01-18-2013, 02:04 AM | #6801 |
Re: What did you do to your truck today?
01-18-2013, 06:00 PM | #6802 |
VERY SHWEEEEEEET...............ME LIKES........PLAIN AND SIMPLE.........
1964 BBC 402 4x4 |
01-19-2013, 01:12 AM | #6803 |
Got another coat of rattle can paint on the lower control arms for my baby, hope it holds up and looks nice for a little while at least. I will put another coat of clear coat on it once installed to hide any marks I put on it during installation. Plan on putting the front cross member in this week end
01-19-2013, 01:47 AM | #6804 |
I spoke with a fellow member who lives about an hour from me and he has a bunch of parts I need. And I put in an order for a bunch of little stuff from classic parts. Nice way to burn thru $400. At least my truck will be ready to roll when the snow melts.
66 shorty |
01-19-2013, 02:49 AM | #6805 |
Picked up my set of plates for the truck, wish I could of gotten the antique plates, but already had a ticket, no sense in waiting to get another.
Bought some wiper arms and blades, figured I better get them on before I need them. Also bought a cheap shifter knob. Figured I've learned stick enough to get me a little something. |
01-19-2013, 10:27 AM | #6806 |
You need to go wash that truck,Oh wait a minute it's it's not on your truck it's me DROOLING all over the laptop screen....sorry...I have to ask what size tires and wheels are you running,that's kinda the look I'm going for..my 64 the original color is a light green,but I was thinking about the Dark Blue with white top..Awesome,Awesome,Awesome,Awesome truck.......
1964 BBC 402 4x4 |
01-19-2013, 10:34 AM | #6807 |
7.50 by16 stock tire size and tread design, may go for a ride again today supposed to be 60 deg
01-19-2013, 10:36 AM | #6808 |
I may paint my 62 k-20 that color
01-19-2013, 03:59 PM | #6809 |
Scrapped the bad cab and some odds and ends. I couldn't help but feel a little sad when the crane grabbed it off the trailer and crushed it.
I just couldn't save it. Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla Matt. 6:27 "Who of you by worrying can add a single hour to his life?” http://www.67-72chevytrucks.com/vboa...=507266&page=2 |
01-19-2013, 04:46 PM | #6810 |
Ok,j.kirn I have to ask what color is that,I believe Iv'e fallen for that color...between that or the dark blue......
1964 BBC 402 4x4 |
01-19-2013, 07:12 PM | #6811 |
The 60 like you see is neptune green and bombay ivory,my 62 k-20 i am gonna paint the blue and white
01-19-2013, 07:24 PM | #6812 |
Is that Factory 1960 colors...
1964 BBC 402 4x4 |
01-19-2013, 07:27 PM | #6813 |
do you have any more pics of that truck,what's the drive train I see it's 3/4.Is it 235 or 283 manual 4 spd...do you have any Interior shots.....Thanks a bunch Randy...
1964 BBC 402 4x4 |
01-19-2013, 07:51 PM | #6814 |
Moderator
I bought a 65 C10 BBW LWB Fleetside. Custom Chrome, Custom Comfort options. 230 with 3spd. Looking forward to getting to work!
01-19-2013, 07:59 PM | #6815 |
01-19-2013, 08:33 PM | #6816 |
Went on a cruise to Tuckers Trucks. Then pulled out the welder, filled the antenna hole. Slapped the temp primer on. Showed the neighbor kid my build photos, his dad has a 1963 longbed build 18 years ago. Time to freshen it up I say. Found some parts I needed and some I don't. Anyone need a set of Bell Tech 2.5" Drop spindles? The brake kit I am getting has drop spindles inclued. PM me if so. 6-lug rear axles and drums after the 5 lug conversion.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
01-19-2013, 08:44 PM | #6817 |
Thanks so much for the pics,I'm sure I'm not the only one enjoying them.
1964 BBC 402 4x4 |
01-19-2013, 08:56 PM | #6818 |
I decided I'm not low enough - (it's the addiction ). I pulled my motor back out today and currently setting up to z'frame 3 inches. Will also be installing T5...slow going.
01-19-2013, 11:32 PM | #6819 |
Back to the junk yard to get a heater fan motor and a few other things that looked interesting..cool place to hang out!
01-20-2013, 12:45 AM | #6820 |
Painted my bed.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
01-20-2013, 01:38 AM | #6821 |
Senior Enthusiast
Received and installed my new 1990 vintage NOS mechanical aircraft clock/chronograph today. This is how easy it is to read from the driver seat, much nicer than the old electric model with the setting knob in the middle:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
01-20-2013, 02:36 AM | #6822 |
Did this..Here's the update of the burb.. I'll let the pictures tell the story.. There were over 200 spot welds lovingly drilled out today...
Here's the driver's side outer floor and inner rocker welded in.. Still have to smooth the welds.. And--here's the mayhem I caused today.. I removed the entire inner structure in expectation of finding internal rot in the A-Pillar.. After rmoval of the dashboard and inner panel-I found that the inside was solid. I will be coating the inside with rust converter and then using the cutaway pieces below to make everything solid.. I will sandblast all the individual pieces before slapping them together... Does anyone re-produce these placards? I used a little Simple Green cleaner on mine to get the oxidation off, but the color started coming off worse than it already was. I figure I can get a new one if they are re-created and just stamp the original codes and numbers in the blank spaces. And, here's the finished steering wheel. It's a GM Pewter Metallic Dupli-Color spray can color from NAPA. I think the lighting makes it look pretty close to the "Fawn" color although I was looking for more of a silver. The metallic in it is really nice-can't wait to get it in some better light. There are more pictures in my link below showing today's work..
My '65 Suburban Resto build-- http://smg.photobucket.com/albums/v6...65%20Suburban/ And it's story of being 'saved' http://www.jalopyjournal.com/forum/s...d.php?t=631495 |
01-20-2013, 02:40 AM | #6823 |
Senior Enthusiast
01-20-2013, 03:22 AM | #6824 | |
01-20-2013, 07:07 AM | #6825 | |
