Re: What did you do to your truck today!
___________________________________ Dima 1970 Chevrolet C10 stepside http://67-72chevytrucks.com/vboard/s...d.php?t=569197 |
Customized my new Moon gauges to match my tachometer.
Brad handshoe |
fri nite i installed my cab for the last time
![]() on sat i figured i would take the weekend off from the truck. but before i did i slapped most of the sheet metal on too get a good visual of what i'm working towards and too check a few things. this is the first pic/time i've had a periord correct bed on this truck. i have alot of sanding and body work coming this spring(ugh i cant wait)its too cold to do it now so i'll get everything prepped until then. seeing the body slapped together gives me great incentive too get'er done. i even had too pop on my e primed oe caps on just for the looky look(2nd pic)
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
laying low
![]() Join Date: Mar 2001
Finding good parts for American made vehicles in your neighborhood has to be difficult at best. You are doing a fine job with your truck. I applaud you Gor.
It looks like you also have several American cars in that shop too.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#6 | |
![]() Join Date: Jan 2012
Thought about it for days. took a nap in it with feet hangin' out and decided i have a classic never to be built again.Might not be a show winner,but it's what I want.
Luv the site!!!
It builds on my intelligence when I make a mistake, Boy am I building on it! '67 C-10,'70 Nova SS ![]() |
Took the wife out to dinner...and we took the truck. This is a pic from when I was still doing the cut/buff. Need to update pics.
That's a good idea, I may do just that!
I might have a paint job coming up where I will need a proper paint gun... Here is what I just finished up today: Second coat of silver put on the back of the tank: ![]() I also manned up and removed the carb for rebuilding: ![]() I am about to head over to the store for a rebuild kit. |
I didn't realize you had a 6 banger rig ~ good on ya ! .
Look for the HVLP paint guns with the paint cup on top ~ they're simply amazing .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
Yes. I get the Harbor freight paint guns for next to nothing. They're actually pretty good. I use one about three or four times and throw it away. Then I go get a couple more.
I didn't realize you could get a Samsung Galaxy for $49.99.
#13 |
![]() Join Date: Dec 2012
Wished it was home
1971 GMC Sierra 1959 GMC 100 |
#14 |
![]() Join Date: Mar 2012
Bought an elec cooling fan and adjustable thermostat to control the heat in traffic. Hopefully get it installed this weekend.
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
#15 |
Remember , *VERY* important to :
A : install a relay to carry the fan's current B : wire it live so the fan will come on during the heat soak when the engine has been shut off . Properly installed , the Electric fan out cools the mechanical fan hands down , is quieter and saves a couple (about three) horsepower and allows you to delete the mechanical fan completely . -Nate |
#16 |
The only thing is even with a relay still need to update the charging system, a lot of the old trucks were generator or the wimpy 37/60 amp alts. I upgraded to a 100 amp 12si style.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
#17 |
Actually ;
A standard GM Delcotron SI alternator from any old dead Chevy will do just fine . Your 100 Ampere alternator only puts out what is necessary and 100 amperes is never necessary so 90 % of the time , it's putting out 15 ~ 20 amperes tops . IIRC the 1989 V6 Camaro has a 65 +/- ampere alternator , I always use & suggest this because it's available EVERYWHERE off the shelf , is dirt cheap and uber reliable . plenty of power to run the AC . killer stereo , power windows , halogen headlights on and on and.... As long as the battery remains properly charged you're good to go . I do understand the want to have over capacity but many here just want turn key old trucks they can drive/work/play with / in .
#18 |
RAT1968 '68 Cab/'71 Parts
Came home from the paint jail today. One month and three days early...July 26-August 23.
I have a bunch of detail work to do. Clean up the bed. Put the wood floor back in clean up a little polishing compound around the windows and in the seams. Put the new and newly painted to match solid (no turn signal holes) front bumper on, and a few other little things. I'll post pics tomorrow. Too tired and excited to take 'em this evening. My painter experience had, up to now, been the same as most of yours. Before I met Lee The Painter. Body work was replacing a pass. rocker (that I supplied), welding up a bunch of holes, including some strange ones up behind my head on the cab, pulling out bondo from here and there, re-doing doors that I'd paid a schmuck $300 to do, took it all down to metal, skimmed it and shot it with eight coats of primer that mostly got sanded off. Color and clear in high quality paint. $4,500 plus $320 in extras that came up as surprises to him as he found them. I gave him four silver 1" x 3" plaques I had engraved, "PAINT BY LEE MOISANT", but kept one for my own truck. Gave him a $100 "thank you" bonus. And a lower end, but very good, Yamaha acoustic guitar with the promise of at least ten 1/2 hour guitar lessons....if he wants 'em. So, even though it wasn't a $15,000 paint and body job which would qualify for SEMA show time (even though the truck..with a $15,000 paint job wouldn't even be allowed in the parking lot), it's better than the paint on my fairly new daily-driving Japanese Altima Hybrid. Now, off to a car show tomorrow to get some pinstripe ideas. Just wanted to tell the tale of paint. Guess they don't ALL turn out bad, huh? Could'a fooled me before today.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#19 |
Home!!
![]() Posted via Mobile Device
1970 Chevy swb, project UGHH! ![]() 1987 Grand National http://s168.photobucket.com/albums/u.../1970%20Chevy/ |
#20 |
In the last week spent over $2000 in parts for it.. time to rebuild the hubs, brakes, ball joints, u joints, steering ect.. and a lot of other stuff too.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#21 |
Looking good Wes, that's one of the first mods I did, that and HEI.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#22 | |
![]() Join Date: Feb 2009
Between yesterday and today, I put about 350 miles on the truck. Running good so far, and putting out a nice, steady 14.5-14.6 volts. I upgraded my other 67 to a HEI, but not sure if I'm going to on this. Hoping the points last until I can do my LS swap in the spring.
1970 2WD K5 1968 Camaro Conv 1967 Chevy SWB 1964 Malibu SS 1957 Corvette Pics www.picturetrail.com/wesmigletz |
#23 |
![]() Join Date: Sep 2010
Joe put another coat of the "wood boat" wax on the bed today. It's really holding up well considering it's been finished for almost three years now !!! . . . .
. . . . Life is short . . . we only have, right now. . . . . My 70 C-10's BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=475526 |
#24 | |
![]() Join Date: Jan 2006
don "The DRBMan" 2014 Audi A4 (The Wife's Daily Driver) 2017 HD Ultra (The Cruiser) 2003 HD Fatboy (The Ride) 2001 Chevy Suburban (Another back up!!) For the first time in forever, not a single 67-72 Chevy truck, Blazer, or Suburban on the property! Basically retired and getting the new Motorhome ready for some traveling. Doing a bit of work on the house getting it ready to sell! LOL!! |
#25 |
Put the wood back in...Cleaning up after getting out of the paint shop.
My Low-tech home improvement wood bed will have to do for now. Down the road? Who knows? Tough to beat the cost...And in-and-out in about an hour. I numbered all the pieces so it fit right back together...snap, snap, snap...screw, screw, screw (about ten screws in the aluminum strips). Forty bucks the first run and $0 every other time she's in and out..... ![]() ![]() ![]()
