752
mortoyz
Active Member
Here's a view from the front
mortoyz is offline
Old 04-27-2013, 10:58 PM   #6753
Tomahawk30
Tomahawk30's Avatar
Great day today! Spent the morning installing the new lock set, gauge cluster bezel with LED bulbs, and passenger mirror on Sprout, followed by some chrome polish on the bumpers and wheel trim. Then my wife and I took Angus to the local building supply store to pick up some trim material for our guest house remodel. Turns out Angus' tailgate is the perfect height for me to use as a workbench for cutting trim with my mitre saw. Wrapped the day up by driving Sprout to the store to pick up dinner. The weather was PERFECT today so I was thinking of excuses to drive the trucks and just be outside all day!
In hindsight, I wish I'd have taken some pictures today...
1979 Silverado C10 Shortbox - Photo Album
1977 Silverado K20 Camper Special - Photo Album
1972 C10 Custom Deluxe Highlander - sold
1971 Cheyenne Super Longhorn -sold
1972 Cheyenne Super SWB 4x4 -sold, bought back, sold again... I'm dumb.
1970 Chevy C10 SWB "Sprout" -sold
1972 Cheyenne K20 -sold
1969 GMC Shortbox Stepside 4x4 -sold
1972 GMC Jimmy 4x4 -sold
Tomahawk30 is offline
Old 04-27-2013, 11:01 PM   #6754
Tomahawk30
Tomahawk30's Avatar
Love your truck! Tough to beat a black Cheyenne 4x4!
Old 04-28-2013, 12:04 AM   #6755
bugmasta
bugmasta's Avatar
Sprayed in a bedliner
68 c20 build: http://67-72chevytrucks.com/vboard/s...d.php?t=358130
Club longbed ...cause girls like'em long!!!!!
bugmasta is offline
Old 04-28-2013, 12:31 AM   #6756
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today!
I went to the truck @ 0-Dark:30 and adjusted the auto choke rod ~ it was a shade too much choke when cold , now it idles much smoother as it warms up .
That bed liner looks really nice ! .
So do the rest of the trucks here , makes my old rig look junkyard ready .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 04-28-2013, 07:05 AM   #6757
lghell
Really nice truck you got there
/Patrik
C20 4x4 1970 TBI350/TH350/NP205
Sweden
lghell is offline
Old 04-28-2013, 07:16 AM   #6758
lghell
Started the process of changing my front outer u-joint
And cleaned my boot and ring for the transfer case stick.
/Patrik
Sweden
lghell is offline
Old 04-28-2013, 10:27 AM   #6759
dirtyjim
dirtyjim's Avatar
put a new seat cover on the old eargesplittenloudenboomer, as soon as i get rid of the damn flowmasters it will get a new nickname
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline
Old 04-28-2013, 10:36 AM   #6760
luckyss
Fixed the trans, looks like it may be back on the road by this afternoon
luckyss is offline
Old 04-28-2013, 01:11 PM   #6761
ole dollor
ole dollor's Avatar
nate did you overhaul your motor ? thought i read some where that you did...
ole dollor is offline
Old 04-28-2013, 02:46 PM   #6762
nlped
nlped's Avatar
Ordered more parts for the '70 GMC. I'm so ready to get this thing put together!!!
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline
Old 04-28-2013, 05:22 PM   #6763
bugmasta
bugmasta's Avatar
Installed door sills, shift boot, and detailed engine compartment for upcoming show.
bugmasta is offline
Old 04-28-2013, 06:13 PM   #6764
bignbad
bignbad's Avatar
used it as a truck like it is,and my 10 yr old nephew
'72 chevy k20
'06 H-D Springer softail
http://www.bluemooncruisers.com/
http://www.enginecycle.com/
~Eric
bignbad is offline
Old 04-28-2013, 07:05 PM   #6765
TexasK5
TexasK5's Avatar
Took the top off and ordered a new Be Cool radiator
TexasK5 is offline
Old 04-28-2013, 07:10 PM   #6766
nlped
nlped's Avatar
Originally Posted by texask5 View Post
took the top off and ordered a new be cool radiator
cool!!!
Carter
nlped is offline
Old 04-28-2013, 07:51 PM   #6767
VWNate1
VWNate1's Avatar
Post Re : Progress : s l o w
No , I have the 292 and got the head rebuilt , new bronze valve guides to replace the crappo original cast iron ones , I have the 292 short block on the stand awaiting me to begin , I have several long distance Road Rallys coming up soon so I've been rebuilding the front suspension and brakes in my '59 Metropolitan Nash FHC , it's back on the road and buzzing right along but then a wheel bearing began to howl on right turns , sounds like a rear hub bearing is going bad...
The current 250 I-6 is running champs , the HEI allows me to run .070" spark plug gaps , this burns all the oil it blows so no misses but , it gulps oil a quart every 200 miles , not good ~ I'd thought about dropping the oil pan and yanking the cylinder head , pushing out the pistons and re - ringing it with gapless piston rings then slap the pre smog 292 head on it for now but maybe I'll do that later as I have other vehicles that are barely chugging along right now .
-Nate
Geezer
VWNate1 is offline
Old 04-28-2013, 08:02 PM   #6768
Shyguy
Junior Member
Shyguy's Avatar
I took one step forward and two steps back today so to speak when I was wiring up the tail-lights on the '67.
I got both tail-lights to work and the left brake light to work. I did a little trouble shooting and found out there was no voltage going to the passenger side.
Then I got the wise idea to pull the steering wheel and check out the turn signal switch and messed with it a little, now the neither brake light works.
I guess I will have to do a little research and trouble shooting another time.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline
Old 04-28-2013, 08:06 PM   #6769
ole dollor
ole dollor's Avatar
Re: Re : Progress : s l o w
good to here its running better, so you are building a 292 for the truck...thats cool. my 292 has 116452.0 as we speak, and still running strong and no oil useage . maybe it will run ok until you get time to drop the 292 in it...good luck
Old 04-28-2013, 08:36 PM   #6770
bassetlust
Finally got the retractable shoulder belt setup that I bought from LMC installed - now I can feel safer when I drive the old monster!!!
bassetlust is offline
Old 04-28-2013, 10:39 PM   #6771
vannatta20
vannatta20's Avatar
Installed remote start
vannatta20 is offline
Old 04-28-2013, 10:50 PM   #6772
goose_on_fire
Finished taking the outside parts off the inside parts.
goose_on_fire is offline
Old 04-29-2013, 12:21 AM   #6773
buckskins4ever
buckskins4ever's Avatar
Drove up to Nevada IA for the Annual Spring Fling Car Show. What a day, lots of beautiful cars (not but a handful of trucks), 75 degrees and sunny. Looking forward to the next show.
buckskins4ever is offline
Old 04-29-2013, 12:33 AM   #6774
ItsRandy
ItsRandy's Avatar
Washed it, vacuumed the interior, cleaned the windows and wheels then took it for a drive to squish bugs all over it again.
ItsRandy is offline
Old 04-29-2013, 12:52 AM   #6775
Bloodyjaws88
Posted via Mobile DeviceToday was a less then spectacular day. I came home from work and fixed the starter, only to have the truck decide it didn't want to idle. I looked down to see no oil pressure at idle, but the it jumps up when giving it gas. Wonderful. Then I see smoke rolling out from under the hood. I discovered oil all over the front of the engine. Woderful x2. Looks like its off the road til I can put a new oil pump and pan gasket on it. Then I can try to figure out why it only wants to run on 7 cylinders all of a sudden. Been a crappy day.
Chris
Bloodyjaws88 is offline
Closed Thread
